Jump to content
Featured Replies
Hi eveyone.
one of the o-rings on my Nauticam housing broke - can anyone share which size o-ring is required?
Also - I'm assuming I'm doing something wrong here - any tips on how not to damage the o-rings of any ball mounts?
Matan.
Edited by Davide DB
Appropriate title
  • Author
1 hour ago, Chris Ross said:
To clarify is this the main o-ring or the o-ring on one of the balls mounts?   I've found the o-rings on the balls very durable my previous housing they lasted 6 years so far.
main o-ring break would flood the housing 🙂
it's the ball mounts - once of them just broke - this is a used housing so nothing new here, just wanted to make sure I'm not doing anything that damages them. I occasionally put some silicon grease on them as well.
Matan.
Yes I'm aware of flooding it could also break being installed.
You need to be a little careful with o-rings and lubricant.  The Nauticam o-rings are silicone I believe and if you apply actual silicone grease to them it can soften them.  The Nauticam lube is a universal lube for o-rings, a generic silicone grease will damage the Nauticam o-rings.
As I mentioned the Nauticam ones are very long lasting and I never did anything other than soak the whole housing after a dive, never added any type of lube.   I don't believe the o-rings need lube as their function to grip.  I recall someone mentioned the spec for the o-rings on here a while back but I don't remember the exact dimensions.  Nauticam of course sell theirs but they are expensive.
  • Author
Thanks, I'll just source new Nauticam ones and stop the lubing thingy.
(yeah they are expensive but a one time payment for them every few years is still cheap - my CCR costs more annually 😄 ).
Matan.
Matan.
Are you looking at the right o-rings? $16 USD for a pack of 10 (Backscatter, Bluewater Photo, etc) sounds like the cheapest purchase related to this hobby you might ever make 😛
Still very expensive thought
10 orings of that type in an hardware store don't add up to one dollar.
I have never understood why manufacturers of various types of diving equipment continue to want to make money on o-rings.
A set of o-rings from my previous rebreather from the manufacturer: 100 €. At the hardware store 10 €.
Matan.
I just checked a few of my Nauticam arms (with balls) and my ULCS arms (with balls). I did find one Nauticam O-ring (on a ball) with a signifiant gouge in it - that one will likely eventually break. The ULCS O-rings feel a little more "robust" (defintiely less soft).
A gouge could easily turn into a snapped )-ring given enough friction and movement.
But they're fancy blue o-rings!
2-209 o-rings in buna are like 10 cents and in silicone are like 25 cents. I like softer o-rings for positional stability and change them once a year (when I remember). The only exception to the size is the XIT 404 versions, they use a different size (and different sizes for different XIT balls
bill
Important Information
