Sea&Sea YS-D3 doesn't work with UWT TTL trigger?
Started by stuartv ·
  • 128Posts
  • 128Replies
  1. 17 minutes ago, stuartv said:
    I would feel like it was much more useful if the test was done with diffusers on each of the strobes.
    Note the shot descriptions; left column is shot without diffusers, right column is with a specific diffuser
  2. 9 minutes ago, stuartv said:
    Thanks! Now, I think I remember seeing that before.
    I think that applies to both strobes , but they are a bit Apples and Oranges.  INON has a 110° beam bare while S&S has a narrower beam but can get about 100° with a diffuser but the guide number is closer to 24.  Add to that guide numbers are a marketing requirement it gets harder still.  The backscatter test from a year or two back was a reasonable guide to expectations, but a lot of the new strobes are not included.  https://www.backscatter.com/reviews/post/Best-Underwater-Strobe-Flash
    It's not entirely clear where the angles they quote are measured from The figure to look at seems to be the 60° measurement which is either edge of a 120° beam if I am not mistaken and the strobes are all quite close there.
  3. On 1/18/2021 at 11:20 AM, JustinO said:
    Well, that is weird - am no physicist, but suggests the sensor may not be as sensitive to red light?  Just took a look at the S-Turtle trigger - looks like an interesting bit of kit, .  Maybe test it on Manual rather than TTL first just to ensure you get a bright enough output?  Fingers crossed it works for you!
    I think many strobe triggers are most sensitive in the near IR. A common trick is to use a TV remote to fire them.
    Bill
    Bill
    I evaluated Z-240 sensitivity range few years ago.  Z-240 optical receiver was more sensitive in red light, than in white light. And yes, it also has sensitivity in near infrared, but in red range it is better. That was a reason for red LED usage in TTL triggers. And later this solution was confirmed for many times in comparison tests.
    Edited by Pavel Kolpakov
    Right. I was talking about the data chart that shows how much less light there is in the different zones. I can't tell whether the data in that chart is based on using a diffuser or not. It kind of looks like it was collected without a diffuser. If so, I would really like to see what the same data looks like when collected with a diffuser. To my untrained eye, it looks like all of them would be closer in performance.
    In that article, I thought this quote was interesting:
    "Inon Z-330 vs. Sea & Sea YS-D2J
    In looking at the 2 top current model strobes, their patterns without diffusers are almost identical."
    Interesting because in the photos in the UWT article, those 2 strobes, without diffusers, appear to have very different patterns.
    Also, comparing the Z240 and Z330 in that chart (with diffusers), it looks like the 330 is a solid full stop brighter, at full dump, At least, in the more central area of the beam.
    Bill
    That's really interesting, thanks Bill!
    Just tested it  with an old strobe and it worked. Close range only, so  I can't mount it on the TV and aim it back at the sofa....I guess I'll have to find another way to persuade the kids to do something else during lockdown!
  8. Well, there is good news and bad news.
    The bad news: I am a dumbass. At least that is only bad for me and not so much bad news for the rest of you.
    The good news: The UWT trigger seems to work fine with the YS-D3s.
    Tonight I was working on my camera housing, trying to work out some things with the UWT trigger and my Z240 strobes. I was checking the position of the dial selector on the trigger, to make sure it was set correctly for the Z240s. It was hard to see because the wires for one of the LEDs were kind of in the way. I stuck a finger in to try and push the wires out of the way so I could see.
    I guess I pushed on them just right and the LED slid another several mm up into the hole where it goes. Then I tried it with the other LED and it also (after some wiggling) also slid up a similar amount.
    *sigh*
    I got the YS-D3s back out, along with the cables @bvanant sent me, and tried everything again.
    Here is the weird part: The first cable I tried was the fat, solid core cable that Bill sent me. The strobe still did not fire. I almost packed everything away right then, thinking that the LED position didn't matter. But, that is not my personality. Next, I tried the 1000 core cable. That didn't work, either.
    Last, just for the sake of completeness, I tried the 613 core cable. It worked! I tried a few shots with it, in both Manual (on the strobe) mode and switching everything over to TTL. It worked every time. Then I moved the cable over to the other LED port on the housing and tried it all again. Everything continued to work.
    So then I got out my Howshot 613L cables that I've been using all along with my Z240s and tried both of them, on both LED ports.
    Then I got out the other YS-D3 strobe and tried my cables on both ports with that strobe.
    Everything worked! As in, everything using a 613 core cable worked. I did not go back and retry the 1000 core and solid core cables again after having success with the first 613 cable.
