Retra strobes
Featured Replies
Hi all ,
A friend has just bought some Retra Pro Max strobe and one of the Led screens is upside down, bearing in mind i have had mine for about 6 months and as i have not been night diving didn't notice i have one upside-down ,anyone else ?
6 hours ago, Griffer said:
Hi all ,
The screen is supposed to be flippable:
https://www.retra-uwt.com/products/retra-flash-pro-max?srsltid=AfmBOooOSX45hVriyk1kCezfA8lVTTvdBWtdCbm7l-Tu0dXEQsKtQ9Bd
it says:  "You can also flip the LED screen on the Retra Flash Pro Max by 180°, allowing you to use it in any orientation."
I assume it should be in the manual, otherwise contact Oscar by PM, he's generally very helpful.
I assume it should be in the manual, otherwise contact Oskar by PM, he's generally very helpful.
  • Author
Yes guys thank you very much i had just discovered this while playing with the strobe ,turn all the way to the U setting and back and it flipped .normally only used in manual. As Tim  said now feeling stupid but this is the idea of Waterpixel to help us stupid old folk.😀
Hi, sorry for the delayed response, I usually follow what is posted in the strobes and lighting forum.
By moving the mode dial to position SOS/TURN the screen will flip or rotate or turn 180deg. The strobe will remember this position even when you switch off and exchange batteries so you don't need to select the orientation each time.
  • Author
Thank you Osker   I found out by accident and then watched a Retra video by Alex Mustard and he turned the dial and it flipped .many thanks for the reply.
