RapidRAW
Featured Replies
Since I started dealing with RAW files I've been using DarkTable. Mainly because I refuse subscription services and don't use any sort of generative AI in my workflows as a ethical principle.
I've been overall satisfied with the images I've produced, the software is VERY powerful but equally difficult to learn. There are multiple ways to do most functions, different work flows and most importantly the masking is not remotely intuitive. It's probably just a little too technical for someone like me.
I think this is likely because the program has been a community project for years and like many such things there just isn't a cohesive vision driving it.
I have been researching RAW editors which are a bit of a fresher take, less aimed at experts and with more logical workflow. A number of people have been quite positive about RapidRAW, which is rolling out updates regularly.
I decided to give it a try and I'm impressed. 30 minutes into learning DarkTable and I had barely opened a file. 30 minutes into RapidRAW and I've edited pictures which I'd given up on.
The subject matter masking has been very successful with sharks, rays and divers even in lower contrast pictures. I have yet to give it a try with macro subjects but that is next.
The initial download is very small but then it'll do an internal download for the masking. I haven't been using it long enough to see how it handles updates and obviously just scratched the surface on everything there is to offer. I don't see going back to DarkTable.
https://www.getrapidraw.com/
RapidRaw's webpage extolls it's AI based features, including AI Subject masking, object removal, and more.
Unfortunately, I think we tend to draw a very large box around the GenAI term and there's certainly workflow acceleration aspects without wholesale manipulation or creation of an image. Maybe it's just backscatter reduction, mask application, or other tasks that may not involve large changes.
  • Author
It's in there, but a separate module which I haven't opened. I believe it runs locally rather than going to some sort of external data center, which is a significant component of my objection. I want to know my images aren't being passed through some sort of training program.
Subject masking is not something I consider generative. Neither would backscatter removal (in my mind).
Being able to recompose an image by adding, removing or reposing subjects is a different story. As is adding details which were not recorded as part of the initial imagine like we see with upscaling.
Edited by Grantmac
You have previously objected to even AI masking, as recently as a couple of weeks ago. Lightroom also does locally executed AI masking. Photoshop can use a local model for high end generative object removal as well.
I think we will find that going forward AI powered software will be the norm and non-ai based tools will be legacy or niche options. Pay close attention to terms of service and privacy protection policies. Your concerns are not unique and business/ corporate customers, which is where the money is, also care about their IP being protected. So these policies have teeth and should not be dismissed out of paranoia.
For sure there are dodgy actors that may play fast and loose with data privacy. Personally, i would put my trust in major software vendors like Adobe, Microsoft, and Apple before tiny vibe-coded software products like the ones you called out. They have a lot more to lose if they violate terms and conditions. But read the terms and conditions first!
I think there’s an important distinction here between AI-assisted tools and generative AI. A subject mask that identifies something already present in the photograph is quite different from generating, removing or inventing content. At least, that’s my opinion.
I agree. AI Masking is simply automation of a tedious task, what you do with the masked pixels is up to the user.
Tools that procedurally add or remove pixels, such as object removal, automated backscatter removal, even spot healing are all altering pixels. This sort of automation can be AI or heuristic-algorithm based. I don't think all of this is inherently bad or should be rejected out of hand. However for contests and competitions, I do not think it should be allowed at all.
Edited by Dave_Hicks
  • Author
I have far less trust of major corporations vs what is in essence someone's hobby project.
To each their own. How much attention to security, privacy, and concern about liability do you think goes into a hobby project? <Nada, zip, nil>
  • 5 weeks later...
  • Author
Latest update the foreground masking has nearly 100% hit rate on underwater creatures in a way that subject detection definitely hasn't.
Still a very lightweight install and a bit faster than before too.
