Subtronic Batteries
Featured Replies
Hi all, I own two Subtronic Alpha 160 pro fusion, which I really love because of its power, light quality and size. for me the handicap of this flashes is its batteries, they are dedicated and I don't really like it. The main thing that I don't like about it it's the charger, only a red or green led to know if they are charged or not. Several times I have noticed issues with the charger, I connect the batterym switch the power on and after 15 minutes turns green, It feels strange, so I restart the procedure and this time  the battery is charging for 2 hours. If i don't notice I'll run out of batteries in 10 pictures the next dive, Presumibly just before you find an Orca having sex with a whale shark.
So as I was tired of the situation I planned to do on myself new battery packs that I can control the cells individually in a normal charger. Then I noticed than the original battery packs are simple as two 18650 cells connected in series, so they give 7,4 volts (nominal). So I decided that if I am going to do it I want to not charge batteies in a day during a trip, tipically 4 dives. So I made my packs with two packs of two 18650 batteries connectd in parallel, so I double de mah. resulting in this packs you can see in the pictures.
I made the design and went to a turner to make the pack with the threads and the o'ring channels, I bought the cables with the conector already welded from Subtronic and I bougt the battery holders from Aliexpress, sended the alluminum pack to anodize and I got the cable penetrators from BlueRov  which i had to modificate a little bit in order to hold 6.5 mm cable.
It's been a bit expensive, around 300 euros each plus my time and my job, but I can control every cell one by one, but everytime I go to the water I am absolutely sure they are perfectly charged, if any of the cells it's damaged i can change it for a ridicculous price comparing with a wole pack, and I can do on myself in seconds. The contra is that this battery packs are big. So now I am planning to make another packs with only to cells in serial connection, ir order to make it thinner, to use it when at home and tipically dive once or two a week.
The connector is an S4, so if Seacam uses the same voltage this would also work with them
  • 1 year later...
gran idea,pero me temo que Arturo Telle ya pensó en eso,en su web idiving ofrece una bateria propia mas pequeña y manejable a un precio muy interesante,saludos...
  • Author
Better in english, so anyone can understand. I have 4 Idiving batteries, are exactly the same than the Subtronic ones but smaller, nothing else. Subtronic sells batteries that works also as an arm (which I don't like) and they also have batteries with no balls, like the idiving ones, in order to put it in the side of the strobe in the neoprene protector. The difference between the Subtronic and the Idiving is only the size, Idiving is smaller and slightly cheaper. But both share the same issues. They need the Subtronic dedicated charger, when the cells become older you have to buy brand new batteries, 2 18650 good quality battery cells are 40 euros worth as much, the whole battery is 200 euros worth if Idiving and 250 euros if Subtronic.
My batteries are absolutely different focused. My goal is manufacture a housing for batteries that I can change the cells in seconds, so when the cells are old I swap them by new ones for a few euros, I can use normal chargers and I double the number of cells, so I can make 4 dives with no changing battery. But I recognize that if I had to do again I would make a design for only two cells.
Hola,sí,es correcto,lo siento no se escribir bien en inglés pero hoy en día todo esto se traduce automáticamente a cualquier idioma,,las baterías idiving cuestan 120E si le entregas el cable usado de subtronic y si le pides a Arturo que te las ponga de más capacidad,,por ej 3500mah no hay problema,,tu idea de poder desmontar y cambiar elementos en un minuto es buena pero todo lo que sea abrir cosas en el mar o en barcos es motivo de posible fallo,,con llevar un par de packs por flash seria suficiente para 4 inmersiones día que es lo que solemos hacer cuando viajamos,no tanto cuando buceamos en casa...tampoco me gusta nada tener un cable de corriente por ahí pero es la parte mala que tienen los subtronic 160 pro,lo demás tu bien lo sabes,son ventajas,Wolfgang Tick sigue en activo revisando subtronic pero lo malo es que ha dejado de fabricar unidades nuevas o eso entendí la ultima vez que hablé con él,...tambien dispone de packs de 9ah o más pero son muy aparatosos...,,lástima que no haya espacio dentro del flash para adaptar un pack 8.4v 4ah,,sería lo suyo pero no cabe y un pack de litio polímero sería demasiado peligroso....,hoy en dia hay celdas de 5ah un poco más gordas 21mm y de igual longitud,,tal vez con eso sería suficiente...muchas gracias por compartir tus conocimientos,esto siempre sirve de mucha ayuda...
9 minutes ago, FOTOSUB said:
Hola,sí,es correcto,lo siento no se escribir bien en inglés pero hoy en día todo esto se traduce automáticamente a cualquier idioma,,las baterías idiving cuestan 120E si le entregas el cable usado de subtronic y si le pides a Arturo que te las ponga de más capacidad,,por ej 3500mah no hay problema,,tu idea de poder desmontar y cambiar elementos en un minuto es buena pero todo lo que sea abrir cosas en el mar o en barcos es motivo de fallo posible,con llevar un par de packs por flash seria suficiente para 4 inmersiones día que es lo que solemos hacer cuando viajamos,no tanto cuando buceamos en casa...tampoco me gusta nada tener un cable de corriente por ahí pero es la parte mala que tienen los subtronic 160 pro,lo demás tu bien lo sabes,son ventajas,Wolfgang Tick sigue en activo revisando subtronic pero lo malo es que ha dejado de fabricar unidades nuevas o eso entendí la ultima vez que hablé con él,...tambien dispone de packs de 9ah o más pero son muy aparatosos...,,lástima que no haya espacio dentro del flash para adaptar un pack 8.4v 4ah,,sería lo suyo pero no cabe y un pack de polímero de litio sería demasiado peligroso....,hoy en día hay celdas de 5ah un poco más gordas 21mm y de igual longitud,,tal vez con eso sería suficiente...muchas gracias por compartir tus conocimientos,esto siempre sirve de mucha ayuda...
