Jump to content
Strobe electrodes cleaning when abroad
Featured Replies
So far I never did experience problems with corrosion of electrodes, but on my recent trip to Mafia Island/Tansania in November, two HF-1 strobes almost simultaneaously let me down for most of the time of the stay (it turned out later the reason was corrosion of the electrodes)...
I was using them for approx. 2 years, never flooded them and cannot remember that I ever dropped a single drop of (salt)water into the battery compartment. I fear that this problem will come again and plan to put together some kind of "emergency kit" that I can use when I am abroad.
The strobes had the electrodes replaced at Backscatter (kind, quick and labour as a goodwill case), are now on their way back and I asked Sevag (the Service Manager), what components he would suggest for such a kit. I think his suggestion may be of interest also for others here:
"...The best tools to have with you are some alcohol wipes, liquid isopropyl alcohol if possible (90-99% is best), a brush to help reach the contacts at the base of the strobe, and a fiberglass cleaning tool like one of these: https://www.backscatter.com/Hama-Contact-Cleaner-CAUTION-Fiberglass ..."
What is the opinion of UW- photographers, who have had problems in the past with strobe electrodes, about such a "kit"? How did you deal with corroded electrodes? Any additional suggestions?
Thanks for the input, Wolfgang
The standard emergency kit is:
  • Diet Coke to remove battery acid, if needed
  • Blunt end of a chopstick or pencil with a bit of t-shirt or makeup pad rubber-banded to the end
  • Some alcohol for the pad on the chopstick
  • Rubbing action
  • If that doesn't work, use fine sandpaper in place of alcohol soak cotton pad
You can get better products like DeOxit Gold to clean your contacts before you are on a trip with fewer resources.
Important Information
