Jump to content
The iPhone wish....
Featured Replies
Hi there, is anyone using their iPhones with video lights for casual video shooting? I wonder if with the help of good video lights their small sensor can produce good results in low light.
Happy day!
8 hours ago, Davide DB said:
One of our member @DAVIDE BRICCOLANI published recently a video shot with the iPhone 15 Pro on a deep dive:
The close-ups are fantastic but the corners of the wide angle sequences are not good.
Physics is physics!
You cannot use such an extreme WA behind a flat port. It looks like the GoPro with the superview. Also in movement the perspective is disorienting. With the AOI lens in front they would be perfect!
12 minutes ago, Davide DB said:
Physics is physics!
There are adapters for smart phones as I remember
  • Author
DiveVolk sells one but it works only with the wide angle lens on the iPhone 14 Pro. It won't achieve focus while using the main lens(24 mm equivalent) and this is the best lens on the iPhone 14 Pro. I use it with the wide angle lens, it helps but it won't completely fix the corners softness.
Important Information
