Design for a Universal Dome Port Hard Cap
Featured Replies
  • Author
The WACP-C port is big enough with that float that it would probably make more sense to replicate the Nauticam design with a spring clip on the inside. But I would likely need the port to do it. Unless it has identical dimensions to the WWL-C, which I have.
Edited by Dave_Hicks
Bummer I can not provide dimensions or send in the port at the moment…
Edited by Lauren Wang
20 hours ago, Dave_Hicks said:
A cap needs to hold on to the port. My standard rubber design grabs the overhang of port with bungees.
I would need the outside diameter of the port and distance from the tallest leaf of the shade to the underhang.
And a photo of the original shade.
Hi @Dave_Hicks
My thought is to have a cover that simply covers the outer shade, not including the float collar. Attached are some images.
To the best I can determine, the shade dimensions are:
5.75" as the outer diameter of the lens shade at the top
  • I am not able to determine if the base of the shade is the same as the top
1.75" as the height of the tallest point of the lens shade
Bungee cords cross wrapped around the float collar would hold it in place. The current design of clipping inside of the shade is attractive, but also can easily come off if bumped just right while in the water.
Having a cover that would cover the entire float collar would be too big for my taste to carry during a dive. A cover around the shade only seems to offer some protection while not becoming cumbersome during the dive.
What are your thoughts?
Edited by ChipBPhoto
  • Author
3 hours ago, ChipBPhoto said:
Hi @Dave_Hicks
I agree. Cover the OD of the leafs and with an inner wall to to pinch the groove inside the tree tall leaf shades. Perhaps a thin elastic rubber collar at the top of the float to capture bungees.
Now i just need a WACP-C, FCP, n100 Sony 90 & 100mm macro ports.
Covers and float collars for these are all on my ToDo list.
  • 2 months later...
I'd love to make a cover for my secondhand WWL-1 that was missing a front cover.
I haven't checked out your model yet to see if I can do it myself, but will take a crack on the weekend.
Dimensions here for reference, or if the full model isn't accessible.
OD: 126mm
Shade height: 46mm (ignoring the fastening screws which protrude a further 7mm)
  • Author
OD: 126mm
I can add the WWL to my existing shared model. Check again later today.
However, based on several requests, i am going to try to make a WWL-1 style spring latch hard cover. For both WWL and 140mm Nauticam ports. Older 140mm ports don't have the notches inside the shade (the new Sony does) so it may also include a new shade.
  • Author
OD: 126mm
https://makerworld.com/en/models/2391039-universal-dome-port-cap
Added a model for the WWL-1 port. This will not fit on the WWL-C, which has an integrated float making it taller.
  • Author
37 minutes ago, ubiquitous226 said:
Thanks, really appreciate that. Will give it a whirl over the next two days.
Please let me know how it works as I don't have the WWL-1 to test. The one question is if the bungee holes are properly positioned. You can always punch new holes if they don't fit. If they need to be moved send me some details so I can fix it.
Yeah naturally I didn't think of the hole location so didn't give any details on the shade placement (for the record small shades about 27mm from base and ~70mm wide, taller shades 46mm high and ~110mm wide).
It's very close to the right spot, I'll give it a go as is and if I find the bungee knots are interfering with it fitting properly I'll make some new holes.
I used translucent TPU 95 so it actually helps to see the hole lineup more easily.
In terms of overall fit it is quite snug which is fine above water but not sure how I'll go taking it on/off underwater if I go that way.
I'll feedback once I get the chance to test (hopefully next weekend).
Edited by ubiquitous226
  • Author
Yeah naturally I didn't think of the hole location so didn't give any details on the shade placement (for the record small shades about 27mm from base and ~70mm wide, taller shades 46mm high and ~110mm wide, total circumference ~420mm).
Is it just a effect of the photo, or are the sides of your print concave? I've not seen that before. That could account for the tight fit. My TPU95a covers have all been nice and straight. I wonder if that is a settings or speed issue. I typically print TPU very slow, like 30-50 mm/s maximum. You can speed things up a bit by using a .24 or .28 layer height, or even a 0.6mm nozzle at .3mm layers.
The hole positions look good. The design intent was to have the hole above the low parts of the shade leaves.
And a few more photos, bungees seem to fit fine as-is with hole placement, if there was a reason to make any other changes slightly wider would be probably be perfection but very happy with it.
Yes it does slightly bow in, it sits straight after printing, but it's stretching slightly around the base which I now realise I neglected to notice was slightly wider than the top of the shades, and adds about 3mm to the overall diameter.
It'll work as I've got it as the TPU stretches.
Massive thanks to you, looking forward to testing in practice.
  • Author
Got it. Thanks for letting me know it needs to be bigger. If you want to try to print it again, just scale the X&Y (not Z) by 102.3% to get an extra 3mm diameter.
I just updated the project on Makerworld to add 3mm of internal diameter to the WWL-1 cap. You can re-download if you don't want to resize.
On 5/11/2026 at 8:02 PM, Dave_Hicks said:
New product promotional image for the TPU Dome Port Covers:
Turns out that the Giant Pacific Octopus is a fan of these too! A GPO climbed on my camera and tried to steal my dome cover. Sneaky little sucker almost tore it off and made a quick getaway! It also managed to turn the zoom knob and made the lens (Nikon 8-15 w/1.4tc) vignette a bit. :)
What a shot Dave!
I think that'll work well for anyone else looking to make it, I'll give what I've printed a go as I think it's well within the workable range.
If it becomes a bit hard to manage taking it on and off underwater I'll reprint.
