Jump to content
sony 28-60 zoom gear/knob
Featured Replies
Posted
Does anyone know if there is a Nauticam port solution for sony28-60 and wwl-1 without the focus knob?
I just purchased the 28-60 and N100 flatport 45 with focus knob, after years of using the 28mm.
I thought the focus knob on the port was for zooming the lens, but as it works with the zoom knob on the housing, I have no need for the knob on the port, as I never use manual focus with that combo.
It's not a big issue. Just wondering..
10 minutes ago, Alex_Mustard said:
Are there instructions anywhere for removing it?
Looking at the nauticam website I find this manual with instructions to do so:
https://drive.google.com/file/d/1eqjAuRyQbazThYDkdThLO0zsoLvzdktJ/view
Now I look at it, the assembly on the product picture does not look the same as the illustration in the manual so I suspect there are multiple versions of the port.
Edited by Robin.snapshots
There was a post asking a similar question possibly for a similar port a few weeks back,  The response was that the port now comes with a blanking plug and there are instructions for installing it.
I found what seems to be a universal instruction set for various focus knobs and their installation - this is for extension rings.  It should be easy to work out if it applies to your port if you have one.
https://www.panoceanphoto.com/factsheets/NA22131_Focus Knob Bedienungsanleitung Nauticam-en.pdf
  • Author
There was no plug included in mine. I got it yesterday. Called the dealer and asked if there was a plug, and he said no.
Just wanted to ask here, before I settled with a no.
Indeed, the port is normally delivered with a cap and instructions for disassembling the focus button
Look at mine:
Agreed.  For what it’s worth, my 45 port is about 3 years old and has a different plug - round vs. square plate.  It came with the plug in the box and the dealer removed the knob/gear as it was not needed and just gets in the way.
Love the WWL!
Edited by ChipBPhoto
In the box there is a blind plug
what you need to do
1. pry the black covers of the allen bolts using a tool that doesn’t ruin them
2. unscrew the two bolts
3. replace the assembly with the blind
4. Screw back the allen screws
5. place back the plugs
Important Information
