Sony 100 mm macro
Featured Replies
1 hour ago, ChipBPhoto said:
Correct and good strategy. Just remember a TC + an SMC is next level of difficulty.
Also keep in mind the further you are away from the subject, the more chance of particles in the water column between the lens and subject. Your lighting output will also need to be increased. Sounds like you already understand that part.
Let us know how it goes!
Yes. I tried the smc2.. and oh my... Good results but hard to nail down. Smc1 is easier to manage.
Good note on the particle bit.
  • Replies 157
  • Views 33.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I've shot over 3000 underwater images with the Sony 100mm now. It is definitely the best macro lens that I have tried on my Sony. And arguably the best macro lens on the market. That said it is small
  • Seacam updated their port chart, and they recommend the PVL65 extension for the 100mm macro. I can confirm that a 60mm would not work. By email, Harald also recommended the PVL65+20 for the TC1.4, and
  • Illustrated review of shooting the Sony 100mm in Lembeh is up on YouTube:
Posted Images
I think the answer is with a 1.4/2x you are always further away than you would be with a bare lens and with a wet lens. With a 2x you can match nearly a 100mm macro with an SMC-3 (2x vs about 2.2-2.3x depending on which macro lens). Basically more water between you and your subject which will degrade the image.
If you back off to get 1:1 with a 100mm_macro/2.0x you have the reach of a 200mm macro, so if you had a 100mm lens with 300mm focus distance and 150mm working distance at 1:1 you would double that distance with a 200mm focal length lens depending on how much the lens reduces in focal length to achieve 1:1 with and IF design. It gets worse as you progressively shoot larger subjects.
A 1.4x might be a good compromise to give a bit more working distance compared to the bare lens and wet lens at a given magnification.. Also bear in mind that the longer focal length of the lens + TC combo will give you significantly more magnification than the bare lens with the same wet lens. For example the m43 Pany 45mm lens gets 1.6x with CMC-1 while the 60mm macro gets 2.0x (both 1:1 lenses) and 60mm is near 1.4x 45mm. so the new Sony macro might go from 2.4x with SMC-3 to 3.3x with a 1.4x and 4.8x when used with a 2x.
So a 1.4x/2.0x locks you into smaller subjects than a bare lens/wet lens combo does and the impact would be noticeable I think in the 0.5x -1:1 range and lower magnifications unless the water was crystal clear. It may work well for skittish mobile subjects like small fish if this was the sole subject of your dive.
You might also degrade AF performance with the 2x at max magnification again depending on lens/body combination
Looks like an amazing lens. I love my 90mm. It is slow to focus at times, particularly on small things, but the images are so beautiful. I'm excited to get my hands on one of these.
Just getting set up with mine— I’ll try and report back on the SMC-1 vs 1.4 TC question.
One thing to consider on the TC side is that there is not yet a focus gear that works with the extension ring. I’ve heard there is enough interest to perhaps make one/adapt the existing one— but it is yet to be made available.
@rainforest_UW Do you have the MFO-3, or any of the other underwater optics you’ve tested with your 90?
It is interesting to note that even though this lens and the Canon RF100 achieve 1.4x magnification, when you add on wet lens they only achieve minimal gains in magnification over what you would get with the 1:1 lens they replaced.
The Canon RF 100 with SMC-3 achieves 2.3x with 30-100mm working distance while the Canon EF 100mm macro gets 2.2x with 46-97mm working distance.
The Sony 100mm gets 2.4x with 34-100mm while 90mm macro gets 2.3x with 47-103mm.
This is due to the lens reducing focal length to focus in closer, this is a feature of all internal focus macro lenses and becomes particularly prominent as the magnification increases. You might initially think you'd get much more, but the shorter focal length means the power of the SMC-3 or any other wet lens is a lot lower and the peak magnification is achieved at a shorter working distance.
It would seem based on theBackscatter review that a 1.4x is a decent option if you were chasing small skittish fish with Sony 100mm macro
On 5/23/2026 at 12:56 AM, Architeuthis said:
Interesting review...
Did you have a chance to test IQ, when MFO-3 is used with the lens & 1.4x TC?
We were very happy with the image quality of the MFO-3. But we never tested the MFO-3 in combination with the 1.4 TC
