Sea&Sea YS-D3 doesn't work with UWT TTL trigger?
Started by stuartv ·
  • 128Posts
  • 128Replies
  1. 34 minutes ago, Pavel Kolpakov said:
    In nearest months we are waiting for the sample of YS-D3 MarkII from Sea&Sea, for tests.  Hope the TTL control has become better there.  So, the nearest future will show.
    I'll be interested to see if you find the same discontinuity in the TTL response curve that I'm seeing.
    I'm using Cree C503B red LED, driven at max current.  40us preflash trigger pulse, ~50ms between preflash and main flash, and then variable-length main flash trigger pulse.
    • 13us = ~GN2.8 smoothly up to 60us = ~GN5.6.  (output flash pulse 36us...70us)
    • Then between 60-70us it jumps directly up to GN8+0.5EV.  There is no input pulse length which generates an output flash pulse length between 70-160us.
    • Above that it's a smooth curve from GN8+0.5EV up to GN22 at 1000us and GN22+0.3EV at 1600us.  (output flash pulse 160...1400us)
    Unfortunately, GN5.6 - GN8+0.5EV is kind of a big gap, right in the range where TTL exposures are likely to fall.
    I don't know if that's something they can fix with another firmware update.
    Why do strobe manufacturers not simply have a straight linear profile for us LED-based trigger board folks?  Something like:
    • 100us input pulse = GN2.8
    • 150us = GN4
    • 200us = GN5.6
    • 250us = GN8
    • 300us = GN11
    • 350us = GN16
    • 400us = GN22
    • 450us = GN32
    That would be really easy for us to generate, and would allow plenty of accuracy on the strobes themselves (much more so than the exponential lengths they try to capture now, which are really short for low power and really long for high power).  And it's not like the strobes don't already have different profiles built into them for number and timing of preflash pulses; this would just be one more profile.
    If we standardize on that profile, then ANY strobe would work with ANY trigger board.  No need for us to profile them every time a new strobe comes out.  That'd be good for the strobe manufacturers too; more potential customers for their new strobes without needing to wait for us TTL board folks to profile them.
    Edited by Randall Spangler
  2. On 2/14/2022 at 11:55 PM, Pavel Kolpakov said:
    YS-D3 strobe was not supported by UWT  TTL-Converters. That strobe had extremely low and unstable sensitivity optical TTL input.
    But recently Sea&Sea has announced they significantly improved TTL in the newest model YS-D3 Mark-II. In nearest months we are waiting for the sample of YS-D3 MarkII from Sea&Sea, for tests.  Hope the TTL control has become better there.  So, the nearest future will show.
    @Pavel Kolpakov Has there been any update on YS-D3 support since your Feb 2022 note?
    Yes, the new version YS-D3 MkII is well for TTL. It works acceptable with UWTechnics TTL Converters (tested at similar profile Z330). Next month it is planned to build a separate TTL profile specially for YS-D3 MkII.
    Edited by Pavel Kolpakov
  4. Thank you for the update and look forward the the additional work you mention.
    Is it possible to update the UWT converters in the field for new profiles as they are created?
  6. It is possible to update the firmware of the TTL-Converters produced in 2021-2022.
    When the new firmware is created, user can send the product to UWTechnics factory (Taiwan) for the update.
  7. Pavel,
    Can the firmware not be updated over the internet rather than sending you the product?
  8. 4 hours ago, MarkB said:
    Pavel,
    No, that product does not have such possibility.
