Saga Trio diopter with Sony 90mm macro
Featured Replies
Has anyone tried the Saga Trio diopter with the Sony 90mm macro lens? I recently switched from a D850 to an A7RV and found that if I tried to reuse some of the ports I already had (Nauticam 35.5mm N100-N120 adapter + N120 extension ring 20 + N120 Macro Port 60), the 90mm was fine on its own, but resulted in significant vignetting if I tried to use the Saga Trio on top of it. That port combination is 10.5mm longer than the N100 Macro Port 105 recommended by Nauticam's port charts, so I was wondering if anyone had tried this combination with the recommended 105mm port to see if it would fix the vignetting, or if I would be forced to switch to smaller diopters with this lens.
