Sealife SportDiver Ultra versus DiveVolk Seatouch 4 MAX - Who's the King of the Smartphone Housings?
There's absolutely no doubt that smartphones are an incredible, cost-effective way to get started in underwater photography.  There’s nothing more exciting than being able to view and upload your images to social media as soon as you finish your dive, on a safety-stop or even whilst snorkelling .
Did I say started?  Let me take that back, as it is so easy to get addicted to using one, that you may just want to ditch your usual camera in favour of it.  Of course there are advantages and disadvantages of choosing a smartphone over a camera, but for ease-of-use and for a complete beginner, they are a total game changer.
So with so many different housings available for your phone, so I thought I’d share some views on two of the most popular housings Divevolk versus Sealife.  I’ll cover other popular housings like those made by Kraken and Oceanic soon.
Sealife SportDiver Ultra Smartphone Housing - Depth Rating 40 metres/130 ft - $349
Both compact and sturdy (ideal for where I am in the UK), this housing is how I fell in love with shooting with my own iPhone and has been voted as Scubalab Tester’s Choice for 2024.
The SportDiver Ultra housing is a heavy duty housing (808 grams) and is made of polycarbonate, stainless steel, aluminium and optical grade glass.  It will take all iPhones from iPhone 8 through to 15 Pro Max as well as most Android models.  Just made sure that you review the Sportdiver compatibility and fit guide.  It has it’s own SportDiver App which connects to your phone through Bluetooth Low Energy 5 wireless technology, using the phone camera’s technology which is native to each camera.  The housing itself is powered by two AAA batteries which last over 50 hours of continuous use.  It is almost neutrally buoyant and Sealife also make a Gear Retractor which is a stainless steel snap clip which attaches to your BCD to keep it extra safe when it’s not in use.
Let’s look at what the Sport Diver housing offers:-
  • It has a generous shutter button at the top of the housing and four easy-to-use buttons on the back, making access to the different settings easy to use, especially when you are shooting in colder water with gloves.
  • It has the ability to change the ISO, Exposure Value, White Balance, Adjust Zoom, Tint, Lens Selection plus the ability to shoot in both JPEG and RAW, making it ideal if heavy editing is your passion afterwards.  Video stabilisation is also available on certain phone models.
  • It is equipped with dual Leak Alarms which include a moisture alarm and a vacuum pressure alarm, alerting the user with on-screen warnings.  This alarm will even notify you on the surface if it detects even a drop of water in it and trust me, you will definitely hear it!
  • It also as a Vacuum System with a pump to create more security for your system.
  • It has a very sturdy build which is suited for more challenging conditions.  It also has a sturdy holding spring and rubber grip tabs which securely hold the smartphone in place and add shock-protection.
  • Automatically comes with a removable red filter (with a safety tether) to restore natural colours in tropical water and a sturdy travel case so you can get started immediately.  Both magenta and yellow filters are also available.
  • Interior fogging and condensation are prevented by using “Moisture Muncher” capsules.
  • Looking to get creative?  A 52 & 67 mm thread adapter is available for both macro and wide angle lenses.  At present there is just one wide angle dome lens available (which is positively buoyant and has a safety lanyard) increasing the phone len’s field-of-view by 40%.
  • The housing features seven 1/4-20 tripod mounts to mount any light or light tray with standard tripod threads such as Sealife’s range of Sea Dragon underwater photo/video lights.
  • Your phone can be taken out from the back door to charge.
  • The Playback Mode shows full size photos and videos with a vertical thumbnail strip, making it easy to locate your images.  Files are also saved automatically to your phone’s camera roll.
The downsides are:
  • It needs to be used with the Sealife App for it to work, so all of the functions aren’t accessible such as the highest quality video setting available in newer iPhones.  Some of your phone settings may not be available through the App, so it’s important to check both the App and Play store for SportDiver App updates.
  • A manual vacuum pump (included in the set-up) is needed.
You can read more about all the different options available via Sealife's website here:-
https://www.sealife-cameras.com/product/sportdiver-ultra-smartphone-housing/
DIVEVOLK - Seatouch 4 MAX - Depth Rating 60 metres/196 feet - $239
It’s safe to say that Divevolk have taken the smartphone underwater photography market by storm by introducing the first ever fully integrated touch screen which makes all of your favourite apps and functions easily accessible underwater at an affordable price as well as offering the widest range of add-on lenses.  Trust me, you’ll be spoilt for choice as to which one to start with!  You can even communicate with your dive buddy underwater via writing apps, make an emergency call at the surface if needed as well as record GPS co-ordinates.   You can even have your own Fish ID Guide with you whilst you’re diving, making identification an absolute breeze.
