Proven 3D printed Parts For Underwater Imaging
Featured Replies
15 minutes ago, Yorkie88 said:
Have you got any tips for making the trays? I've been trying to make one for an MF-2 for a while but I'm hopeless with the 3D models and designing 🤦🏻‍♂️
I measured up and drew the outline, ready to use https://www.tooltrace.ai/ but I can never quite get it right
I can make an MF-2 tray pretty quickly. I played with tooltrace and similar but they only created flat outlines and a sculpted round one is better for this application of lenses and strobes.
These are easy as you just make a stack of appropriately sized cylinders to model the object. Then you save that model. Make a gridfinity tray of the needed size using a parametric modeler, fully filled to the brim. Import the object model as a negative modifier and position in the tray. Done!
  • Replies 153
  • Views 29.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Tino Dietsche
    Tino Dietsche
    Hello everyone, Since my used Nauticam WWL-1 lens didn't come with a back cap, I made a suitable one. It also works for the bayonet mount. I hope someone can use this. https://makerworld.com/en/mo
  • brightnight
    brightnight
    N120 body cap found on Thingiverse worked for me:   https://www.thingiverse.com/thing:5326351/files         Files attached too: Nauticam N120 Port Cover Male
  • Tino Dietsche
    Tino Dietsche
    Hello everyone, Over the last few weeks I have created new parts for underwater photography for the 3D printer, perhaps one or two of you can use some of them. This time they are parts that are i
Posted Images
20 minutes to design. 3.5 hours to print it out! Will share it out after it's validated.
I needed one of these anyways, will also be making cutouts for the HF-1 and Atom too, if they will fit in my drawer. The lens cutouts were a start on cleaning out a chaotic cabinet full of gear and getting things into the drawers currently full of random plumbing and electrical parts.
Edited by Dave_Hicks
Selfish enquiry for the nearby future - has anyone worked on focus gear for the Sony FE 100mm F2.8 GM in its Nauticam N100 Macro Port 125 by any chance?
That looks great! I'd been trying to design it with the ball mount parallel to the base.....but your design made me realise it can just stick up and still fit in the drawer, and that means it's a smaller footprint for the grids too! And the buttons having their own holes will stop it rotating in the holder.
What do you use for the modelling? I need to learn how to do the basics and get my drawer tidied up 😁
The only part i designed was the MF-2 body form. In fusion360. I auto generated the tray, then positioned the MF-2 as a negative modifier to the tray in the slicer. Added some text and color accents in the slicer.
Here is the MF-2 negative model.
BS MF-2 Strobe Negative.stl
Hello everybody,
And here comes the next part for my underwater photography setup, which might also be useful for others. To prevent my MFO-1 lens from getting scratched during transport, I quickly made a simple cap yesterday. Together with my protective cap for the Nauticam bayonet, this allows the MFO-1 lens mounted on the Nauticam bayonet to be transported safely and well protected.
Downloads:
Front-Cover for MFO-1 - https://makerworld.com/de/models/2326198-front-cover-for-nauticam-mfo-1#profileId-2541153
Rear-Cover for Nauticam Bajonet - https://makerworld.com/de/models/1346497-rear-cover-for-nauticam-wwl-1-bajonet-mount#profileId-1388138
Greetings from Switzerland,
Tino
10 minutes ago, Tino Dietsche said:
Hello everybody,
Downloads:
Tino
Nice. I solved that problem a little differently and made a tpu hood that stays on all the time, especially when diving.
Personalized:
Very interesting part we find here...
What I like are not the part (they are good) but the idea from the other... They are so many different methode / concept...
I really need to start again building my own parts... .but since 3 month... no time... to many work at work... I need holiday
  • 3 weeks later...
I created the attached N85 focus gear for a Sigma 10-18mm zoom on my Sony a6700. I took the Canon 8-15 zoom gear that @Chris Ross posted here, and modified it to fit the Sigma. I'm using the housing zoom knob in the NA-A6700, since my N85-N120 adapter doesn't have the integrated zoom knob (my preference, tbh). While I haven't tested it wet yet everything fits and zooms correctly.
