Jump to content
Help..not sure whats wrong..
Featured Replies
Hello,
Way back in 2011 I bought a Canon 7D and ikelite housing (80mm lens for macro), and sea and sea strobe via TTL sync cord. Everything worked well. Fast forward to 2023, I dug everything out of the case as I booked a dive trip, and I updated the firmware on the camera, erasing all the settings I had previously (dumb move on my part). Problem I was having on the first couple of dives was getting a solid black, horizontal line in the bottom 1/3 of the photo. In conversation with another diver with a camera he suggested I needed to go from 1st to second curtain in my settings. Between the 1st and second dives I pulled the camera out of the housing to make the changes and neglected to turn off the strobe. When I was reinserting the camera into the housing I hit the shutter button and the strobe fired full blast as the protective cover was over the front port. This fried the strobe. So I was never able to test if this solved the issue. Has anyone experienced a similar issue? Do you think that was the issue? He described it as the mirror still being in the way (on 1st curtain).
Thank you in advance!
T
Edited by Titanite
additional detail
What was your shutter speed? If you set the shutter faster than the sync speed of the camera, you get a partly black vertical band. A quick search says the max sync (shutter) speed for the Canon 7D is 1/250th of a second. Anything faster than that will create a black curtain.
  • Author
I dont remember what shutter speed I had. I was wondering if this was an issue after losing all my previous settings and knowing myself, I was probably "trying a bunch of different things to see if I could get rid of the black horizontal line", then the strobe cratered before I learned anything.
Edited by Titanite
You should be able to look at the meta data in an image file to see the shutter speeds and other settings.
It's not going to be first vs second curtain sync, that just moves the timing of the pulse from the beginning to the end of the exposure. I don't know of any explanation apart from shooting at higher than the maximum sync speed. Shooting macro you would notice any other issues like dark background water as the exposure is entirely from the strobe. Look at the EXIF data in your original files, what ever you use to process the images will report the shutter speed used. More than likely you could review the images in camera and get it to report the aperture/shutter/ISO used.
Important Information
