Nauticam - BMPCC 4K
Started by Miru ·
  • 131Posts
  • 131Replies
Nauticam - BMPCC 4K
  1. The guy posted the settings used:
    “31-66ft, Braw Q0, set WB to 8000k”
    Can the new camera set wb or is it just colour temperature setting??
  2. Can the new camera set wb or is it just colour temperature setting??
    https://youtu.be/1b-yj_YXBoM?t=328
    Looks like you can use a center box for manually setting WB
    Edited by thetrickster
  3. Interesting RAW editing observation with the BMPCC4k..
    Due to the dual ISO configuration, you are only able to change the ISO values in Resolve within the two individual ranges [100-1000] [1250-25600] - so if you wanted to go from 800 to 1600, this is no possible.
  4. Interesting RAW editing observation with the BMPCC4k..
    This I guess inside the same clip but not overall?
  5.
    Yes this is per clip. As you can modify the iso, white balance, tint on a per clip basis.
  6. Yes this is per clip. As you can modify the iso, white balance, tint on a per clip basis.
    This is not a big issue unless you go into a cave your shots should range max 2 stops overall
  7. Agreed. Just thought it was interesting, if you were already at ISO 800 and wanted another stop on top, you wouldn’t be able to do it via raw.
  8. Interesting RAW editing observation with the BMPCC4k..
    This video does a good job explaining the two iso ranges:
    Edited by thani
  9. For people considering the BMPCC4k or a GH5 (or people looking at upgrading...)
    I've tried my best to match the housing sizing to get an idea on travel sizing. Top I've matched the n85 port and front latch. Bottom matching the rear latch sizing and vacuum led size - its not 100% but enough to showcase the relative housing sizing.
  10. Assuming that you don't need a monitor (and I think you still do) the dimensions are fine
  11. The housing is on sale now Alex tattersall just posted it on facebook
  12. The housing is on sale now Alex tattersall just posted it on facebook
    Indeed...hopefully mine will be posted by Alex tomorrow.
  13. Indeed...hopefully mine will be posted by Alex tomorrow.
    Only £3600!!!
  14. Basically, if you remove the ball mounts on the handles, height is the same as GH5 rig. Width only slightly wider. Looks similar to the nauticam housings for full frame DSLRs (D850, not D5). Price is the same too :)
    Look forward to hearing what you make of it, Richard.
  15. Basically, if you remove the ball mounts on the handles, height is the same as GH5 rig. Width only slightly wider. Looks similar to the nauticam housings for full frame DSLRs (D850, not D5). Price is the same too :)
    I know I was against the BMPCC4K to being with (having had the GH5s and discounted it) as an upgrade from the GH5 - but the more I thought about it, the more I liked the idea of RAW, internal recording and for me the smaller travel setup compared to my GH5/Inferno, - and there is only one way of proving or disproving yourself - got to try it out for myself... so I bit the bullet.
    Not selling the GH5 - Ideally I would like to get them both in the water at the same time, to report back on a side by side, and i think the GH5 will sit well as a photo rig - its what to do with the inferno - keep it as a lovely screen for the BMPCC4k (but then this negates the travel aspect) or sell it on.
    Will report back once I have it all in my hands - but I believe there will be others in the water sooner than me, so will be keeping an eye on vimeo and youtube.
  16. This video does a good job explaining the two iso ranges:
    Thanks for this. Just got around to watching it today.
    Very concise and to the point. Really explained clearly the Dual ISO - and how to use it to your advantage. Some good pointers.
  17. Looks good. Can’t wait to see more of this camera in the real world. Not having the ibis puts me off a little but raw would be so nice
