Available light shots
Started by Alex_Mustard ·
  • 165Posts
  • 165Replies
  1. Thanks James.
    I've seen the article and found it to be instrumental in getting geared-up for my upcoming trip. I was wondering if anyone else has had the opportunity to try their hand at using the technique.
  2. I have found it very applicable at shallow sites in Grand Cayman - but many of the traditional dives sites are too deep - so it is important to select where you try it. Alex
  3. Hi Alex,
    Thanks for the info. I don't plan on going below 10m on this trip.
  4. Greetings,
    I have read the article and reviewed this thread and would like to try my hand at available light photography.
    Could I get some help on where to start.
    Data:
    1-I will be in Bonaire 12/6-12/17 and will usually dive between 35-60 feet.
    2-I have an Oly C5050 in a Pt-015 and a Sing-Ray SR-B 67mm Marine Filter that I purchased as part of a package deal.
    With my strobe [iNON D-180] I simply set to f 5.6, point the camera at the water and set the EV to 0. Is this a good place to start with available light photography?
    Tom
  5. Tom,
    Using a strobe AND a lens filter is very tricky ... the red correction from the lens filter for ambient light will make the strobe too red unless you use a filter on the strobe, to shift it bluer. As a beginner at this, I am sticking with "pure" available light (no strobe) until my use of filters in this situation is good, and then I may try to get fancy with the strobe. Craig (if I recall correctly) has previously posted on how filters nicely fit on some Inon strobes.
  6. Ok no strobe. Where do I start with my f-stop, ev and shutter speed?
    Tom
  7. The easi4est answer is check the readings on your camera when you get in the water. If you put it in auto you will get a setting that will work.
    If you put it in aperture priority it will then choose your shutter speed for you.
    and then when you get used to it you can put it in manual and adjust all your settings for the result you want. :rolleyes:
    i would like to know what filter pack you have as i have a oly 3040 in tetra housing and would like to know what sortof filter system ohter people use with it.
    is there a web example of what you use ?
    Giles
  8. Giles-
    It is clear that there is a dearth of experience on this subject. To the extent I can I will add to this thread.
    I wish I could find a refrence to the filter that I have. The bill of sale says Custom Filter SR-B 67MM (Underwater). The filter case is labeled Singh-Ray Marine Filter 67MM.
    I have 10 diving days in Bonaire so I should be able to experiment with available light photography as well as take standard pics with my strobe. [iNON D180]
    I will start in Macro, Auto, no strobe mode and see what happens at various depths and natural lighting conditions.
    Tom
  9. Great shots !
    Being a neophyte at the DSLR and Ikelight approach, I have a really basic (I am sure) question......
    I have tried to do the same thing, using my D100 with no strobe, but the shutter will not trip underwater. Above yes, but once in the water, nuttin. I know I am probably missing some very obvious points, but I don't know enough to be dangerous. Any help would be appreciated !
    mjleblanc
  10. You are probably trying to use a wideangle lens behind a dome port and the lens doesn't have a close enough focus to focus on the virtual image created by the dome.
    The lens will focus fine above water, but when underwater, the water and port acts as a negative diopter.
  11. Help!
    Does anyone make colour correction filters that will fit on Sea & Sea equipment?
    specifically
    - DX 5000 (Nikon Coolpix 5000 housing) standard port
    - Sea & Sea WA lens for MMIII and DX5000
    If not, is it possible to buy larger filters, cut them to size and ...?
    My local photo experts say "no" to both
  12. I have noticed quite a big difference between CC filters and Fluorescent filters is in the cameras ability to auto white balance.
    Fluor filters (specifically the UR-Pro series that I have used) tend to work really well on AUTO-WB (even when they actually don't look too good on the LCD screen when they are underwater). Whereas CC filters tend to need custom white balancing either in situ with a grey/neutral card or in RAW conversion in post processing.
    This shot, for example, was shot on Auto WB and can out of the camera looking pretty much like this. The only way I can get such good colour balance straight from the camera with a CC filter is in situ WB.
    The obvious answer to this is that fluor filters are better. But I am not convinced about this because at certain depths the camera uses more extreme white balance (colour temp and tint) settings for the UR Pro than are needed for the CC filter. It is just that the camera (well my cameras D100 and D70) have found it easy to get the right white balance (in Auto) with the Fluor filter as opposed to the CC filter.
  13. Alex, I absolutely agree that FL filters are better for ambient light and I think that the camera agrees too! I think CC filters are OK for shallower depths and for complimentary stuff. FL filters are much harder for mixed light shooting though.
  14. Craig, I was hoping that you would add your thoughts.
    Now we need a fluor filter that will work on a fisheye! (Not easy to physically fit them on with glass/sandwich FL filters).
  15. Nice color, Alex.
    But I'd bet that if you saved your white-balance image and did a post-WB using the white from that image (as opposed to trying to find white on the image you're working on), you'd arrive at similar results...?
    Or is that not the case? The reason for this is that the WB is so far off the scale that normal raw converters don't even offer the option for you to drag the sliders that far. One has to WB by clicking on white, and since it can be difficult to do so in the actual image you want to WB, you can take the settings from another, helper image.
  16. Craig, I was hoping that you would add your thoughts.
    There aren't any that I know of. I've combined two gels for that purpose but it's very hard to do without the image going soft. It's be great to get some FL gels.
    Nikon's 16mm has a lens cover that's easily adapted to take a front filter. With a DX sensor camera the corners aren't clipped too bad and they disappear with barrel correction. That doesn't help the 10.5 of course.
    I think a tinted dome would be cool too. :D
  17. I think a tinted dome would be cool too. :D
    What a great suggestion. That would be the ultimate UW photographic extravagance.
  18. Help!
    specifically
    :blink:
    Kirk at URPRO can custom make them to your specs... at $$$. Another idea is to check out ikelite. They have a plastic filter cap for their bigger video housings which can be retrofitted. I have no idea how wide your WA lens is but that's a start.
