Weefine WF101 Ring Light 3000 Version 2
Weefine have just released a new ring light, the WF101 Ringlight 3000 Version 2 to compliment their existing WF105 Ring Light 3000 CCW but what are the differences between the two and why would you prefer to use one over an external strobe?
Ring Lights are particularly useful in macro underwater photography, providing shadow-free illumination when a subject is close to the lens (the WF105 Ring Light provides 1000 lumens of light allowing users to shoot at just a 25 mm distance from their subject), super ideal for lighting tiny subjects, particularly if they are in an area difficult to illuminate evenly with an external strobe.  They are a fabulous smaller, lighter (just 470 or 480 grms above water/245 arms underwater), more economical option for those macro lovers starting out in underwater photography who don’t want or need to invest in a larger, heavier strobe.
Images @ Pauline Wong and Ken Thongpila
Both versions provide a 90 degree beam angle with a continuous 1800 lumens of light for 45 minutes and 3000 lumens for 12 hrs of strobe use.  As mentioned above the WF105 is a Super Close Ring Light providing 1000 lumens allowing for softer lighting, making it ideal for super close subjects.  Both have a built-in strobe port offering a Strobe Mode with a specialised optical fibre cable.  The newer version WF101, also provides extra options of blue and red light aside from white light (5500k), whereas the WF105 offers the possibility of adjusting the colour temperature (3500-8000k) to allow extra colour precision.  It also has 19 brightness options via an adjustment knob compared to 4 with the newer WF101 V2 via a push button which also boasts 4 choices of power levels - 100%, 75%, 50% and 25%.
Battery wise, the WF105 offers the extra option of USB-C charging, with both offering 3 colours to indicate battery power, making it easy to see if a quick boost is needed between dives.
Finally both are depth rated to 100 ms/330ft and offer the ability to be used with lenses of both a 52 mm and 67 mm lens thread.
To sum up, Ring Lights are a fabulous way for a beginner to get started capturing their favourite macro subjects as the light will never need repositioning, giving your subject a flattering soft glow and can lessen the risk of backscatter in your images.
Visit www.weefine.com for more information.
User Feedback
Recommended Comments
There are no comments to display.
