Jump to content
Subtronic Strobes
Featured Replies
On 7/23/2024 at 3:04 AM, Architeuthis said:
These are all very interesting comparisons. I would say that the intensity in the center is similar between HF-1 with 5500 K diffuser and Ikelite DS230 w/o diffuser. The carpet is, however, much darker with HF-1, compared to Ikelite. I interpret this the way that light distribution is clearly more even with the Ikelite w/o diffuser compared to HF-1 with diffuser...
=> This sounds pretty bad as even light distribution is something highly desired by everybody...
One must say, however, that normally for WA one uses two flashes and the objects in the center are normally lit by the periphery of the flash beams. The centers of the flash beam lit at most the corners of the scenery and these may be the problematic regions where light drops off in real life conditions (so more intensity there may be well a benefit). In the center the two flash beams add up and give good brightness.
I cannot remember that ever I had a problem with WA and two flashes, where the center was not bright enough due to uneven light distribution of the flash beam (YS-D2s and Z330s; all linear flash tubes) - unless the object in the center was close and I did not pull the flashes close enough together...
Maybe the more uneven light distribution becomes a problem when WA with a single strobe, but few people do this...
Wolfgang
 This is a great observation I didn't initially catch in reviewing my shots, Wolfgang -- you're right, center illumination (which is what I was measuring) may be the same between the circular flash tube strobes and the straight flash tube strobes with a diffuser, but the circular flash tubes throw more light towards the edges of the shot like on the carpet. I have a look through the comparison images I took again and now I do see a clear difference in light coverage between the circular flash tube strobes and the Backscatter HF-1/Sea & Sea YS-D3 and the Marelux Apollo 3 with their diffusers...
Basically, the diffusers aren't necessarily spreading the beam wider, they're just dimming down the center and thus making the overall illumination more even. But importantly, they're not really increasing the amount of light that falls towards the edges of the image. This is visible when you look at no diffuser vs. flat diffuser, but it's even more evident with the dome diffusers. In each case, edge illumination remains basically the same -- it's just the center that is attenuated, leading to overall more 'even' light intensity across the frame.
Makes me rethink my earlier conclusions about diffusers and straight flash tube strobes. If you care about edge illumination, it seems that what you really should be focusing on is how well the strobe performs without diffusers or light modifying accessories, as they don't (can't?) actually improve the brightness of the edges, they can only dim down the center hotspot.
  • Author
On 7/23/2024 at 9:54 AM, Alex_Mustard said:
I didn't know anything about this, but in my experience the service has change a lot for better. i had issues with one of my 160 pro fusion unit during a trip to Tulamben, the green led light was blinking while diving and the flash didn't fire anymore, so I sent it to Subtronic when I arrived home, in 30 days I had my strobe back again at home and working fine, they said it was an overheating issue and had to replace something inside. I paid 200 euros shipping incluided. I was all winter long using it while diving in Ibiza, then I went back to Indonesia, and the second day ( I'm not the luckiest guy) the same flashgun start failing again with the same issue, so I sent a very angry email to Subtronic, I had an answer in less than 12 hours, asking me to do something with the dials which didn't work, they said Sorry and I sant them back to Germany when I arrived home in Spain. In less than 2 weeks I had my strobe again at home, thay said than the first issue was caused by this other piece but they didn't detected it at the first time. They charge almost nothing for this repair  and I paid the shipping again. Now I am diving with it for more than 6 months, in the cold winter mediterranean waters and the last time was today with water in 25 ºC. No issues, they are working flawlesly. In october I'm going in a trip to the Red Sea. I hope I will not have issues again. But almost the service they give me was fine.
Yes, exactly! The better the strobe the more the diffusor is an option rather than a necessity! If the strobe has really good quality of light, you might find yourself using the diffusors only for special applications like CFWA and leaving them on land most of the time.
Actually I don't even own diffusors for my Seacams and used them on the Retras only to get warmer color temperature.
In your test shots, I think you can clearly see the Ikelite just lighting up the whole scene overall quite nice and even and other strobes having a much harder "fall off" towards the edges (floor, plant and the picture on the wall). Based on this test shots, the Ikelite would be my preferred one.
EDIT: sorry for OT!
Edited by ChrisH
  • 1 year later...
Hola,sería interesante retomar este tema,lamentablemente ya no podemos acceder a wetpixel para leer esos artículos,mi experiencia con los 160 pro (opto kit) de momento no esta siendo buena,el encargado de Subtronic es amable y correcto , los envíos a Alemania son caros y las reparaciones demoran bastante,es una lástima porque la calidad de construcción es excepcional , las pequeñas empresas en Eu tienden a desaparecer,el mercado chino lo absorbe todo,,si tienes algún problema te envían directamente un flash nuevo,sin protestar,mientras este en garantía,luego si se rompe lo puedes tirar directamente ya que aqui en España es casi imposible encontar un técnico general que repare flashes subacuáticos...muy lamentable pero así es hoy el mercado..a más electronica y componentes más probabilidad de fallos,,yo empecé con nikonos,eso si eran buenos flashes que no daban problemas,,el 105 fue la estrella ,y luego los ys250 pro y el ys 300 de sea sea eran maravillosos,,tempus fujit como dijo el rey de la Biblia...esto ya nunca será lo mísmo.....usar y tirar,ahí está el negocio....
siento ser tan fatalista pero son ya mas de 40 años en el mundo fotosub y he pasado casi por todo...un saludo.