The Divevolk housing is much lighter (375 gms), made of plastic and stainless steel, supporting any smartphone.  Simply pop your phone in a customised adapter and slide it into the housing through a narrow opening and close the housing door which has a built-in compression ring.  You’re then all good to go.
So let’s look at what it offers the user:-
  • All functions are easily accessible via the touchscreen, even with wetsuit gloves.  And yes, the touchscreen is tougher than it looks with a special 3-layer sealing gasket to keep the housing secure.  For those colder water temperatures, this innovative company have even invented a special finger cot to pop on over your drysuit glove.
  • It may not have a vacuum pump but it does have a pressure balance system to keep it safe from leaks.
  • If film making is your passion, this housing is the only one to give you a choice to shoot at the highest resolution that your phone can offer.
  • It can also be used as an external monitor for your d-SLR or Mirrorless camera.  It has developed a wi-fi transmitter which can be placed in-between your housing and your phone where the signal is transferred.  Divevolk is the only manufacturer to offer this option.
  • Incredible underwater content can easily be achieved using the variety of add-on lenses which Divevolk offer.  From both red and magenta filters to a 15 + close-up lens, plus both wide angle and dome lens options make this an unbeatable system to get started with and grow your creativity.
The downsides are:
  • Take added care to protect the membrane when travelling.
  • If you are using a tray with two handles, be aware that you will need to remove the housing from the tray first before being able to remove your phone from it’s side door.  Alternatively you can purchase Divevolk’s own tray which allows it to swivel and you can then remove it easily.
DIVEVOLK Platinum - Depth Rating 262 ft/80 metres - $399
This recently launched housing has been specifically built for newer and thicker smartphones and has a much more sturdy finish.  It has the following upgrades:-
  • It is made of aluminium alloy which makes the casing more resistant to corrosion.  It also makes it look very stylish.
  • An upgraded sealing system, making the housing feel more resistant to leaks.
  • The touchscreen is easier to operate with gloves and offers a smoother response than previous models.
  • It comes with an integrated expansion clamp which attaches directly to the case with 1/4 inch threaded holes at the bottom.
For more information on Divevolk, visit their website here:-
https://www.divevolkdiving.com/en-gb/collections/seatouch-4-max-kit
Finally, don’t forget to utilise a wireless charger if possible to reduce the risk of moisture entering your housing.  Regardless of which one you choose, you sure are guaranteed a whole new underwater photography world opening up in front of you.
I’ve absolutely loved shooting with my phone the past couple of years for ease-of-use and the simplicity and how I can create my content for social media in a nano-second after getting out of the water.
I look forward to hearing your thoughts, experiences and seeing your images 🙂
Maria
User Feedback
Recommended Comments
fruehaufsteher2
Members
Thanks for the article.
Did you personally ever try out the:
"It can also be used as an external monitor for your d-SLR or Mirrorless camera." for the divefolk?
I don't remember any direct experiences... but that would be interesting.
Maria Munn
Members
Hi @fruehaufsteher2
Thanks for the thanks.  It would be really interesting to hear from someone who has.  I only shoot with a compact camera, phone or go pro, so sadly not.  I'll reach out to see if I can find someone who uses it and see if they can do a review.
Have a great evening!
Maria Munn
Members
Happy Sunday @fruehaufsteher2 🙂
Just to let you know that I have been in touch with Divevolk on Friday night and they are going to reach out to find some more material on this to help.
Have a great day!
Maria
Nando Diver
Members
(edited)
@Maria Munn
There´s any underwater case for the iPhone ( with touchscreen support )  that let us fit some SSD for external storage.. ??
Because to get 4K60 with ProRes 422 HQ its required external SSD
ProRes 422 HQ models 256 GB, 512 GB and 1 TB
iphone 15pro 4K60 (only with external ssd minimal 220MB  )
iphone 15pro Max 4K60  (only with external ssd Minimal 220MB  )
iphone 16pro 4K120  (only with external ssd Minimal 440MB  )
iphone 16pro Max 4K120  (only with external ssd Minimal 440MB  )
this article cover all the supported models
https://www.idownloadblog.com/2023/09/28/how-to-record-prores-video-iphone/
Edited by Nando Diver
Hi Buddies,
Thanks for article @Maria Munn
Like for me, Divevolk it's the best I have not tried the Sealife because his own app and the reviews are really bad!! On other side(Divevolk) I can use phone cam app or in my case (99% use for video) I use it Blackmagic Camera app(false color, white balance adjust, focus peaking, zebra, timecode, rack focus, .... 'almost' a cine camera!!) and if the dive it's boring(it's not!!) you can play chess or solitaire:classic_laugh::classic_tongue:!! Better thing, if you arrive to the surface, you can use the phone in case of lost or emergency!!
