Jump to content
Backscatter MF-2 in HSS mode
Featured Replies
HSS does not have sync speed limitations, as the strobe flickers continuously at a high rate while the narrow slit between shutter blades passes across the frame, therefore you're only limited by your camera's mechanical shutter speed. For the A7RV, that's 1/8000s. However, HSS, when activated, significantly reduces the brightness of the strobe, and increasing the shutter speed progressively reduces it further. As I recall, with my Retra Pro strobes, I get a similar exposure with HSS at f/8 1/2000s as I do with normal sync at f/22 1/160s, both at max power.
Good explanation!  Realistically, about 1/800 - 1/1000 or so for the HS-2, but you most likely wont need that fast.  The biggest benefit is to help tame a sun ball or use a wider aperture beyond the 1/160-250 normal limit.  1/640 or 1/800, or less, can normally do that very well.
  • Author
So using a Sony A7RV and S-turtle 2 trigger, how do I set it up in HSS mode?
Balazs said no need to setup software.
But there is a B.Scatter MF-2 option that I cannot select for some reason.
HSS is often setup from the camera menus as the camera is the thing that needs to change sync timing.  It should be in the same place where you would select HSS with a land based flash.
  • Author
One must turn on wireless flash in the camera settings in order to use HSS with a Backscatter MF-2.
Sample:
ISO 200, 1/500, f/6.3
Important Information
