Mini-Dome for GoPro?
Featured Replies
My wife bought the Hero12 black and a really cheap (40.-) Domeport from „telesin“, rated down to 15m. Feels little plastic.
https://www.telesin-store.com/dome-port-c0027
What makes me totally unhappy is that she took pictures that really look nice. Really.
Is there a stable solution also? Meaning small dome for GoPro that will survive more than 5-10 dives and more than 15m?
Edited by fruehaufsteher2
The best option is the Inon UFL-G140 SD Underwater Semi-fisheye Conversion Lens, which corrects the underwater view from from 94° to 140°. It's a water contact lens, so you can't really use for half-half pictures (as your example above). There is a workaround to apply a special O-ring (and contact the lens underwater.
There is a new cheaper alternative, the AOI UWL-03 Wide Angle Lens (almost half price) that has a similar quality.
  • Author
Hi Nikolausz,
Thanks for your help!
Actually both INON and AOI seem not to support splitshots, but could provide narrower focusing and better image quality. The Telesin port has a diameter of 6" (18cm) - what seems to be the lowest size for splits.
But maybe worth a try.
1 hour ago, fruehaufsteher2 said:
Hi Nikolausz,
Do you need it exclusively for split shots?
3 hours ago, fruehaufsteher2 said:
Hi Nikolausz,
The inon supports split shots but you have to buy an extra ring. "Split Easy for UFL-G140 SD"
http://www.inon.jp/products/gopro/uflg140sd.html
  • Author
Ah, now I got it - that's what you meant by "There is a workaround to apply a special O-ring (and contact the lens underwater. ".
OK, seems to be interesting! Thanks a lot!
  • 6 months later...
Easydive has unveiled the new housing for Gopro and Insta360 Ace pro with built-in mini dome (split shot I don't fear you!!!) 😄
Actually reading the features it is a 160mm dome so not really mini, especially for a GoPro. the FOV remains the same.
Here the product page and a YT video of Alessando Beltrame showing the housing and dome in action. (Video is in Italian but YT can translate it for you).
https://www.easydive.it/en/underwater-housing/action-cam/housing-for-action-cam/actiondome-case.980.html
  • 2 months later...
Important Information
