Nauticam USB-C bulkhead mini review
Featured Replies
  • Author
17 hours ago, RuudStelten said:
Does anyone know if this piece of kit is compatible with the Isotta OM-1 housing? I just got off the phone with Backscatter, and they weren't sure as the lower ridge along the M16 bulkhead on the Isotta housing might not be wide enough to accommodate the insert. Has anyone tried this?
You are referring to the USB-C bulkhead? The Nauticam right angle plug only just fits through the special M16-M24 adapter, it has to be angled through, If you had a right angle USB plug you could see if you can squeeze it through the M16 on your housing, bearing in mind that . The Kraken bulkhead might be a safer bet as you plug the cable in from inside the housing and it doesn't need to go through the m16 hole.
  • Replies 76
  • Views 16.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Sokrates
    Sokrates
    I have the same trigger and it last for a long time. I use manual and not sure on the power setting (fairly low i guess), but i did like one week in a resort (3 dives per day) and the led flashed stil
  • eocean-eu
    eocean-eu
    I actually did that mod on the NA-GH5 with a reed switch (magnetic) but there is a big trick behind as you are right: the circuit needs to sense the vacuum forming when one to go from yellow to green.
  • Well, my Z8 has not been in the water yet, so cannot answer your question, yet, but I did purchase the USB bulkhead.  There are times in the past when I would have liked to do a battery change but was
Posted Images
Just need to order the old Kraken bulkhead. New one is perma attached like Nauticam and its M24 only. Looks like the isotta housing has three M16 holes.
New and old Kraken side by side (old on left)
