Experimental test for correct lens position within a dome-port
Featured Replies
You don’t need to take a split shot
Distortion shows only in the water part
you can shoot any rectangular object like a grid on a slate topside and underwater and check after lens correction the distortion is the same
fisheye are easy you use the longest extension on a real dome that doesn’t vignette
the lens is distorted the technique
of two layers still works
so in short there is no need of taking a split however a split gives you the answer in a single shot
