O-Ring dimensions UW Housings generally
Featured Replies
Hi all,
current looking for spare O-rings for the Vacuum Valve for my Nauticam housing. Nauticam charges 15,-€ for this part. Which is a rip-off from my point of view.
May be we can open a topic where everybody who knows dimensions of O-Rings for UW housings will share his knowledge . So we can buy this parts manufacturer independent. My focus here is NOT mainly the big housing O-rings (would be nice too), but O-rings for accesories, ball mounts, threads, valves, flash sockets......
Br Markus
Yes, you are quite right in speaking out about the high cost -"rip-off" - of O-rings.
Some O ring replacement options are discussed here:
https://wetpixel.com/forums/index.php?/topic/69152-orings-for-sea-and-sea/&tab=comments#comment-437649
When replacing an O-ring, it is useful to keep in ming that all underwater equipment O-rings are metric (except Ikelite), and while most are made of "nitrile" rubber, some are "silicone".  Replacements must also be metric, but at times one can replace a silicone O ring with a nitirle one.
An O-ring size is described by its inner diameter and ring cross-section, in millimeters. It is best measured with a metric caliper, but a metric ruler may serve.
It can be a bit difficult to measure the i.d. of a large O-ring.  One trick is with a drawing compass, to draw a series of concentric circles about the inner diameter of the O ring, then overlay the O ring on the circles until the drawn circle matches the I.D. of the O ring.
Replacement metric nitrile O-rings can be found at The O-Ring Store, Backscatter Underwater Photo, eBay, Amazon, or thru a web search.  The price of a given O ring may vary widely, depending on the seller. For years I have bought from The O-Ring Store.
Good luck!
https://www.theoringstore.com/
https://www.backscatter.com/search?keywords=O ring
Edited by Kraken de Mabini
Important Information
