Blur Photos
Featured Replies
I have rear curtain sync and struggle to pull off any blur photos. Primarily cannot keep focus on the eye of the main subject
If you're trying to blur using flash, the key is to use a slow shutter speed, much slower than the x-sync of the flash, with enough ambient light and contrasting background items to cause the streak. It's easiest if your subject is moving in one continuous direction rather than swimming in a haphazard way, like some tiny fish like to do. You might even go as long as a second, but not so long as to overexpose the background.
The other kind of blur, is to use a wide open aperture - small numbers - which creates narrow depth of field.
Also, if your camera and lens combination is not particularly good at continuous tracking, you might consider prefocusing on a spot about the same distance as your subject and panning as the subject comes into view.
Hope this helps.
Craig
Hope this helps.
Craig
Howdy! I agree with what advice Craig here has provided and I have a bit more to offer.
For motion blur shots it is really important to understand the difference between front and rear curtain sync and when to use them.
A general rule of thumb is if the subject is moving, meaning your tracking the subject as it swims, use rear curtain sync. This will then capture the blur behind your subject and freeze your subject at the end of the exposure when the flash fires. This does not work well at all when YOU are applying the movement to the camera. As by the time the flash fires at the end of the exposure you've moved the camera which has in turn changed your composition.
When you are applying movement to your camera during the exposure you want to use Front Curtain Sync. This will freeze the subject at the start of your exposure then the blur will show up opposite the direction of camera movement. Most subjects I use this technique on are stationary so I prefer front curtain sync as it puts me in control of the blur.
Here is an example.
1/4th f16 ISO 100 - Front Curtain Sync.
Edited by LGWVPhoto
