On 11/16/2019 at 6:55 PM, DocTock said:- That power comes at a cost of eating batteries rapidly; to be "safe" the batteries were changed after every dive as one dive (~ 200 shots using 25%-100% strobe power setting) brought fresh off the charger Eneloop "Black" batteries from 100% (full green) to yellow advisory charge state.
Thank you for the feedback.
With the Original Retra Flash we had 4 lights: 1 red and 3 green. Green lights started to turn off once the battery voltage was decreased. Once the battery was drained only the red light remained.
With the new Retra Flash PRO/Prime we have a multi-color indicator with 4 colors for battery indication: green, yellow, red and a blinking red. These are divided into approximately! 25% steps - we can not determine a super precise percentage because it depends greatly on battery age, temperature, etc. This means that red light is 25%-50% battery and yellow is 50%-75% approximately(!). With a yellow light your will therefore usually have more than half the battery remaining. This may not be enough if you are expecting a longer dive but if you have a shorter dive coming up it could suffice.
In general the battery consumption is greater with the new Retra Flash PRO because of increased power on the pilot light and the flash output. This means you might need to recharge the standard pack of 4xAA batteries after a photo intensive dive. We recommend black eneloop pro batteries as they offer increased capacity compared with the standard white eneloops. We were getting about 25% more shots in our tests with the black eneloops.
An extended battery compartment is in the works and will be introduced in the coming weeks once the majority of pre-orders are sent. This new product will increase the number of flashes by approximately 2x and decrease the recycle time by approximately 0.5x. More details once it will be announced.
Also keep in mind that if you are using the flash and switch immediately to BATT/TEST mode the battery indication may not be correct as the battery voltage hasn't settled. In most cases to get the best measurement the batteries should have about 30 seconds off time before making the measurement.