A quick translation:
Hello, it would be interesting to return to this topic, unfortunately we can no longer access wetpixel to read those articles, my experience with the 160 pro (opto kit) at the moment is not being good, the person in charge of Subtronic is friendly and correct, shipments to Germany are expensive and repairs take a long time, it is a shame because the quality of construction is exceptional, small companies in the EU tend to disappear, the Chinese market absorbs everything, if you have any problem they send you directly a new flash, without protesting, while it is under warranty, then if it breaks you can throw it away directly since here in Spain it is almost impossible to find a General technician who repairs underwater flashes... very unfortunate but that's how the market is today.. the more electronics and components the more probability of failures,, I started with nikonos, that if they were good flashes that did not give problems,, the 105 was the star, and then the ys250 pro and the ys 300 of sea sea were wonderful,, tempus fujit as the king of the Bible said... this will never be the same anymore.....use and throw away, there is the business....
I'm sorry to be so fatalistic but it's been more than 40 years in the fotosub world and I've been through almost everything... greetings.
I fully share this view, and unfortunately it reflects a broader structural shift in underwater photography equipment and not just one brand or one product.
And I understand this feeling very well. I started underwater photography when nothing was automated : Nikonos III, then V, manual exposure, manual focus, manual strobe power, no histogram, no second chance. Every frame had a cost, and every mistake taught you something. That constraint was not a limitation; it was a school.
Back then, technology did not rescue you. It forced you to see: to anticipate light, to understand distance, to read water, to frame before lifting the camera. You learned patience. You learned discipline. And above all, you learned intention.
Today I shoot with a Sony A1 in Nauticam. I use TTL, HSS, fiber optics, focus tracking, etc.... Of course I do. I enjoy the precision and the efficiency. I am not nostalgic for missed shots or unreliable film. But I am very aware that modern equipment has shifted the center of gravity: from photographer skill toward system intelligence.
The irony is that while today’s strobes are technically extraordinary, they are often philosophically fragile. More electronics, more features, more integration, and therefore more points of failure, less repairability, and shorter lifespans. We traded mechanical robustness for digital sophistication. It was probably inevitable, but it was not free.
What worries me is not that equipment breaks. Everything does. What worries me is that repair has quietly disappeared from the equation.
I still have (and use) my so old SEACAM Housing for my analog Minolta Dynax 700si. Mosrtly for B&W photos....
When replacement becomes easier than understanding, fixing, or maintaining, something fundamental changes, not just economically, but culturally. Tools become consumables. Mastery becomes optional.
Brands like Subtronic belonged to a different logic. Not perfect, not fast, not cheap, yes, damn so expensive, but built to be used, repaired, and kept. Today, even premium gear often follows a “sealed box” philosophy: incredible performance, zero forgiveness. When it fails, you don’t troubleshoot. You discard.
And yet, despite all this, I still believe the essence of underwater photography hasn’t changed. Technology can assist, but it cannot replace vision. The best images today are still made by people who learned to see when nothing helped them. The danger is not modern gear, it is forgetting that skill came first.
So yes, the market has changed. Small European manufacturers struggle. Asian brands dominate with efficiency and scale. Use-and-replace has won. That is reality. But creativity, discipline, and respect for light are not obsolete. They just require conscious effort now, instead of being imposed by limitations.
We gained comfort. We lost friction.
And friction, sometimes, is what makes you grow.
That’s not fatalism. That’s experience speaking.
After an initial problem with a leaky cable, I have now been photographing with two Subtronic pro 160 units for more than 13 years without ever having any problems again. The Subtronic replaced the Inon 240 I had been using previously. In terms of flash power and illumination angle, the Inon is a poor toy compared to the Subtronic. The pro 160 is at least twice as powerful as the Iron.
Subtronic support has always been reliable, fast, and friendly. When it comes to quality, many manufacturers could learn a thing or two from Subtronic.
100% agree Jens. Used a few UW strobes (Inon D180, D2000, Z-240 Type2-4, Nikon Sb-800 with Sealux housing, Nikonos SB-105, Seacam 150D, Retra Pro Max, and Subtronic Pro270 + 160)
Subtronic had a very good light quality when there were only few providers in earlier times and they still offer good performance today.
While I used the Subtronics,  service was outstanding compared to other manufacturers .  Quick & cheap, always  communicative. They even modified the strobes to my liking for little money.
From my point of view a 100% + is that they still offer reliable repair service.
Anyone still interested in sustainability these days? Hmmmh☹️
Important Information