    The sad part is that the LEDs were like they were because I am the one that installed the trigger in the housing. When I bought the housing and trigger from Reef, they sent it pre-assembled. But, that first trigger was defective and they ended up replacing it. Rather than ship the housing to them to do the replacement, they just sent me a new trigger to swap out myself. So, the positioning of the LEDs was totally my fault. (but they worked just fine with my Z240s...)
    So.... what a lot of hoopla for nothing!
    @Pavel Kolpakov I want to apologize for all the doubt I raised in this thread about the UWT trigger. And thank you again for the help here and via email.
    The funny thing is that I had already decided to forget about trying to use these YS-D3 strobes, so I have a buddy coming to buy them from me tomorrow. At least now I know, and I can order another set at my leisure.
  9. Good to see a solution, not sure why you would be keen to buy another pair if they are so sensitive about their triggering though - do you see any advantage to them over your Z-240s?
    The reasons I wanted them in the first place were expecting them to have more power, when needed, and the ability to shoot strings on continuous drive (faster than what the Z240s will do).
    However, I'm not going to buy another pair right away. I thought this was a done deal earlier and I could do something else with the money I'll be getting back out of these strobes tomorrow. So, I made arrangements to pick up a Sony 200-600 lens on Friday. You know... for those Jawfish that just won't come out if you're too close. ;) Strobe money gone (for now).
  11. LOL, sounds a brilliant switch: strobes to a 200-600 lens. :rofl:
  12. Regardless, UWT doesn't have a D3 profile yet, correct?
    I assume everyone has a list of "I wants".... strobes and a long lens are just 2 of MANY items on mine... :D (and I stumbled across a killer deal on the lens yesterday)
    As far as I know, that is correct. When "new strobes" makes it way back to the top of my shopping list, ordering a Turtle trigger directly from Balazs' website is definitely something I will be looking at. But, really, where I've ended up is going to give me a good opportunity to do what I should have done long before now - experiment with using TTL with my Z240s. If it proves useful, then new strobes and a trigger with a TTL profile for them will be on the list. If I decide TTL doesn't really have any value for what I do, then I won't care about the D3 profile. The profile isn't used when shooting on plain old manual (no TTL).
    YS-D3 profile will be added to UWT firmware at the end of this week.
    I will also share TTL test results of YS-D3 by optics and by sync cord.
    Once you have that, how could I get that profile into my UWT trigger? Is the only way to send my trigger to you to update?
    First of all,  i would compare YS-D3 profile to existing YS-D2 profile, maybe the difference is very small and no sense to update. I will specify. Please wait for few days. I will share the info.
  17. Guys, I need help. Sorry to piggyback on this thread, but I kinda have a similar issue :( I just dropped $$$ on an Aquatica housing and ports for my Sony A7R3. Drove from the Bay Area to LA last week to pick up from Bluewater because I'm leaving for Oahu on Tuesday. I told the Bluewater rep I had a Sea & Sea YS-D2 and Sea & Sea YS-110a. I guess this isn't a widely known issue, otherwise I think he would've suggested for me to switch to sync cords OR buy the S&S 613 optic cable. I called Aquatica and the guy I spoke with suggested sync cords because he's heard of strobes being triggered by other strobes when using the type II 613 cables. He added that S&S must have overcompensated for the lack of sensitivity.
    I'm not entirely screwed on my trip because the 110-a works with the trigger. Of course the recycling time is slow because it's old, but it works! The YS-D2 doesn't. At all. I've always shot with fiber optic cables because I don't want to deal with the added o-ring fussing and leaking. My question to you guys is - should I get that S&S cable for my YS-D2 or say to hell with S&S new strobes and just get Inons/something else like the original poster did? I've had issues with the uneven power and recycling time of using two different strobes anyway... Thank you in advance for your advice!
    I like the say to hell part.
    What trigger system are you using? I would get new Inon or Retra strobes if time and budget allow for.
    Ha! Using the Aquatica trigger.
  20. If you go with INONs all the triggering problems will disappear.  Bluewater seems to really like the S&S strobes for some reason - just an impression I have.
    The issue most people seems to be experiencing seems to be getting the strobes to fire at all, rather than them firing on their own? - this board is littered with tales of woe from people with difficult to trigger S&S strobes including YS-D2.  From the evidence I've seen here S&S slave sensors are getting progressively less sensitive with each new model.
    I think the first step should be to try a 613 core cable, either S&S or Nauticam at least on this trip - if you have until Tuesday you could drop down to Backscatter in Monterey to get a better cable - if you can squeeze it in, checking by phone to see it's in stock first of course!!.  Or you could drop $$$$ on a set on INONS which will trigger.
    Oh - and double check the LED on the trigger  is lined up with port properly - it may need jiggling.  I assume you have swapped cables and ports so you have tried each strobe on each port with each cable in turn?  That would be 4 checks in total.
    Edited by ChrisRoss
