Nauticam - BMPCC 4K
Started by Miru ·
  • 131Posts
  • 131Replies
Nauticam - BMPCC 4K
  1. Just open with Vimeo...
    Edited by TaxiDiver14
  2. I see nothing wrong with these clips.To my taste I would add some contrast and saturation. Maybe he likes them in this way.
    I suppose BMCC 4K has color profiles (???). Who knows which one he used.
  3. The clip on vimeo can be downloaded the file is pretty basic not even 10 bits and bit rate is low for H264. In terms of the clips itself the usual situations color in the foreground with lights ok background dim that you can't correct no matter what
    The guy is pretty stable though considering is shooting a lens without stabilisation so he has nothing at all to help him that must be the reason why the shark trip is slow mo
    ideo
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L5.1
    Format settings : CABAC / 2 Ref Frames
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 3 min 8 s
    Bit rate mode : Variable
    Bit rate : 19.6 Mb/s
    Maximum bit rate : 768 kb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.095
    Stream size : 442 MiB (99%)
    Title : Core Media Video
    Encoded date : UTC 2019-05-09 17:47:21
    Tagged date : UTC 2019-05-09 17:57:12
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
  4. Finally got out and dived this weekend with the BMPCC4K.
    Was mainly shooting ambient lighting in 8-25m of water with no filters or lights. I got a couple of shots with lights, but haven't look at these yet.
    So fair I was impressed with the housing handling (button layout probably not as good as the GH5 housing if I'm honest - would be nice to have the AF button on a thumb lever, more than a push button on the rear) but button layout is good enough. I purchased the hand strap, but this is not good combo, as you need to move your hand to reach the front dial to change aperture, so took it off as it got in the way.
    Screen, in shallow waters, it was hard to see, the focus assist (when you could see it) was very clear, and I found, once I had focused it initially at the beginning of the dive, I didn't need to touch it again. Getting a bit deeper, the screen was lovely, with a clean layout and no lag. Looking forward to adding the 7" atop for better ergo with a deep hood.
    Buoyancy needs work, as I was a bit negative and front heavy, but as I found in the pool with the inferno it should balance out nicely.
    Really impressed with the highlight handling, close to the surface it didn't blowout the surface like my GH4 and GH5 would have. Colour handling very similar to the GH5, obviously it can't restore what isn't there, but no banding or compression issues either when playing with the colour wheels and channel mixer in Resolve.
    Q0 at 60p 4K DCI was no problem with the Samsung T5 drives, no dropped frames or issues. The HFR button is a real nice feature, you tell the camera you want to film in 30p and the HFR button will switch to 30p/60p - but on import to Resolve, it will automatically mark the 60p clips for slowdown. Nice.
    A few clips I had a quick look at and play with last night. Need to spend more time with Resolve (as I'm used to FCPX) but happy with the results so far.
    Will post up some straight from camera BRAW files later today / tomorrow for anyone interested. (They are huge mind..)
    One BIG issue which has reared its head, is due to the camera not doing any in-camera lens corrections (one of the reasons I wanted the BMPCC4k) - the side petals of the WWL-1 are visible in shot shots (I presume due to the OIS in the lens moving) so a slight crop-in (in-post) is needed. I haven't tried it with the OIS turned off - but something to consider.
    Overall, from my initial dive, I'm super pleased with the camera and what Nauticam have done with the housing.
    Edited by thetrickster
  5. Finally got out and dived this weekend with the BMPCC4K.
    I think when you use a multiaspect sensor in 16:9 the horizontal axis is wider than the 4:3 format on a normal camera so you can see the hood. Disable the OIS may help then you are left with nothing at all I presume?
  6. I can confirm the petals on the wwl do appear on the na-bmpcc4k but for me its only on the left hand side. Upper left corner is a strong vignette but the right side is completely free of these. The very slightest of zoom means it is gone. Swapping between OIS didnt change anything.
  7. I can confirm the petals on the wwl do appear on the na-bmpcc4k but for me its only on the left hand side. Upper left corner is a strong vignette but the right side is completely free of these. The very slightest of zoom means it is gone. Swapping between OIS didnt change anything.
    Yeah - snap. Its just the left hand side (that werid eh!)
    What lens were you using? (I was using the PZ variant of the 14-42mm with the 29mm port, I've yet to try the Mk2 14-42mm with the 35mm port)
  8.
    I'm on the 14-42 mk2+35 port. I guess there is faint vignetting right hand corners but pretty faint... see for yourselves.
  9.
    Shadow top right corner and petal left side
  10. I found this review pretty comprehensive
    https://wolfcrow.com/blackmagic-pocket-camera-4k-real-world-review/
    The conclusion from wolfcrow
    Those who want to shoot documentaries, weddings, events, music videos, etc., should stick to the Panasonic GH5 (B&H, Amazon) instead. For extreme low light work, nothing beats the Sony a7S II (B&H, Amazon).
    On the whole though, the Blackmagic Pocket Cinema Camera 4K (Amazon, B&H) is a great camera as far as image quality is concerned, and is a perfect fit for low budget short or feature films, web series, corporate videos, etc
    Any more real life examples out there?
