Nauticam NA-A7c housing
Started by Phil Rudin ·
  • 124Posts
  • 124Replies
  1. Just remember that you need to adhere to the "lowest" depth rating of all components in the system. I believe most Nauticam housing are rated to 100m unless you get some special seals put in them. Also, some of the larger domes are depth rated to 60m. One of the reasons I got the N85 7" acrylic dome instead of the 180mm glass dome is the 60m depth rating on the latter.
  2. If the WWL-1B is rated to 150m, and the foam buoyancy collar is only rated to 50m, then I wonder why the WWL-1 is only rated to 100m? It must be different than the WWL-1B in more ways than just not having a metal buoyancy collar...
    Not that it's likely to matter to me... If I ever get to the point of diving deeper than 100m, I doubt I'll do it enough to get to the point of feeling comfortable enough to add a camera rig to all the other stuff I would have to be taking... I might do a few dives deeper than 100m eventually, but probably never while also carrying a camera.
  3. If you have classic alu arms like ULCS or Nauticam you could just buy a kit like this:
    https://www.easydive.it/en/arms-and-accessories/floating-arms-and-items/floating-rings-kit-500-g.217.html
    The hole is 25mm which is enough for most commons arms.
    After the Stix bad experience, I bought a small pane of the same material and I cut it by myself copying the Stix design. While now I use carbon fiber arms I used them for years and they are still very handy for special rigs...
    Edited by Davide DB
    "Stix bad experience"?
    What happened, Davide?
  5. The new WWL-1B on the NA-A7C's big brother.
    Quite likely some small change will allow them to rate it deeper.  It depends on what the limiting component is - it's probably not the glass dome if I were to guess as the optics are reported to be the same- perhaps the collar adds strength to structure.  In terms of mechanical design you are looking at 1500 kPa pressure at 150m, it's really not that high. Though being external pressure that does add some complications.
    I am not a technical diver and use regular floats, designed for fishermen nets, for buoancy of the housing from the company below (similar depth rating as the Stix floats, but cost almost nothing). They have  also special floats for deep-sea nets at low cost in their program, rated between 400m and 1800m, depending on material. The material can be cutted and holes can be drilled into it. Maybe worth to consider (unfortunately the site is only in German)?:
    https://engelnetze.com/tiefseeschwimmer
    Wolfgang
    Wolfgang
    Yes, plenty of DIY solutions out there
  9. Thanks for all the helps here guys! I bought the housing with wet lens and 2 Inon z330 strobes with Nauticam carbon fiber float (not sure if I need the float but Reef photo recommended them).
    How do you guys cary the whole rig for travel? Any case that can fit the strobes, arms, housing and WWL-1B, CMC1 lenses do you recommend to protect these gears for check in?
    Also how do you guys normally carry it on the boat? Just assemble before and drag the housing up?
    On getting to the water, do you leave the rig with someone and ask them to pass you the rig after getting in the water?
    Sorry for a lot of noob questions.
    Hi,
    Congrats on the purchase - maybe it's best if you create a separate post as these questions are not really related on the housing thread itself
    I just carry my gear in my carry on if it fits, otherwise i'll put the whole thing in the suitcase. Never had any issue.
    Assemble everything before being on the boat.
    As for the float, you need to do buoyancy check on your equipment (bathtub and electronic scale should work).
    I don't have one myself, but I've seen a few people use this bag on day boats, and it looked like a very good solution.
    Sorry, this is going way off the original topic now:
    I've just bought one of those and used it twice so far. Pricey but, yep, very high quality indeed. I've tried it so far with:
    Subal ND500 housing + Macro port + 2x Retra Strobes + Snoot + 2x 5" arms with Stix + 2x 8" arms with Stix (a squeeze but doable)
    Subal ND500 housing + 100m port + 2x Retra Strobes + 2x 8" arms with Stix + 2x 12" terms with Stix  (Fits - see photo)
    Zips look good and should be pretty salt proof. The handles make it easy to carry. I've not tried the shoulder strap yet but it looks very solid. The thing I like about it especially, as well as the protection it offers, is the personal rinse tank. It's marketed as leak proof - unlike the various cheap cool bags I've bought over the years which, in total, probably cost what the Cinebags does. (buy cheap, buy twice)
    I got mine from Bluewater.
    Edited by TimG
    And then people complain that Keldans are expensive :D
    $159 is as much as a large Nauticam float arm; really not that much in the great scheme of things. A single Keldan 8X is over $2000.
    Agreed, but Davide is shopping in Europe and the Cinebags are somewhat pricey there. I wouldn't buy one whilst I was living in Amsterdam. It's a different matter when covered by the US market and pricing.
    A lot depends on the type of trips you are doing.  Going to Thailand on work trips I sometimes add on a dive day trip.  On those I take the camera onboard in a spinner style carry on bag (meets carry-on regulations ) that I added some padding and dividers to - same bag I take it on the plane with.  In the hotel remove the dividers assemble the rig and line it with a hotel towel or two.  Wrap it up in the towel between dives after rinsing.
    The strobes are assembled to arms but only attached to the housing onboard.
    It looks to be about the size of my EM-1 MkII rig and I fit that with 170mm dome, lens, camera and strobes/cables/batteries etc in the spinner bag and carry it on the plane.  the arms and clamps are wrapped up and padded in my dive gear bag.  Is use the divider set out of one of my photo backpacks and I lined the bag with fabric covered closed cell foam strips and added velcro to hold the dividers in place.
    for local day trips I carry it on the dive boat from my car in a small tub and have an old (damp) towel to wrap around it to keep it from drying out till I get home and soak it.
    Edited by ChrisRoss
    A while back I saw it in a store and it was over $200.
    Really too much, whatever features it may have
    I think it is not a matter of seal. At least with Aquatica it is only a matter of changing the springs on the push buttons.
    You need to have springs that do not allow the buttons to get pressed in only by the external pressure.
    Of course the buttons will need more effort to be pressured on the surface and at shallow deeps.
    Edited by pbalves — To add some more explanation