Tambien decirte que los packs de idiving se pueden desmontar por el usuario y cambiar las celdas,,los originales de subtronic vienen sellados para que nadie puede abrirlos sin romperlo todo,,podrías adapatar un portapilas especial dentro del tubito idiving de tal manera que pudieras cambiar tu mísmo las 18650 que hoy en día ya las hay de 50A de descarga......
  • Author
Trust me , I actually have a lot of experience both with the Subtronic batteries and the Idiving batteries, I have open all of them, the Idiving ones are a bit easier to open but you need tools. I have also bought cables to Mr Tick to fix my batteries and manufacture the ones above. Once you have opened it if you need to change the cells you will need a welder by points, a new niquel strap and tin. It's not an option to open the batteries in the middle of a diving cruise. When I go on a trip I go with 4 batteries and until I made my own batteries I always had issues with them, they always brake up in the middle of the trip, so I finally start to change the cells inside before the trip and now I go with Idving and Subtronic batteries plus my ones. Mr Wolfgang Tick is still doing strobes, my diving buddy have just bought a brand new 160 pro. And Mr. Tick is still making revision of the strobes, my two 160 pro fusion have gone to him once per year since 5 years ago, revisions, failings, new failings after revisions...it's true that he always makes me a fair price but it's also true that I'm tired. Mr. Tick says the strobes must be checked by him every 6 years. I had to make my last trip to Thailand in december with two AOI strobes that I bought brand new a few weeks before the trip because one of my Subtronic strobes had a failure just after a revision, I paid 160 euros each strobe for that revision, plus shipping, when I received it, weeks before the trip one of the strobes didn't work anymore so I had to send it back, that means it wasn't to arrive on time. So, I sent two strobes months before my trip to do it with no issues, one of them comes failing and I have to buy new strobes to do the trip.
Those AOI strobes work flawlessly with batteries that I can buy in Amazon for 20 euros each. I'm not going to buy Subtronic again.
bueno,tambien he tenido varios problemas de ese tipo y este mes pasado me ha revisado 3 de mis 160 opto,,le pedí que me vendiera flashes nuevos y me dijo que no,que ya no fabrica solo vende usados revisados,solo los garantiza por 6 meses y los envíos a Alemania desde el 1 de enero son bien costosos,es decir que tambien ando mosqueado con el tema,,por otra parte compré flashes fotocore que todo el mundo habla muy bien de ellos y en 1 mes dos se rompieron,afortunadamente el distribuidor me atendió perfectamente las garantías y me envió flashes nuevos,hoy por hoy lo único fiable es inon pero de momento no sacan la joya de la corona,habrá que esperar un poco más.....
uno ya no sabe que comprar....pequeño y potente además de fiable,,viajar con sobrepeso es complicado...
seguiré jugando a la lotería con los subtronic,estoy cansado de dar de baja otras marcas de cuyo nombre no quiero ni acordarme.......todo se andará.
bueno,tambien he tenido varios problemas de ese tipo y este mes pasado me ha revisado 3 de mis 160 opto,,le pedí que me vendiera flashes nuevos y me dijo que no,que ya no fabrica solo vende usados revisados,solo los garantía por 6 meses y los envíos a Alemania desde el 1 de enero son bien costosos,es decir que también ando mosqueado con el tema,,por otra parte compré flashes fotocore que todo el mundo habla muy bien de ellos y en 1 mes dos se rompieron,afortunadamente el distribuidor me atendió perfectamente las garantías y me envió flashes nuevos,hoy por hoy lo único confiable es inon pero de momento no sacan la joya de la corona,habrá que esperar un poco más.....
uno ya no sabe que comprar....pequeño y potente además de confiable,,viajar con sobrepeso es complicado...
Seguiré jugando a la lotería con los subtronic,estoy cansado de dar de baja otras marcas de cuyo nombre no quiero ni acordarme.......todo se andará.
tambien tengo un 160 pro (nuevo) comprado hace un mes,pero fue fabricado hace 7 años,con lo cual garantía cero y se rompió a la segunda inmersión,,otra vez paga portes,reparación etc etc,,el señor Wolfgang siempre muy atento y cordial,eso sí,y revisiones a un precio razonable,pero todo esto cansa mucho.............aunque he tenido peores experiencias con sea sea por ejemplo.......
  • Author
Well, my buddy's new 160 pro was bought in november, it arrived just in time for the trip. He never said anything about that he's going to stop making strobes, and the strobe is brand new, so 3 years warranty. But obviously is a brand which is near to close ot to be sold. Anyway, my intention is not send my strobes never else, next time I'll put it on a box and I'll use only the AOI ones. I'm so happy with them.
I also was about to buy that Photocore but I was told there are so many issues with that so I I bought the AOI. Sea&Sea, never again, I have had D1, D2, D2J, all of them are bullshit. It's going to be difficoult to trust them again. And Inon, for the moment are in a lower league.
es todo correcto,,la producción de subtronic esta parada por falta de componentes electrónicos pero si todo va bien en unos meses empezarán a producir de nuevo....si,the fotocore no quiero ni comentar nada...............ya irá saliendo ese tema en este portal...muchas gracias,,un saludo.
