G'day
Featured Replies
Hi, I'm a diver from Perth, Western Australia and couldn't resist the stereotypical greeting.
I only dipped my toes into the underwater photography world over the last couple of years, utilising a Sony A6000 I already had, a secondhand Seafrogs/Salted Line housing and some old S&S strobes - about as cheap as you can go!
I've since upgraded the body, added some lenses and a few of the limited ports available with the Seafrogs system, and at least got two of the same strobe (YS-110a).
With two little kids I don't get to go out nearly as much as I'd like which is the biggest thing holding me back, but still greatly enjoy it, so loving the advice and input from this forum as I consider my next steps gear-wise.
  • 3 weeks later...
  • Author
On 2/12/2026 at 2:00 AM, Grantmac said:
Welcome!
What body did you upgrade to?
Sorry missed this!
I went from the Sony A6000 to the A6400, as I had the Salted Line housing I could just change some shims to make it work and I've been very happy with that upgrade.
Eventually I'll have to consider if I upgrade the body when I go for a new housing, which will likely depend what I can find secondhand.
Heya, welcome !
I'm also putting together a A6400 set-up inside a Salted Line housing. Have a Tokina 10-17mm and currently working on getting a zoom ring for it.
Looking forward to sharing ideas !
  • Author
On 3/2/2026 at 7:36 PM, tailwind_marseille said:
Heya, welcome !
Thanks! I had noticed some of your posts around the place.
Feel free to PM me if you have any specific questions on the A6400 Salted Line setup as that's what I've been using for a little while now.
I own the Tokina 10-17mm but haven't yet shot a bunch with it as I've been enjoying the Sony 10-18mm a lot, when I have taken it underwater I use the Metabones adapter and have 3d printed the zoom gear but managed to break it when I chucked it straight into my camera bag, and have had a friend re-print it, although I wasn't in a rush as I found myself using it most at 10mm anyways.
I'm sure you've come across @Barmaglot across many different sites if you've been doing some research, they have some really useful info available too.
Yes ! I did interact with him a little. Upon his advice got myself the Tokina (also with metabones mark V), and was looking right now at the model in 3Dcults for the zoom ring. I need to find somewhere local where I can print it. Thanks for reminding me it's a fragile piece, and best way to carry it around would be fitted to the lens AND inside the housing :D
Thanks for the reply!
Create an account or sign in to comment
Important Information
