Olympus TG6 Question about wide angle Lens
Featured Replies
Why do you need to tell the TG series cameras that you are using a FCON T01 or a FCON T02 Lens. What does the camera do or not do if you don't ?
I got the answer from AI, did not verify it, but makes a lot of sense, hope it helps:
You need to tell your Olympus/OM System TG-series camera (TG-6, TG-7, etc.) that you're using an **FCON-T01** or **FCON-T02** fisheye converter lens in the menu because the camera uses this setting to apply the correct **optical corrections and zoom behavior** for that specific lens.
### Key point from Olympus documentation:
> "When using the FCON-T02, change to settings appropriate for shooting with the converter: In Live Control's **Accessory Settings → Converter Name (Conversion Lens)**, select **[FCON-T02]**" [2]
### What happens if you don't set it:
The biggest practical issue is **vignetting** (dark/black corners around your image) because the camera doesn't apply the distortion/vignetting correction specific to that fisheye lens [3]. You'll still get the fisheye effect mechanically, but the image quality degrades significantly at the edges.
  • Author
I took my TG 6 with the FCON 2 Lens on when I went snorkeling. I told the camera I was using the FCON Lens II. When the camera got below water the camera would zoom in to cover the full frame. When I tried to go to the full 180 circle mode it would not ?
  • 2 weeks later...
Note that, according to Ikelite, the menu item for accessories should not be set to FCON-02 if it is being used because it will stop a flash from firing.