Last week, I sent a message to Divevolk, but so far they haven't responded!! I really talked about this subject you talk about here @Nando Diver
To do this you would to have a completely new underwater housing, with the opening on the opposite side (USB), for SSD disks, I found these two very small ones, the Lexar® SL500 Portable SSD and the Kingstone XS2000 External SSD! The photo with disk that you posted will not work, as it will still have the waterproof case on top and the ultra wide angle lens will not work, as it will appear in the field view! The solution was to take these discs and try to get the manufacturer to change their connection (but this would still be much more complicated!!) so these two discs could already be done, if there was a desire from Divevolk!!
So @Maria Munn can you help us and talk about this subject(iPhone with SSD) with Divevolk?! With this system, almost I can do it a very profissional videos because of ProRes...
(edited)
Like this @Nando Diver
And if is the Max better!!
Edited by Cutbacks_Ericeira
Divevolk needs to do it better lens, I tested a Macro and Wide , but not using now because a lost of quality and sharpeness, if they change this, it will be a leader for years!!
Nando Diver
Members
True, their lens are acrylic, quality is very low.
Regarding the SSD + Divevolk case, theres a model  LEXAR GO and would fit inside the divevolk + iPhone 16 pro, but   is not recommended by divevolk to use underwater, this is what they reply to me.
Quote
I apologize, but we do not recommend using the Lexar Go SSD inside the Divevolk Seatouch Max Plus. The SSD would create a large empty space behind it, and underwater pressure could potentially damage your phone.
If you are running out of storage on your phone, we suggest uploading your photos and videos to iCloud instead.
Small ssd are good options to save large video files while on vacations.
Regarding the Iphone 16 pro or pro MAX, the blackmagic camera app will film up to 4K 120fps.
(edited)
@Nando Diver The space is already there, so it doesn't make much sense!! A ssd it's a only way to record ProRes! Or do they mean on the side of the screen?!  I was thinking to buy the new iPhone 16 Pro Max and the new Max Plus housing, but I could still equip the Sony better!! Almost €2500 is enough for some good things and on top of that, Seafrogs has launched a 'new' line of aluminum waterproof boxes (the same copy as Marelux - which I think are both manufactured by Nauticam as a white brand, or Seafrogs itself manufactured for Nauticam - be careful, these are assumptions) but 1/3 less expansive... Here in Europe you can buy from Aditech UW shop(Spain)
I just use Blackmagic app to record video on my iPhone 13 Pro, but ProRes it's better for color grading , it's more heavy files and there it's less compression, bigger files has more information for post-production
(edited)
On 1/23/2025 at 9:20 PM, Nando Diver said:
@Cutbacks_Ericeira it seems the seafrog uses bluetooth to control de stock camera app... the divevolk is complete touchscreen +50€
https://www.aditech-uw.com/downloads/sf-ph-01-pro-control.jpg
I was talking, how Divevolk doesn't care about evolution, I still with my mirrorless camera, I change my Seafrogs plastic to a new from same brand but in aluminiun (for I upgrade a new Iphone and Divevolk it's the same price that I go to aluminiun, yet I can record 4k 120 fps with 600Mb or use a Atomos to record 4k60fps Raw)
https://www.aditech-uw.com/es/tienda/7074-sea-frogs-sf-l-a7siii-para-sony-a7siii.html
For iPhone I will wait, yet in future someone will do it
Nando Diver
Members
(edited)
The best feature of divevolk is the ability to use full touchscreen on smartphone.
In Boot Dusseldorf 2025 they present an external bluetooth trigger/shutter, and they have a new Glass lens for macro (Diopter +18).
Divevolk focus of their products is for smartphone use.
For Mirrorless or DSLR  the Easydive they built universal Housing with lifetime warranty.
Over the years you only upgrade to any camera brand in the world and keep the housing.
I prefer dedicated houses, in this case any of them (Nauticam, Marelux, Isotta, Sea Frogs) have all the buttons on the housing, the easydive work via cable but the functions are only those that easydive has(8 pre definied buttons)!! A big difference when Seafrogs has identical prices, but with all the 22 camera buttons, with this you can adjust all thing underwater
Nando Diver
Members
(edited)
Today one of the divers in my group had the new Weefine WFH07 smart housing with iPhone 16 Pro.
Looks nice and well built, it uses dedicated DiveIT App.
It support RAW picture, 4K120fps video, HDR and ProRes
It also has built-in electric drive air pump.
But in my opinion the big selling point is the possibility to use strobes and connect optical cable to the weefine housing that match the iPhone Photo DiveIT app.