A few notes/changes from Chris's model:
  • Added the four "guide nubs" on the geared end to help keep the gear aligned around the lens
  • Thickened the "front" end to make up for the smaller lens diameter from the 8-15mm
  • Increased the length overall from 41mm to 54mm
  • Used a few pieces of cloth medical tape to give the inside of the ring some grip in addition to closing up the clearance (honestly I didn't want to redo the model to make up for about 1mm total extra clearance)
  • When aligning the gear on the lens, you need to make sure the guide nub doesn't catch on the white raised "lens alignment" dot. It will keep you from using the full zoom range if it is in the way
  • An M3 locknut and 16mm m3 screw are used to tighten down the ring on the lens's zoom ring
Printing notes:
  • Printed in regular PLA, 35% infill, with a 7mm outside brim to promote adhesion to the print bed
  • Used a Bambu A1 Mini, and have the 3mf if anyone prefers that
N85 Sigma 10-18mm Zoom Ring v2-fixed.stl
  • 2 weeks later...
Hello everyone,
I've adapted my MFO-1 lens cover to fit my new SMC-3. Maybe someone can use it.
I've also adapted the lens cap for the CMC-2 if anyone needs it, and various other lenses are compatible with the Nauticam bayonet mount. If you're interested, just send me a private message.
I'm still working on a prototype for the MFO-3, but since it has a protective ring on the front, it requires a modified design.
SMC-3 Cover
https://makerworld.com/de/models/2463780-front-cover-for-nauticam-smc-3#profileId-2704602
rear-Cover for Nauticam Bajonet
Tino
Is there anybody a good printing solution for N85 focus gear for Sony 10-18mm f/4 (SEL1018) zoom on Sony a6400 (or similar A6xxx) in Nauticam housing (housing zoom knob). I'm totally noob for 3D printing but I have access to a printer and help.
I have printed a camera tray with three ball mounts to use as a tripod with strobe arms. I will be testing it next week in Roatan, and if it works out, I will post it here.
Well, that design was a failure. Once the arms were attached, the torque was too much and two of the balls snapped off. Once I get home, I will need to re-design that area of the tripod and get some additional strength there.
is there any reason why when downloading the stl file from maker world it downloads it onto my computer as a step file
Edited by Paul s
spelt incorrectly
Hello everyone,
My protective ring for the Nauticam MFO-3 lenses is now available online. The basic design idea comes from "flowdesign," whose ring I also used for a while. Tanks for this!
Since I've designed various things for SMC, MFO, and CMC lenses, I completely redesigned the protective ring.
Now I have excellent protection for my MFO-3 lenses both in the water and during transport.
Tino
https://makerworld.com/de/models/2548785-lens-bumper-for-nauticam-mfo-3#profileId-2806849
Cover for MFO-3 mounted on Nauticam Bayonet-Adapter for Transport
MFO-3 Deckel.stl
Well, it was a failure, The ball mounts were too weak, despite my reinforcing fillet, so I am currently redesigning it. Mk-II prototype coming up soon.
Perhaps the orientation might help with strength, I've seen some examples where people print stuff at 45° with a bunch of support, presumably to make the layer lines less likely to snap.
https://youtu.be/7aJ4dDyyf20?si=3T__uJ_6qiGAqx85
Consider boosting the strength of a ball mount by including a long M3 bolt inside the shaft and with a nut and washer tightened at the far end. Leave an opening on top of the ball to tighten the screw head.
That's exactly what I decided to try this time - except that I am using M8 bolts. Nothing like overkill, eh?
What I am trying this time is to increase the infill % to 55% and changing the infill pattern to gyroid. I don't have much room left on the plate to change orientation, I'm afraid.
Edited by SwiftFF5
I suggest losing the infill. Instead increase walls and perimeters until there are no voids in the sliced model. Walls are far stronger than infill. Long lines of filament are also stronger than layers, so consider printing orientation vs the expected stresses.
Cool, thanks. That will also probably add to the bouyancy and reduce the added weight in water - although perhaps that might not be a good thing for a tripod where a bit of negative bouyancy might be useful. I will play with that a bit, thanks, I appreciate the help. I am learning so much here.
Important Information
