Sony 16-35 GMII AND WACP-1
Featured Replies
Actually the 16-35 GMII is on the WACP-1/1B port chart, but it only works between 28 and 35mm zoom settings and will give you about the equivalent of a 12-16mm zoom in rectilinear terms based upon the horizontal field of view. This is not a wide zoom range and you could be left wanting more reach if the sharks are at all shy.
If you want to have a zoom behind the WACP, maybe look at the Tamron 28-75 which is on the port charts if you want to be using a lens with better quality than the Sony 28-60. That lens is usable from 28-45 and will get you out to about equivalent to a 30mm lens. I expect it bumps into the back of the WACP beyond about 45mm. I seem to recall some discussion on this lens on the forums.
Port Chart:
https://drive.google.com/file/d/1oPHvkUhf-_rRNqZWTnuIHVa_xnXhSkvI/view
