Retra Maxi - The Most Powerful Underwater Strobe and Video Light
Introducing the Retra Maxi: The Ultimate Underwater Strobe and Video Light Combo
The Retra Maxi sets a new standard in underwater photography, combining a GN46 strobe with an optional 6000 lumen ultra-wide video light. Perfect for both stills and video, it offers unmatched performance for photographers and videographers looking to elevate their work.
Incredible Strobe Power and Performance
The Retra Maxi features a GN46 strobe, providing excellent light output for distant subjects. With its 110º beam and 5800K color temperature, it delivers precise and balanced light. The optional wide-angle diffuser expands the beam to 160º and reduces the color temperature to 4500K, perfect for wider scenes.
Unmatched Speed and Efficiency
With sub-2-second recycle times and over 550 full-power shots, the Retra Maxi ensures you won’t miss a moment. It also provides up to 1 hour of full-power video light output, giving you exceptional endurance for long dives.
Customization and Compatibility at Your Fingertips
Customize settings via the Retra UWT app, including HSS, TTL, and manual modes. The Retra Maxi is also fully compatible with all Retra Flash accessories, such as diffusers, macro rings, and the LSD Optical Snoot, allowing for flexible setups.
Durability and Design for the Toughest Conditions
The Retra Maxi features dual O-ring seals and a sealed battery compartment for protection against water damage. The LED-illuminated back panel ensures easy readability during night dives, and the strobe is powered by two 21700, 6000mAh batteries for long-lasting performance.
Pre-Order Now and Secure Your Retra Maxi
Pre-order the Retra Maxi now at $799 (excluding local taxes) before the December 4th deadline. Shipping is expected in early 2025, with more details coming in end of December 2024. Don’t miss your chance to secure the Retra Maxi and revolutionise your underwater lighting setup!
https://www.retra-uwt.com/products/retra-maxi
User Feedback
Recommended Comments
CaolIla
Members
Hi @Oskar - Retra UWT
I ordered 2 flashs,  I received weeks ago the information over a new delivery date.
Can you update us here?
CaolIla
Members
Hello @Oskar - Retra UWT, no answer... hummm
What doe ist mean?
You get my money for the 2 Retra Maxi I hope I'll receive it.  I've trust you/retra UWT... was that a mistake ?
Hi,
Thank you for your message. I can confirm that your order is secure, and we remain fully committed to the updated delivery timeline. As mentioned previously, deliveries for the Retra Maxi strobes is currently expected to begin in May 2025.
We kindly ask for your understanding that our team does not actively monitor forums and is usually not available over the weekend, which is why there was no immediate response to your inquiry on Friday evening.
For any urgent matters or direct questions, we recommend reaching out through our official communication channels listed on the Contact page of our website. This is the most efficient way to ensure a prompt and accurate response.
Thank you for your patience and understanding. If you have any further questions or concerns, please don’t hesitate to contact us directly.
CaolIla
Members
Thank you Oskar.
I posted here for the other member of Waterpixels.
The Idea was that all can read the answer.
I have no problems with the delay.. it's OK, and Retra is still alive
I'm happy for that  🙂
Alex_Mustard
Members
Images and thoughts on trying (pre-production) Retra Maxis in the Maldives in March/April.
Quick summary - performed very much as you'd expect them to - mega powerful, good ergonomics. With specs that are very similar to Backscatter HF-1 (Retra can claim to be the most powerful strobe on paper - but basically max power on these is all but the same as FULL +2 on HF-1 in the real world). Dry weight same as HF-1, but fatter, so much closer to neutral underwater. Quality of light not as nice as Retra Pro Max, but I still produced very pleasing images (just a bit more care needed on strobe positioning).
Alex_Mustard
Members
(edited)
And a small selection of shots taken with the Retra Maxi strobes in the Maldives
Sony A1, 28-60mm, FCP
Sony A1, Nikonos 15mm
Sony A1, Nikonos 13mm
Sony A1, 28-60mm, WACP
Sony A1, Tamron 90mm, MFO-1
Edited by Alex_Mustard
Architeuthis
Members
Hi Oscar,
I have a question about the electrical contacts of the new Retra Maxi strobe:
What material are the contacts made from (gold plated?)?
Thanks, Wolfgang
Hi!
The battery contacts have multiple layers of anti corrosive coating with a silver coloured finish, designed specifically to protect the connection points. We have not encountered issues with this coating unless there was water ingress or a short circuit caused by a damaged battery or incorrect battery orientation. Incorrect orientation is not possible in the Maxi battery compartment and the new li ion batteries typically include short circuit protection.
If water enters the compartment the contacts can get damaged, although in all past cases users were able to clean them well enough for the strobe to power on and remain usable. Any replacements (if necessary) were carried out only after they had successfully completed their diving trip.
Michi
Members
Is there any Information about how many frames you can take in serial Mode per second with what power level / GN? Thx in advance
