Help with Retra Burst Shooting
Featured Replies
I have switched over to the Nikon Z8 and will be on another Black Water trip soon.
In an ideal world I would want to have my Retra Pro X strobes burst-shoot a couple of images. But are they capable of it ?
(I know they are not super at it due to the AA batteries)
I have just tried it and only the first image gets light, even on the lowest power setting.
Am I making some basic mistrake or is this just not possible with the Retra`s ?
Specs:
Nikon Z8
Nauticam housing with Nauticam LED Flashtrigger
Retra Pro X with battery booster/supercharger
I would have thought you’d get 2-3 shots - I usually do but have never really tried seriously long bursts - but of course depends on your camera settings: ISO, aperture, Manual/TTL etc. What are you trying to do?
  • Author
Thanks Tim. That`s what I expected as well. I am trying typical "Black Water" setttings with Manual Strobe 1/200, F29 and ISO 400 and would love to get 2-3 shots per burst..
  • Author
1 hour ago, Chris Ross said:
Need more details of what you are doing, what trigger, manual or TTL, are you using the booster, how many frames/sec you are trying etc?
Thanks Chris, as stated in first post:
Nikon Z8
I was attempting burst shooting the Z8 with 10 frames/second, Manual Strobe/no TTL.
To be sure I tried the strobes with booster on lowest power, still only the first shot got light.
f29 is a pretty small aperture which lets in precious little light (and must lead to considerable image softness too). And 1/200 shutter speed is quite fast. Could you not use, say, f11 and 1/60? I doubt though you’re ever going to be able to shoot 10 frames a second with any strobe.
Nikon Z8
There's something going on there, at minimum power it should fire off a few bursts before needing to recharge, regardless of aperture you are using. The aperture is a separate problem as it won't burst on min power . A couple of things to try:
  • Try progressively reducing frames/sec
  • See if the camera will allow setting second curtain sync, then do a test shot in a darkened room with the shutter speed around 1 second. This is a handy way to check if a pre-flash is firing, the pre-flash fires first and the main flash at the end of the exposure. It just allows you to see both pulses. I know it "shouldn't" but worth checking.
  • What batteries are you using - eneloop or eneloop pro is generally recommended.
  • How old is your flash trigger - it may have some issues with the Z8 as it has no mechanical shutter??
  • Try triggering you strobes with a Nikon speedlight as trigger if you have one, test shooting into a mirror so you can see if the strobe fired easily
  • If you still have your OM-1 see if burst shooting works there
@Aliens From The Deep
I was shooting using my Nikon Z8 in Anilao on blackwater dives ~4 weeks ago, 3-4 shots at a burst at times., with Retra strobes.
After shooting blackwater on the Z8, I'm not sure I would ever shoot at f29 (at 1/200). I'm usually at 1/125 (at the fastest) and often even slower (1/80 if it's not fast moving, etc.) unless I'm shooting HSS. And for shooting anything that's partly translucent I'm usually down around at f10 or f11. Only shooting very reflective subjects (like silvery fish) would I be at a smaller aperture.
Edited by OneYellowTang
10fps are done at easy with Marelux strobes at full power in their ultra-fast MTL mode. But you have to use them in MTL and with fibre optic cable (not Lumilink) to squeeze out the maximum repetitive performance.
They are currently leading the fast recycle time without blackout frame technology in underwater strobes.
Here on the forum is a pretty dismal measurement of mx strobe strength by dreifish though - something I could not agree to when comparing it 1to1 to my Backscatter HF-1. I can only assume the Apollo tested by Dreifish must have been a monday model or malfunctioning pre-production unit.
On any AA eneloop powered strobe you will struggle to get fast recycle times near 8 - 12fps. You need a strobe which utilizes 18650 or 21700 high current discharge cells. Otherwise the capacitors cannot fill back up at the speed you desire.
I just recalled that Henley Spiers has shown the RETRA fast recycle time performance in his review:
https://www.divephotoguide.com/underwater-photography-special-features/article/first-impressions-marelux-apollo-iii-2-0-strobe
It‘s showing a lot of struggle at 7fps.
The Marelux strobe smokes the oneUW and RETRA in this discipline.
Edited by Adventurer
I'll try this out later with my Retra Pro Max strobes. I seem to remember struggling with burst shooting above 1/2 power but under that it was okay.
This is clearly something else, on minimum power they should allow for rapid firing, something is preventing this. The suggestions I posted above are test for potential issues. My first inclination is a problem with the trigger, online I see various issues reported with the Z8 and trying to sync with manual flashes.
Does Retra have a pre-flash learning mode? You want that to be OFF. If there is no way to force it off, it could be a trigger problem. I've reported and had issues with the Nauticam trigger before, but with Backscatter strobes. In my case Backscatter was able to get Nauticam to send me a replacement trigger with modified firmware to address the problem.
