ULCS Releases Three Underwater Camera Accessories
Oxnard, California – February 17, 2025 – Ultralight Camera Solutions (ULCS) has released three new accessories designed to solve recurring challenges in underwater photography: the Camera Dome Weight Trim Kit, the Stabilizing Plate for Video and Still Photography, and the AC-AQD04 Quick-Release Adapter.
All three products were developed in direct response to requests from dealers and photographers who identified specific gaps in the underwater camera accessory market.
"We had dealers asking for these solutions," says Ken Kollwitz, Owner of ULCS. "These products exist because people kept running into the same problems, and there weren't good options available, or the existing options had significant drawbacks."
Camera Dome Weight Trim Kit: Adjustable Trim for Any Dome Port
ultralight CTK-DWTK dome weight trim kit1
The Camera Dome Weight Trim Kit addresses a fundamental challenge in underwater photography: achieving proper balance when using dome ports of different sizes and materials.
Acrylic dome ports create upward buoyancy, causing the front of the camera housing to rise underwater. Glass dome ports, particularly larger ones, add significant weight to the front of the housing. Both conditions affect a photographer's ability to maintain proper trim and control.
The ULCS kit mounts to the bottom of a camera housing and allows photographers to add adjustable weight where needed. The design accommodates different dome sizes and materials without damaging the protective rubber pad on the camera housing base, a problem that occurs with similar products from other manufacturers.
"Only one other brand offers a comparable solution, but it destroys the rubber pad on the bottom of their housings," Kollwitz explains. "We wanted to give photographers using different camera systems an option that works without causing damage."
The adjustable design allows photographers to customize the weight configuration for their specific dome port setup. Price: $129.95 USD.
Stabilizing Plate: Keeping Camera Systems Steady During Deployment
ultralight TPK-CSP short tripod staiblizer plate with olympus camera2
The Stabilizing Plate for Video and Still Photography provides stability for camera systems during staging and deployment, particularly on boats in rough conditions.
Heavily rigged underwater camera systems, with multiple strobes, arms, and accessories attached, tend to tilt and rock when placed on deck, increasing the risk of equipment damage and complicating pre-dive preparation.
Kollwitz identified the need for this product after observing the challenge repeatedly in the field. While other manufacturers offer similar stabilizing solutions, the ULCS plate is designed to be more universal in application and priced lower than competing products. The plate works with both video and still photography configurations and accommodates a range of camera housing sizes. Price: $177.95.
AC-AQD04 Quick-Release Adapter: Simplified Equipment Changes
The AC-AQD04 is a 4-inch quick-disconnect arm designed for fast, one-handed attachment of underwater lights, strobes, snoots, and other equipment.
for strobes, lights, and snoots
The adapter features a push-button release mechanism and compact design that streamlines underwater photo and video setups. Built with fewer moving parts than competing quick-release systems, it can be operated with one hand and is fully serviceable for field maintenance and repair. "There are other brands making similar products, but ours has fewer moving parts, can be used with one hand, and photographers can service it themselves," says Kollwitz. "We also plan to use this as a starting point for other quick-disconnect products."
While designed primarily for underwater photography, the AC-AQD04's simple, reliable mechanism makes it potentially suitable for applications beyond diving. ULCS has provided samples to professionals in the cinema industry for evaluation. Price: $44.95.
Field-Tested by Underwater Photography Professionals Andrea Michelutti, underwater photographer and ULCS Brand Ambassador, has been testing the new accessories in real-world shooting conditions to validate their performance and functionality.
All three products are now available through authorized ULCS dealers and at ulcs.com.
User Feedback
Recommended Comments
There are no comments to display.
