Canon RF 20-50 F4L for Underwater
Featured Replies
I'm interested in this lens for use in the 230mm (primary) and 140mm dome (travel). I wonder if it will require a closeup diopter filter to focus on the inside of the dome, or if it can focus stand-a-lone.
2 hours ago, puttsk said:
MFD of 0.24m
The 15-30 has a MFD of 0.28 and works well behind a dome so it should be good on the 180 or 230mm. No idea on the 140mm.
I'll bet its front element is too large to work well with the WWL-1B, that later of which is really designed for small front elements.
This may be a nice lens for video (behind a dome and for certain shots), or stills if it works with an wet-mate or dry-mate adapter (WACP,WWL-1, Marelux Aquista) for a solution (with limited to 28mm and greater zoom...)
I'm looking forward to seeing some real world examples underwater!
The new Canon 24-50 is very close to the Sony FE 20-70 F/4 for full frame with the main difference being the Canon is internal zoom. The both have the same minimum focus distance and magnification so the results should be very close. I have used the Sony 20-70 extensively with Marelux 180, 210 and 230 ports. In my tests the 140mm port it was a bust in terms of corners and not really recommended. I have attached the front page of the review I did (in UWP back issues) along with photos at 20mm and close to 50mm (45ish) to give an idea of the range, both with the 180mm port. The Marelux 210mm acrylic port fits into the same case as the 180mm port and is a little bit lighter and works better for splits so it is my travel dome. The PZ feature on the Canon 20-50 saves the cost of a zoom gear and it has worked well for me on the Sony FE 16-35 PZ.
Regarding use behind a flat port with Nauticam/Marelux wet lenses this remains to be seen. More likely to work with dry lenses like WACP-1 and Aquista 135D which is coming soon.
I am happy Canon made this lens.
20mm is the sweet spot before rectilinear lenses start looking odd.
I hope the lens design pops up on optical bench soon, so we can have a closer look.
Good news everybody!
The lens has already made it to optical bench hub:
https://www.photonstophotos.net/GeneralTopics/Lenses/OpticalBench/OpticalBench.htm#Data/US20260029629_Example06P.txt,figureOpacity=0.25,AxisO,OffAxis
Two some very good indicators that suggest it to be a good uw candidate:
1.) Entrance Pupil just moves 4.35 mm during zoom
2.) Just 42mm front glas diameter (will work with many water corrective optics)
3.) Minimum subject distance in Front of the lens = 123,2 mm = 12,32 cm
94° diagonal FOV @ 20mm behind a dome
Edited by Adventurer
Does anyone have an estimate on what extensions will be required for Marelux/Nauticam 180mm and 230mm domes?
  • 2 weeks later...
I've put my order in for this lens. Shipping July 24.
Waiting to hear back from Marelux on whether or when they will support zoom gear and extension.
  • 4 weeks later...
RF20-50mm lens arrived. I do not yet have a zoom gear. Tried mapping the PZ zoom in/out to custom buttons, but the R5 does not allow this option, even with the latest firmware.
I see Nauticam has a zoom ring for the 20-50. Marelux does not list it, and I haven't heard back from them on whether they plan to.
Does anyone know if the Nauticam zoom ring would work inside my Marelux housing?
Good news.
Although the diameter lens spec for the 20-50mm is 80mm and 14-35mm is 84mm, the marelux zoom gear for the 14-35mm fits the 20-50mm (snugly). I took 3 of the rubber shims off the inside of the ring that contacts the lens barrel.
Next will be figuring out the extensions required.
I was able to try this lens out yesterday underwater in a 140mm dome.
1/160 sec at f/8.0, ISO 100 @ 20mm. I bumped up the exposure +.55 in Lightroom, but otherwise no other changes. One negative, is the Lightroom Profile Correction for the new lens leaves a thin border banding. I assume future versions will fix this.6B0A1423.jpg
Last photo cropped lower left to show the Lens Profile banding on the border introduced by Lightroom.
Whow that’s strange!
Does this happen when you turn lens corrections in Lightroom ON or OFF ?
Looking at the MFD data of that lens the 140mm should be too small,… did you add a diopter to the front of the lens to compensate for it?
I think the 180mm MX dome or the giant MX fisheye dome will perform better concerning corner sharpness.
Also the new MARELUX Aquista 135D and this lens look like they will magic.
@JayceeB could you upload a lens image taken of a white wall (land-use), with deactivated lens corrections in Lightroom to see if there is a full image projection to the corners or if they are black @ 20mm focal length ?
Also if without lens correction you have black corners, at what focal length will they disappear? ( 22m , 24mm , 26mm , 28 mm)
Christopher Frost says in this video at 7:10 timecode that the black corners disappear at 24mm focal length:
Yes. If I turn 'Enable Profile Corrections' to 'On', I get the banding. The banding is more exaggerated when zooming in. At 20mm, it is negligible.
I did not add a diopter. I have been shooting this setup with 140mm dome and 30mm extension, which is the recommended port and extension for the EF 8-15mm fisheye. As I mentioned earlier in this thread, I was able to re-use the zoom gear from my RF 14-35. I've taken it on 5 dives and one offshore shoot for big animals. To be honest, I have been very surprised at how well it has worked in the tiny dome. I know the edges will not be acceptable for some, but for me, I am satisfied. I mainly shore dive, so lugging a bigger dome down rocky entries can be a handful, as well as exiting in rough conditions.
There are definite dark corners without lens correction at 20mm, so lens correction is mandatory.
This zoom range is very useful for most of my diving, and I think it may end up being a popular choice underwater use for some people. I have been able to shoot Harlequin shrimp (cropped) and dolphins on the same dive.
I'll upload a few more shots at various focal lengths.
Has anyone used this with a wacp-c yet? I am debating buying it.
Also debating switching to a Sony a1 for the 20-50 2.8 with wacp-c over my canon R5mii.
Does the camera allow you to turn off lens corrections (in-camera) or is this one of those Canon lenses where lens correction is forced in camera?
@JayceeB thanks for sharing the images. I think, the marelux 180 glass dome or their 210 acrylic will not add much volume or load and dramatically improve lens performance.
I assume the freshly introduced Marelux Aquista 135D - which is Marelux‘s take on Nauticam‘s WACP lineup - will give you the highest image quality with that lens, @JayceeB .
@WhoTippedMyCoW it was said that mx is launching that lens with adapters for various other housing brands, too.
Worthwile watching that progression.
Hi @Adventurer - The lens correction referenced is done in LR during post. It can be disabled there. The best solutions are to either frame a little wider to crop the outer edges or not use the LR profile and manually update the image as needed.
LR had the same issue with the original RF 24-240 profile. Not an uw lens, but a fantastic travel lens I frequently use.
I haven't been able to find a way to turn off lens correction in camera. You can turn it off in Lightroom after importing, but Lightroom defaults to applying it. I prefer lens correction on for the 20-50mm and 14-35mm, but lens correction off for the 8-15mm fisheye.
