Condensation on inside of dome port
Featured Replies
I’m currently in a shoot in South Africa and for the first three weeks, no issues. Recently though, I have been getting condensation in the inside of my glass dome port and it’s rendering footage unusable.
Any tips to avoid this? Nothing has changed, the camera and housing are assembled in the same room and sand conditions. The only slight change is a -1 degree temp change in the water.
I have a small silica gel sachet at the back of the housing.
Set up is:
Red Komodo X for n a nauticam housing
Zen 230mm glass dome
Canon 24-105
Ext 60 and 30 attached together.
Anything I can do to stop this as it’s never happened before. Air temp is 20-25 degrees, water temp 22-23.5 degrees
See if you can purge the housing before closing with dry compressed air from a tank (gently). Or one of those cans of nitrogen for blowing dust from equipment and electronics. And then close up and pull the vacuum.
Edited by Nemrod
  • Assemble and seal housing in an air conditioned room. This reduces humidity in the housing.
  • You can use a scuba tank & drying nozzle to spray extra dry air in the housing as you seal it.
  • Microwave your silica packets as they are probably saturated. A few rounds of 5 minutes at 50% power. Store in a Ziploc bag to keep the extras dry.
Edited by Dave_Hicks
It is possibly a change in weather with more humid air , there is not much temperature drop to be causing condensation. The other thing that can happen is getting a few drops of water inside the housing and these evaporate if the housing is in the sun for example, this will significantly increase the humidity inside. You can often get drops clinging to your o-rings.
Silica gel can help but it must be fresh and you probably need a good size packet with a large housing. If the air is at all humid they will saturate quickly if not sealed up.
I had condensation problems for a while, eventually traced it to a leak on one of the buttons. when i pressed it a tiny drop of water got in. Stripping down the button and cleaning the shaft cured the problem.
Had exactly the same problem several years ago: 1 slightly leaking button. The Housing was not even wet.
I had once problems with condensation on a Nauticam 140mm domeport in a cold mountain lake on a rainy day: reason was a 120N extension where screws were missing (from factory). Few droplets of water came in (maybe half or quarter of a teaspoon), not enough for the vacuum or moisture systems to react, and this caused the condensation...
