Supe UM5.5
Featured Replies
17 hours ago, Interceptor121 said:
After positive discussion I have ordered this monitor and should have it next week
Not sure I will be testing it in Grenada as this is a a photo orientated trip and I prefer not to test equipment on trips
Β Side by side with Shinobi real world use comp will be interesting πŸ™‚Β
17 hours ago, Davide DB said:
Β
Let us know your impression on desktop use πŸ™‚
Β
Will surely take it to the pool in a few weeks
  • 2 weeks later...
I have received the unit. It is heavy however I can confirm the ergonomics work very well and I expect to work well with gloves too.
The display is extremely bright
One challenge is that zebra stop at 100% the display does not support out of legal range zebra (which is also an issue on atomos but that stops at 105% and on the ninja you can legalise)
Functionality seems complete and very solid.
This is an initial topside view need to check on underwater more in depth literally
  • 2 weeks later...
I have finally set up the monitor it is heavy but nothing to worry too much and quite negative
Β
Negative thingsΒ
Zebra goes to 100% (atomos to 105% both useless)
The battery placement is poor
Β
Positive
It is very bright
All exposure controls are good except zebra and false colour is indeed very good
The ergonomics of the command are good
It is not expensive
Β
Now if someone would explain to Sony how to implement HDMI out because frankly this company is hopeless. It reminds me why I use the EVF/LCD
You set HDMI out so you can see the level and this genius camera outputs the HDMI at 3:2 like the LCD so the screen is tiny this is SO STUPID it is Sony
Β
Β
Negative thingsΒ
Β
Positive
It is very bright
It is not expensive
Β
Β
Β
Sony indeed output exactly what sensor offers. Clean 16:9 for videos and 3:2 for stills. Off course you would have to opt for clean HDMI and have your controls on the camera screen. If you want to see controls then sony outputs its rear screen exactly as you see it - which is useful for some and not for others.
  • 5 months later...
Β
Negative thingsΒ
Β
Positive
It is very bright
It is not expensive
Β
Β
Have you done "real life" testing of this monitor? Β Could you please share your experience?
Β
On 4/4/2024 at 10:04 AM, Davide DB said:
I'd like to know its weight in water. Last time I checked, this info was missing form their website.
It is 720 g in water (as advised by SUPE).
Edited by DiversLens
Important Information
  2. Tap Permissions β†’ Notifications.
