Removing scratches from a dome port
Started by rschrager ·
  • 185Posts
  • 185Replies
  1. I badly scratched up my Sea & Sea dome port (it's acrylic) while diving at Cocos and Malpelo. Lots of current and lots of rock is a bad combination for a housing with a big dome port. A couple of fairly deep scratches (you could easily feel them with your finger) and some shallower ones (you could feel them with you finger-nail).
    After doing some research, including some older threads on this board, I decided to try the Micro-Mesh NC-78-1 ACRYLIC RESTORAL KIT (Micro-Mesh) . It's made for taking scratches out of airplane windscreens. It cost $37 and comes with 9 grades of their Micro-Mesh papers (high grade wet/dry sandpapers), polishing paste, detergent, anti-static cream and pads and cloths.
    Taking a good stiff drink first, I started the job with 320 grade wet/dry paper, went to 400 grade paper and then started using the Micro-Mesh papers. Each grade took about 3-5 minutes and the instructions were to sand in straight lines only, not circular, and then rotate the dome about 120 degrees for the next grade.
    After the first sanding, the port looked like a diffuser (although when I flushed it with water before going to the next grade, it was clear). However, by the time I did the final polish, it looked new.
    I highly recommend this product. $37 and a little elbow grease (actually, not much at all) is a lot better than a buying a new port.
    Bob
    ____________________________________________________________________________________________________
    _________
    I couldn't find it for $37 but it did work well on getting out some minor rub marks that wouldn't respond well without it. Nice to know that I can repair scratches and blemishes in the future. I highly recommend this product, too!
    Richard
  2. I posted this elsewhere but it probably should be in this thread as well.
    Ikelite 8" dome, Micro Mesh NC-78-1 kit
    <object width="425" height="350"><param name="movie" value="
    name="wmode" value="transparent"></param><embed src="
    type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
    Thank you!
    I had a scratch on my Aquatica port that was fine underwater but would annoy me on over/under shots.
    The Kit saved it (after a very stiff drink and lots of talking to myself before I started)
    Dive safe,
    Celia
  3. Hello all
    I been able to get the products you all talk about but not in kit, and I am missing the instructions...
    Is it possible to get a copy of the user manual for the micro-mesh kit and the novus kit?
    Thanks for giving hope to my Dome port!
    Pedro Alves
  4. Hello all
    Pedro Alves
  5. I know this has nothing to do with y'alls subject, but I am looking for help and information. I received a bunch of equipment that I have no idea what it is worth or what to do with. I have two boxes, one is holding a sea and sea pro vx1000 underwater housing and the other has a bunch of what looks like lenses, batteries, cables, lighting etc. I received these from a client that is in declining physical health and can no longer enjoy them. I don't know what to do with these items as I don't dive. Can someone please give me some information? Anything helpful would be appreciated.
    Thank you,
    Clueless
  6. Hi and thank you for all the advice. Just got a 50 mm fine scratch in my 8 inch Ikelite dome port and didn't know what to do.
  7. Here's a nice video about using the micro mesh... I found it "comforting" :lol:
  8. I killed my Sea & Sea fisheye dome on a high current dive in Bali. The scratches ruined all of my shots at Manta Point to where I had to really butcher them in PS to make them viewable. It was suggested I try toothpaste. I did that and it worked, somewhat, but didn't get the really deep scratches. When I got home I bought a headlight repair kit (they make two grades, one for normal oxidation and one for heavy scratching-I bought that one for about $22 as I recall) The kit included two grades of superfine sanding discs, a buffer and buffing attachment for an electric drill, and two levels of polishing compound. An hour or so later it looked like new. You can buy this stuff at any auto supply store, Sears, Walmart, Target..... The only tough part was keeping the buffer out of the shade ring when doing the top and bottom edges.
  9. Very helpful , thanks
  10. This is great info. Thanks everyone.
  11. They do Alex. It's called a credit card.
    Bob
    LOL!!!!
    Bob
    Has anybody tried to use those car headlight cleaner sets? They come with paper and paste...! You need a drill for the paper though.
  12. Hi Udo,
    Thanks for sharing with all. Good job. Now a solution for crystal domes too.
    Thanks!!
  13. Glass dome solution (aluminum "scratches"):
    Didn't have time to read the whole thread, so apologies if this is a repeat of another post. Thought I would offer it anyway- just in case.
