Remote trigger
Featured Replies
Hi everyone,
A question came to mind while thinking about a few shooting situations.
Do any of you use a way to remotely trigger a camera or start video recording underwater?
I’ve found myself wishing I had something like that a few times, especially for cameras left on the bottom or when trying not to get too close to shy subjects.
Just wondering if this is something people actually do in practice, and if so, what systems are being used.
Thanks!
Remote control has been a core technique for my UWP of salmon for over two decades. There are many pix showing set-ups on my web site at: https://www.salmonography.com/Salmonid-Topic/Photography-techniques/n-mnzBPB They are in chronological order with newer ones first.
They show Seacam housings most of which are set up to use the Seacam remote control. https://www.salmonography.com/Salmonid-Topic/Photography-techniques/n-mnzBPB/i-ChFJBmw/A shows a set-up placed on the ground. In this pic you can see the bulkhead near the bottom of the housing where the remote is plugged in as well as the remote control “stick” at the other end of a 10-meter long cable, my standard length for remote control. The button on this stick works just like the shutter release button on a camera body (at least for Canon and Nikon, the brands I have used).
A light touch on the release button wakes up the camera (if the camera is asleep) and turns on the autofocus (AF). A further push triggers the camera. As the AF technology has improved over the previous two decades I have had to adjust the timing between the first touch and the triggering to allow the camera to focus. I often took a full second way back when, following advice given by Chuck Westfall, the late Canon tech rep, on the net. Here is one example: https://digitaljournalist.org/issue0506/tech-tips.html This is not the one I recall reading which may have been on DPR or Photo.net. Regardless, it is important to finesse the AF system a bit especially if one is using a more computational type of AF such as auto-area which is what I use with Canon. Nikon came out with a similar mode starting with the D4 generation. The many shots on my website suggests this works.
There are other makes of remote control besides Seacam. I have used the Aquatica remote with the Nikon D1x which I installed by disconnecting one of the N5 bulkheads from the hotshoe fitting and installing a cord with a fitting for the Nikon 10-pin socket on the camera. The Aquatica remote uses Ikelite cords that connect with the N5 bulkhead as opposed to the S6 bulkhead used by Seacam. The Aquatica release does not separate the wake-up-AF-on and the trigger functions; it is just a simple switch so I connected two of the three wires on the inside of the housing (that goes to the camera) and only used AF priority. Nonetheless the first shot in a series was typically OOF when using the Aquatica release. It might be better for video but I have zero experience with that.
Reef also makes a release. See: https://reefphoto.com/products/zen_remote_release_handle. It is a bit cheaper than the Seacam and uses Ikelite cords. I have not only not used it I not even seen one in person. Hopefully someone will provide you with some info on this.
The Nikonos RS had a remote control as well. I modified mine to work with the D1X because I could separate AF-on from triggering. The RS release is a piece of junk compared to the Seacam one. I will leave it at that.
Cheers!
Tom
Edited by Tom Kline
  • 2 weeks later...
  • Author
Hi Tom,
Sorry for the late reply, and thank you very much for taking the time to write such a detailed answer. I really appreciate it.
I had a look through your photos. What an impressive body of work! It’s fascinating to see how you’ve refined your remote setups over so many years, and your explanation of the autofocus timing was especially interesting.
My question actually came from thinking about something a bit different. I’m wondering whether a wireless remote trigger could be made reliable underwater. There are a few situations where I’d love to place a camera on the bottom or close to shy animals without having to stay connected by a 10 m cable. I know radio doesn’t travel well underwater, so I’m exploring other possibilities and trying to figure out whether it’s technically feasible or just an idea that sounds better than it is.
In any case, your reply gave me a lot of useful background on the existing wired solutions, so thanks again for sharing your experience.
Jim
Edited by JMB
You might look at the wireless protocol used by Halcyon for their new CCR controllers. They seem to have both range and bandwidth. Likely proprietary and expensive however.
Thank you Jim, glad you found it useful.
To your question: About a decade ago a visiting Swiss photographer used a wireless remote control by placing the device in a floating small sized Pelican case that was wired to his housing using a cable similar to what I use. You might be able to build something like this yourself.
Another solution, which I have used, is to trigger an underwater camera using a built-intervalometer. None of my Canon 1D type cameras had this so it was not an option for many of my shots (I have used four different 1Ds). First use was with a Nikon D3X. Its limitation was a maximum of 999 intervals which is not many shots when it comes to salmon. I selected 3 shots per interval but this was more of a band-aid solution. More recently I have used the intervalometer in my Nikon D4S which allows 9999 intervals so is far more useful. As well the intervalometer works well in conjunction with a remote cable, for example, I used the intervalometer to take a shot every 15 seconds as a back-up in case I was away from the release stick or the release stick ceased to work (this has happened). Most shots were done with a cable. I remember this shoot because I drained the battery in the D4S with the very last shot (of over 10K) showing actual spawning. Needless to say a lot of files had to be culled.
Intervalometer shooting is also useful for angles where one cannot be close enough to observe such as on the far side of a stream relative to a primary housing.
Also one has available the full use of two hands to move a polecam rig while the camera keeps on shooting. This was how I managed to get multiple perspectives when shooting the underwater shots for this gallery: https://www.salmonography.com/Salmonid-Topic/Family-ties
You can see in the topside shot included in the galley that I was on the ground right next to the stream and the camera pole was aimed towards my left side (can only see one of red sneakers I was wearing over my waders in the pic). As well, this particular housing has just two bulkhead holes, one for the flash synch and the outer for a “remora” (a common name for remoras is shark sucker but mine is a housing sucker!), so I was compelled to use the intervalometer.
Edited by Tom Kline
Tom is an expert when it comes to remote triggering. Just for fun you both may want to checkout the Marelux remote trigger module which is triggered from up to 10 meters using a blue light. The Marelux.co web site includes a video of the product being used. It can be found under products in the innovative products section. it is designed for newer Marelux housings that are equipped with a small port to detect the blue light. It mounts under the camera tray.
42510 Remote Shutter Module Patent of invention
Material: POM
Dimensions: 72mm(W) 30mm(H) 30mm(D)
Weight in Air: 37.5g
Effective receiving distance : 10 meters
Optical signal receiving angle : 140 degrees
Equipped with a built-in battery that supports charging via the USB-C interface
Compatible housing models: MX-R5II, MX-R6III, MX-A7V, MX-A1II, MX-A6700, MX-Z6III, MX-GH6/7, MX-S1RII