Contact Retra directly and discuss the Nauticam manual trigger with them.
Have you tried frame rates below 10 fps and above single shot mode ?
That way you can rule out the general issue coming from camera or trigger.
As you can see in the Henley Spiers strobe comparison photos: at 7 fps already the 2nd frame gets pretty dark and the RETRA is struggling at more open apertures.
  • Author
Thankls everyone for your input ! I`ll run some more tests now and will in doubt contatc directly.
Having said that: I am actually tempted to get the Marelux Apollos just for this unique feature...
Burst mode shooting is not a unique feature, most modern strobes should support it. The models using Lithium Ion batteries will be better suited for it however. Backscatter HF-1, the new Atom, Marelux, Kraken, and the Retra Maxi (if they ever ship it) would all be good options.
But you could still have a trigger problem. I had to address this even with a capable strobe.
  • 1 month later...
  • Author
Hi everyone,
just wanted to post a quick update and close the loop on this thread.
I’ve now been in direct contact with Retra support and sent them detailed test shots and settings. They tested the Maxi strobe under exactly the same conditions I described (3 fps, low power) and confirmed that:
➡️ The strobes themselves are not the cause of the black frames.
➡️ In their tests there were no dark frames and no relevant drop in output across the burst.
This strongly points to a sync / trigger issue, not a strobe performance issue.
That fits very well with what Dave Hicks already suspected earlier in this thread — especially regarding the Nauticam LED trigger. Dave had similar problems in the past with other strobes and mentioned firmware-related trigger behavior causing missed sync in burst shooting.
Retra’s recommendation now is to test with a standard manual trigger from TRT-Electronics, which should eliminate any pre-flash / timing issues and give reliable sync for burst mode.
My only small dilemma:
I’ve just bought the Nauticam housing with the LED trigger brand new, so replacing it means both additional cost and removing a factory-installed trigger — not something I was initially planning. Before doing that, I’ll reach out to Nauticam to see if they are aware of this issue and whether a firmware update or alternative solution exists on their side.
Bottom line so far:
Retra strobes (including Maxi) are fully capable of burst shooting.
⚠️ In my case, the limiting factor appears to be the trigger system, not the strobes.
Huge thanks to everyone here for the input — especially Chris, Dave, Tim and others who helped point in the right direction. I’ll report back once I’ve tested with a different trigger or heard back from Nauticam.
Best,
Marco
@aliensfromthedeep
On 1/9/2026 at 2:15 AM, Aliens From The Deep said:
Hi everyone,
Bottom line so far:
Best,
Marco
@aliensfromthedeep
Thanks for the update. I suspect it is something similar to what i see with e-shutter on my OM-1 . In focus stacking I do on land with an Olympus flash - the flash fires very rapidly on low power. I trialed doing a short stack UW, using the mini flash on manual at 1/64 power for triggering. The little strobe can fire rapidly at such low power but it was like it was waiting to confirm the flash was ready again before firing.
The standard way of getting around this is to make use of the X-sync on the camera, which it basically a mechanical contact built into the shutter - the camera doesn't recognise there is a flash attached and fires every time the contact has closed as long as it has charge.
Did a little searching to find this, seems the problem is by design from Nikon:
nikon-z8-focus-shift-and-flash-issue.343
  • Author
Hey Chris,
thanks for your input, that is super interesting and I would love to see more. Alas the link you posted is only a red X here and I can`t see it.
Meanwhile Nauticam have replied, but were not helpful so far to understand what is not working. They basically said "it should be working." My UW dealer (Pan Ocean Photo) however has graciously offered to lend me a TRT Electronics trigger (that was also suggested by Retra) which should arrive tomorrow. That way I should be able to see if the problem lies with the Nauticam LED trigger or with the Z8.
  • Author
Thanks, Chris.
I’ve already deactivated First-frame exposure lock, but unfortunately that didn’t change anything.
I have, however, now been able to clearly identify where the problem lies. Using a different LED trigger (from TRT Electronics), burst shooting between the Nikon Z8 and the Retra Maxis works flawlessly (tested at half power or below).
This effectively isolates the issue to the Nauticam LED trigger. I had already contacted Nauticam a couple of weeks ago, but at the time they weren’t able to provide any helpful solution. Now that the root cause is clear, I’ve reached out to them again to explain how frustrating it is to run into this issue with a brand-new housing. I am not keen to spend any more money on another LED trigger and also not on having to rip out the pre-installed Nauticam one.
I’m very curious to see how they respond.
Edited by Aliens From The Deep
56 minutes ago, Aliens From The Deep said:
Thanks, Chris.
Sounds like the problem I had. In my case Backscatter did all the talking to Nauticam and had them send me a new trigger.
Important Information
