Jump to content
wet lens thread stuck on flip holder
Featured Replies
7 hours ago, insomniac said:
Too funny, I have the same exact strap wrench. In this case, I wasn't able to get it to grip well with the small surface area. The Irwin clamp happened to work easily and didn't damage the surface. Just wanted to give people a heads up of another potential tool to use. After breaking my last lens with the combination use of a vice clamp and induction stovetop; I figured I'de share something that worked this time around. But I agree, those strap wrenches are great!
I too, was about to give up with the strap wrench. Then, on the last try, it worked. Effectively, the irregular shape of the flip holder prevents the wrench making a firm grip. With the Irwin clamp you are able to apply the force on more specific spots.
For future reference, I had a CMC-1 stuck on a bayonet adapter and tried various methods including a strap wrench. All no-go. The one that did it for me was to hit the aluminum adapter ring with a heat gun and that will expand the ring just very slightly and allow the release of the lens threads.
Try sitting the flip holder in hot water. Keep as much of the lens clear of the water as possible. You are trying to heat the holder so it expands to make it easier to remove.
If you heat the lens also it will expand just the same as the holder and you will be in the same position as before.
Important Information
