Jump to content
Featured Replies
Inspired by the recent thread on essential spares, I went looking for a new Olympus FL-LM3 flash since I have had two failures in the past and I am now located a long way from any supplier. I found that it is discontinued, as is the FL-LM2 used by other model cameras, and not available from any of the usual online retailers.  I was able to find units on Amazon Japan and Amazon Global UK that could be shipped, so that is solved for now.  If you are an Olympus user without a spare, it would be well worth considering picking one up sooner rather than later. Maybe physical stores have a few units laying around, if any are close to you.  Otherwise, it will eventually be necessary to upgrade to an electronic trigger.
  • 1 month later...
Uppppsss thanks for informing. Another option is to use the Nauticam Mini Flash Trigger (#26306), but it's $300, very very expensive.
https://www.nauticam.com/products/mini-flash-trigger-for-olympus-compatible-with-na-em5ii-em1-em1ii
Another options is....
O-TURTLE 2 SMART RC TTL trigger for Panasonic and Olympus systems
https://www.trt-electronics.com/shop/o-turtle-2-smart-ttl-trigger/35/
Edited by turandot
Add O-TURTLE 2 option
Important Information
