Nauticam newest MFO-1
Featured Replies
9 hours ago, humu9679 said:
I think you are correct, an improvement in image quality shooting through a flat macro port, with improvements in magnification and range of focus. Here is the Nauticam product page: https://www.nauticam.com/products/mid-range-focus-optimizer-1-mfo-1
It would be very helpful if Nauticam can provide sample images like e.g. with and w/o MFO-1 that clearly show the benefit of using MFO-1.
And does it improve IQ also when a macro lens through domeport is compared to macrolens&MFO-1 through flatport (especially interesting for shorter focal lenses, where the flatport makes most detoriation of IQ)?
It seems to me that the MFO-1 is better mounted permanently to the flatport when making macro. But then, what when another diopter will be used that increases the magnification substantially above 1x (like SMC-1 that is essential for macro on FF)? Is SMC-1 used in addition to MFO-1 via e.g. a flip holder (as many use the SMC-1 now)? Or is MFO-1 removed and SMC-1 mounted instead (either via (unhandy) double flip holder or by dismantling MFO-1 and storing in a pocket)?
Edited by Architeuthis
  • Replies 95
  • Views 20.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • The MFO-1 (Midrange Focus Optimizer) was inspired by Dr. Alex Mustard and Ryan Canon.   Ryan and I have been discussing quite often on how much our optical products elevate image quality, in
  • As I understand things, the issue this deals with is the air-water interface of the flat port, where away from the very centre light rays are refracted through the front port glass which degrades the
  • I've done some checking around today and details remain thin at the moment.  The only thing confirmed is it is a stand alone lens, not used in conjunction with the SMC/CMC, which is what I figured.
Posted Images
Bluewater Photography Guide says that SMC-1 and MFO-1 can be used in serial combination: https://www.uwphotographyguide.com/Nauticam-announces-the-Nauticam-Mid-range-Focus-Optimizer1-(MFO-1)
This, however, seems to be a misinformation as Alex clearly states here that SMC-1(3) and MFO-1 should be used alternatively and not together (he says that serial combination will lead to double correction of flat port abberation and hence a loss in IQ):
=> The only problem with Sony 90mm plus SMC-1 that I was able to recognize so far is slight vignetting in the corners when I use SMC-1 at the longest object distances and smallest magnifications that SMC-1 allows. These are, however, object distances and magnifications that I better cover with the pure macro lens w/o any diopter attached...
=> I also wonder what the benefits of using MFO-1 on Sony 90mm with flatport are: does sharpness improve just in the periphery or is it increased also in the center (when it is the center, it may be worth going for it (but I did not recognize any sharpness problems in the center yet))?
Wolfgang
Wolfgang
The thing with macro lenses behind flat ports is that the aberration increases continuously from center to edges as the angle the light rays are coming in gets progressively greater as the angle of view increases, so it's a progression, only in the very center of the port are the light rays perpendicular.  However out at the rule of thirds points where you might place something important to your composition, the rays are at an angle and you are about half way out to the edge.
If you photograph a test chart on land you will see something similar a slight degradation in quality that gets progressively worse towards the corners, but it is going to be hard to spot that in a regular photograph - It's only when the aberrations reach a certain level that they are obvious.  UW the port and lens aberrations add together.
The other thing that is claimed is reduced hunting - apparently due to compressed focal range.  I would also think that removing flat port aberrations can only help focus is easier to find on a sharp lens.
It sounds interesting for sure, But I think we might need to wait for some high resolution test shots to see if any improvements are enough to convince you that you need one! 😂
  • 2 months later...
Mine is mounted and waiting our flight.... I'll give some feedback in a litle bit one month wenn I returned from Raja Ampat and Lembeh
Hi,
maybe there are already some first-hand reports.
My question is:
how does the mf01 behave in conjunction with the sony 90 mm
how does the mf01 behave in blackwater diving (also with 90 mm)
Thnks wolf
26 minutes ago, sorgiew said:
Hi,
My question is:
Thnks wolf
  • 2 months later...
Bumping this up.
Now that this has been out for a while, any first hand experiences with it? And specifically, any thoughts on whether it is worth trying this out on an APS-C body with a 90mm macro? Non-Nauticam system, for what it is worth (which shouldn't matter, as far as I can tell).
Well it works fine for a u4/3 at 60 mm, close enough to 90 on APS-C. Not sure that it really extends the focus range though. You will need more flotation, on a flip adapter it is quite heavy. The spine cheek was shot with the Panasonic 45 on an OM-1 with the MFO
Bill
Bill
It "works" with the 28-60mm Sony lens, but vignettes as expected in the wider focal lengths.
Thanks for that, guys. I dont really shoot that much macro to build up a big array of accessories that will get used maybe 1x a year. But still, something to think about - this or a close-up lens.
I did my first dive with one this week and got one shot I liked. Rhinophores so sharp they could cut you!
I’ve done a lot of diving with the SMC1, with and without snoot, around California and elsewhere in the Pacific. This Felimare californiensis is an unusually large nudibranch, so a nice in-between size that was perfect with the MFO and Canon RF 100mm. I think the combo of the RF 100 (which focuses closer than my old 100) and the MFO will be a nice macro and blackwater setup.
(Sidenote: I used Backscatter Xterminator on this pic and wanted to remove all the yellow spots from the Nudibranch!)
Edited by jlaity
Bill
Hi Bill, it works ok, but can you expand on the advantage? Did you experience a better corner sharpness and/or a snappier AF? I always liked the behaviour of my Pan 45 so I would like more info before I draw my wallet.
Floris
Bill, have you tried it on black water dives yet?
(Pics with and without, for science. Actually, please don’t take it off during a black water dive.)
In the new UwP144 (May/June), there is a review about MFO-1 (with Sony 90mm macro): https://www.uwpmag.com/
Just a repetition of what has been already told/advertised: works nice, a little more magnification, better IQ and better AF, but still no side by side demonstration of the improved IQ...
In case somebody here has the MFO-1 on a flip holder it would be really great to see comparable photos with and w/o MFO-1...
I have, but no dive is planed for the moment (only in fresh water with nothing for macros... ;) )
In 2 month I'll go to Ustica (Island north Palerm/Sicile) If noboby had published pictures with and without I will do that. There are some small and nice stuff. Nudibranch, Shrimps , crabs, it's not Asia but a nice place to dive one or 2 weeks it will be our third stay.
You need to be patient.
Edited by CaolIla
No blackwater for us on this trip. Tomorrow I will put it on a flip adapter and shoot with and without. In my hands at least it is a bit faster focusing (still not fast) with the 45 Pana/Leica but sharpness doesn't seem to improve very much but we will see.
Bill
We are off to Flasher Beach in Triton Bay. I am pretty sure that the MFO will get me the same number of good shots as without it, meaning zero in either case.
I will try to shoot some little stuff with and without to see what we see.
Bill
I have been shooting with and without the MFO on an OM-1 with the 30 macro (Oly), 45 macro (Panasonic/Leica) and the 60 macro (so far). In general it seems that the MFO really increases the focusing ability of the 45 but does not make so much a visual difference at least for the things I am shooting. The 30 macro shots with it are clearly better but focus speed seems pretty much the same. On the 60 it seems both focus speed and visual appearance are better. I can post some images if anyone wants to see.
Bill
Important Information
