Pimp up your GoPro
Featured Replies
Most of the time my GoPro will sit on my larger sony camera setup, but time to time I take a single action camera with lights. Yesterday I tried a new setup with a single GoPro12 with AOI wide lens adapter and two Weefine lights. I think this is the maximum level worth to pimp up your GoPro. It Included:
  • GoPro12
  • AOI UWL-03
  • Divevolk tray with two grips
  • 2 Weefine Smart Focusd 7000
  • Weefine remote control unit
  • 2 fiber optic cables
  • BGNing Trigger rod shutter
  • 4 floating arms
You may further improve it with an aluminium housing and better and more expensive lights, but it would be overkill. I have an aluminium housing for an older model and the size and weights were more disadvantage then the  added advantages (robustness, better depth rate etc.)
The best thing in this setup is putting the control of the light and the shutter release close to the grip. The AOI lens improves the image quality, but it's a bit problematic to use it under turbid condition.
How does your top GoPro setup look like?
Your sunhood could use a little adjustment 😀
This is indeed a very capable setup like this. Have you thought about adding a macro wetlens to the setup? There is the AOI ucl-03 that fits on the bayonet system but I don't have personal experience with it.
Edited by Robin.snapshots
  • Author
I haven't tried the macro wetlens and will probably skip it. I have a bigger camera (Sony A6400) with proper macro lenses (30mm, 90 mm) and I also have other solutions for actioncamera macro (replaced, adjusted lens).
  • 2 weeks later...
Thank you for this!  I find my biggest gripe with the gopro housings is hitting the "shutter" button with thick gloves on.  I hadn't seen that Trigger rod shutter before - definitely gonna pick one up.
  • Author
I've ordered here:
https://de.aliexpress.com/item/1005004323302764.html?spm=a2g0o.order_list.order_list_main.39.42d35c5fq0pu67&gatewayAdapt=glo2deu
It was really worth it. I also like the wire control of the video lamps.
  • 1 year later...
Hi, I've almost the same rig ;-) 2 video lights weefine solar flare 7000.
I bought the trigger on AliExpress and I believe its usefuf with dry gloves in cold water
The only problem you might have is always the trim—specifically the torque you have to apply (with your wrists) to keep it level or to tilt it up and down.
Assuming it is neutral or slightly negative, if you hold the arms in the shooting position and let go, or hold it with just one finger, what happens? I mean, how does it position itself?
The rig is almost neutral, slightly negative. After arms and lights proper positioning, the trim is almost good and horizontal and I manage the whole system with only one hand. However, to get the better stability when shooting, I use both hands and the footage quality depends by my hovering.
By the way, due to the horizontal cross bar, this solution is huge better than without trigger when using dry gloves.
I have another kit without crossbar and trigger is absolutely not necessary to shoot videos with my Gopro 12.
Bye, Giacomo
I just pimped my GoPro 13 with a tray and trigger after frustration a couple weeks ago with 5 mm gloves trying to maneuver the GoPro. So far I’m pretty happy with the rig on dry land wearing my gloves.
  • 1 month later...
Curious, what upper cross piece is that?
Lens holder on cross bar
Edited by Gmsalterego
  • 3 weeks later...
  • 2 weeks later...
  • 2 months later...
I am a bit late to the party, but here my pimped GoPro, for macro, super macro and wide 😁
Lenses:
Inon G55 (super macro)
Inon G165 (macro)
Inon G140 (wide)
Tray, main floater, clips and the 2 short arm from AliExpress (really cheap, but served me well for 3 years)
2 Arm floater with lens holders from inon
Tripod from Joby (5k version)
Torch DL08 from wurkkos
Torch here
On my Instagram you can see some of the results (I have that problem, the one that I like to shoot a lot of cool video, but edit just a small part of them 🫣)
Insta:
Elvandar
Edited by Elvandar
  • 3 weeks later...
Hi,
how is the G165 performing?
I got it for my new Mission 1 Pro because I was looking for a close up rather then a real macro but online I didn't find much info about that lens.
Lenses:
Inon G165 (macro)
Inon G140 (wide)
Torch here
Insta:
Elvandar
3 hours ago, BeppePADI said:
Hi,
IIRC this video of Vincenzo Striano was shot with the Inon G165.
Try to reach him on YouTube, I'm sure Vincenzo will be glad to give some feedback.
@BeppePADI the G165 Is nice, you can use it on the GoPro 9-13 to have a focus distance between 10 - 35 cm
Outside of this range it start pretty quick to go out of focus
The quality of the lens is really good, and you can make really nice video, with subjects of the right size, not too small.
About using it on the Mission 1, I don't know if it's compatible, since the bigger GoPro sensor, will change it's working distances.
I didn't see any news about that from INON yet