    I was shark cage diving in South Australia with my Zen 230mm dome kitted up and had my rig through the cage's camera port. Every so often one of the huge South Australian white pointers got a little too close so I had to retreat into the full safety of the cage in a hurry. I had heard stories of sharks squashing cameras against the cage or having a test taste, so decided to pull my kit "indoors". A few times I bumped the dome on the aluminum cage which left a mark. When one of the marks was right in the center of the dome, my heart sank.
    When I got out of the water and grabbed my Colgate regular toothpaste from the cabin, and started rubbing. 30 mins later I had removed the aluminum "mark" on the glass and was delighted to find out it had not actually left a scratch. Good news. Chris, one of the Divemasters, suggested I use "Jiff" which had "microcrystals" instead of toothpaste because it worked faster and would not scratch the glass. He said that this happens to most of the people with big glass domes. I tried it and it worked a charm. I just used my leather palmed dive glove as rubbing cloth and rubbed off the aluminum marks. Very good outcome. I reckon this product is called Softscrub in the states. Not sure, but it worked well and I have a perfect dome once again. It only worked since the aluminum is so soft compared to the optical glass- no scratches, just aluminum colored marks.
    Good news considering we had 7 different white pointers in 3 days (I was more terrified of the 13 degree water than the 5m males)!
  14. A good suggestion, but I'd stay away from 'used' gloves as the leather may contain coral/sand grains.
    We use 'SoftScrub" when your mask gets to the pint where it needs a good basic cleaning.
    Have never seen any scratches in masks or domes/ports from SoftScrub!
  15. Has anyone had any success in sourcing Micro Mesh in the UK. The website given doesn't ship anywhere but the US.
  16. Hi there,
    My story is similar to that ones of the members above, but i took images of my domeport in between each step which i want to share with you. Each picture is after a treatment with different grain size papers (1500-12000). Just for your information.
    cheers, Udo
    the scratch that caused it all
    after the first treatment with 1500 grain size paper
    after 2400..
    after 3200
    after 3600
    ...4000
    ...6000
    ...8000
    ...12000
    ...Finished
    and finally after treatment with abrasive liquid and and antistatic treatmanet mounted on my housing.
    cheers, Udo
    Hi there,
    cheers, Udo
    after 2400..
    after 3200
    after 3600
    ...4000
    ...6000
    ...8000
    ...12000
    ...Finished
    cheers, Udo
    Wow! Waht a difference! How do yo like the D800?
  17. Hi,
    Some questions on this old but precious thread.
    I lightly scratched my Nauticam 6" acrylic dome port. Scratches are visible when shooting > f8 or sun in my frame.
    I have the NOVUS kit but...
    Dome protections on my port are not removable so is nearly impossibile to polish the entire dome. There's one inch of dome that is impossible to reach.
    I read that once you polish a dome you cannot polish just the damaged part but it must be polished entirely.
    Any advice?
    Thank you all
    Edited by Davide DB
  18. I did something really bad to my Ikelite 8” dome port this weekend. After not shooting UW for about a year I have been putting all the pieces together. We’re going to Little Cayman in a few weeks. I was testing the strobes and needed to put a lens on the camera. I had the super wide port body on the big dome but instead of mounting the shorter 8 mm f/3.5 fish eye lens I put on the larger 11-22 mm f/2.8-3.5 WA zoom lens. If you shoot with Olympus you know these lenses and how different they are in size. Both lenses are great underwater but they require different port bodies. I had my DIY neoprene port cover on and couldn’t see why the port body wasn’t engaging with the port locks. I kept rocking and rotating the dome trying to get it to seat.
    To make a long violin solo short, I ground up the inside of the dome port on the knurled lens filter, making an ugly round mark. Ouch! I felt awful and awful dumb at the same time. Please don’t try to cheer me up by saying, “Duh, you should ‘a known better”, ‘cause that won’t make me feel any better. L LOL, I know I deserve it anyway. J
    So Ikelite is being very helpful, as always. The acrylic dome can be replaced in my existing dome body and shade without having to buy the whole Dome Assembly new. It’ll cost me about $150 instead of $400. Gee, I feel a little better already.
    I thought about this polishing method but it would be really hard for me to do this evenly on the inside of the dome. My hands are too big to fit inside and if I didn't polish the whole surface evenly the dome would have anomalies in the surface that would show up as distortion.
  19. I can change only the dome for 80 euro without replacing the entire port. Nevertheless I want to try. :)
