Jump to content
Preview of the MFO-2 - Now called MFO-3
Featured Replies
  • Replies 64
  • Views 12.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Alex_Mustard
    Alex_Mustard
    No idea. The normal rule in underwater photography is think of the maximum amount you can possibly justify or afford and then double it!
  • Alex_Mustard
    Alex_Mustard
    A point worth raising is that it is difficult to do really precise test shots with and without the MFO-2.  I just wanted to highlight this issue – as surely many with and without shots will be shared
  • Alex_Mustard
    Alex_Mustard
    I asked Nauticam to look into designing such a lens specifically because of the limitations of only having a one "decent" focal length macro lens on Sony FF (90mm) and Canon FF (100mm) camera systems.
Posted Images
On 9/23/2025 at 8:15 PM, Chris Ross said:
i have the lens not the port, i expect it will work just as well on any lens that works with it.
Thanks. They have it listed on their website as compatible with the 90mm in "normal macro" mode. I don't have a Nauticam housing and my port won't let me change modes underwater, I mostly use it set to "S-Macro" mode. When I emailed Nauticam asking if it would work in S-Macro they said: "For MFO-3 to work well, the lens needs access to its entire focus range."
So I may be out of luck!
I think it would only focus very close to the port so defeats the purpose. I guess you could use it in normal mode and also carry a closeup diopter if you want greater than 1:1.
I would be really curious to try it with the PanaLeica 45mm macro.
I'm currently doing a project, mostly macro, in murky water, but in the same dive, I also find subjects that are 20/30 cm large. I'm diving with the Pana 14-42mm with a flat port and the CMC-2 mounted on a flip adapter. This way, in the same dive, I can do both moderate macro and medium range. Theoretically, it seems like a great compromise, but in practice, I am hating this setup.
Yesterday, I was filming a 3 cm blenny playing hide-and-seek in tunnels dug into the coral. With the CMC-2, I could film it in detail. Then, I wanted to take some wider shots to show the context the blenny was moving in. The 14-42mm zoomed to 42mm with the CMC-2 has a focus range of 77–124 mm. Even if I reduce the zoom and moved further away, I immediately go out of the focus range. But if I take off the CMC-2, the 14-42mm has a huge (MFD. Underwater behind a flat port at 42mm, the MFD goes up almost to 50 cm. Basically, I have a "hole" in the shots I can get—from too tight to too wide.
Ah, I know, I can't have everything in life, but an MFO-3 and an EMWL, yes I can! 😂😂😂
Seems like you'd be uniquely served by the Olympus 12-50ez, it's a weird lens but extremely versatile.
It's a macro port too. Old but quite unique.
Nick Hope, a glorious WP member, used it for most of his underwater videos.
His videos have more visualizations than the BBC' ones
I have one in the regular macro 65 port so can't change to macro mode but I find it extremely versatile. At least as a general use lens combined with a mild diopter for larger macro subjects. Internal zoom makes it work very well with wet optics.
for that specific case the MFO-1 might serve you well, as it basically just gives a small lick of magnification but pulls the focus range in. It would be more compact for sure. Otherwise a +5 diopter like the INON UCL-165, or that +3 diopter Alex Mustard used, which are much cheaper., but maybe not quite the image quality. I would think though that the MFO-3 would be nicely versatile with the 45mm macro giving you a 26mm approx equivalent FF lens.
Yes, this is what they recommended. However, the whole point of me switching from the 60mm to the 90mm was so that I didn't need a diopter for super macro. Oh well, maybe once the new generation of OM cameras comes out I'll switch from Isotta to Nauticam just for the port with the selector switch!
  • 1 month later...
Did anyone test MFO-3 on a housing other than Nauticam?
I currently use Isotta with S&S ports and a Saga flip with M67. I’m not sure the position of the thread, not at the end of the lens, could cause problems using other flip holder than Nauticam.
It comes with an M67 adapter that you thread on so that the threads protrude from the end like a regular diopter or filter. I think it shuould be fine with most flips.
Thank you Chris, I was told that it is better to check if you mount on a different flip other than Nauticam.
I’m thinking of buying one paring with the Nikkor 105mm… GAS
Mount on the x-adventurer flip, without adding M67 adaptor, it works fine. So I'd agree with Chris, most of the flip shall be ok.
  • 3 weeks later...
Adding to the MFO-3 posts, I had a chance to try the lens with my A7C and 90mm macro in our wonderful Puget Sound Seattle water yesterday AM. The rock fish pics are with the MFO-3 and without, from about the same distance from the fish. The Sea Angel was just flapping in the water column and is about a centimeter in length, so approximates a lot of the Hawaiian blackwater critters.
For blackwater, I think this provides a very nice solution from what I'm seeing. Storing the lens is a little more difficult than the smaller CNC diopters and I usually use the bayonet mount. I can see why a flip holder is going to work out a better! There was also negligible weighting issues with that lens being so far out in front. Only one dive so far, but this looks like a great lens.
Important Information
