Sony 28-70
Featured Replies
Has anyone shot the basic Sony 28-70 behind WACP? I'm asking because I was doing some cleaning and found that I had it, but never used it.
How does it compare with the 28-60 (which I own and love for its size/quality).
Thank you
  • Author
Thanks, I was asking on 28-70, not 28-60 which as you said has been well documented. I'll check wetpixel if it still works!
  • Author
Thank you, i believe they were referencing the Sony 20-70f4, which is a different one than the 28-70 i was asking about.
However i did find a comment on wetpixel from Phil comparing both 28-60 vs 28-70, and he mentions he prefers 28-60! (Feb 2021)
Thanks!
Thanks!
Have a look at the table they are comparing 4 different lenses to the 28-60 and saying the 28-70 is not as good as the 28-60.
Copyright © 2025 WaterPixels. All Rights Reserved Powered by Invision Community
For the original poster, Alex I have used both the Sony 28-60 and 28-70 kit lenses with WACP-1 (native N120) and both also work with WACP-1B (native N100). The 28-70 uses an additional 20mm of extension, does not focus as fast as FE 26-60 and if you look at many land reviews the 28-60 out performs the 28-70. In real world use with water contact lenses you won't see large differences between the two lenses in terms of IQ. I don't think it's a big mystery that a kit lens introduced by Sony in 2021 would have improved over a Sony kit lens introduced in 2013.
By the introduction of the WACP-C I had sold the 28-70 so can only comment on WACP-1, however I would expect results to be about the same. Since I rarely used the 70 or 60mm end of the lenses I don't miss the difference. Any comments from wet pixel you may have seen would I believe reference overall performance not just IQ. I have found best results with both lenses to be in the F/8 to F/11 range even though with full frame my normal starting point is F/13+/-
I reviewed the WACP-C and both the WWL-1 and WWL-1B in past issues of UWPMAG.com.
As a sidebar the first Nauticam wet wide lens I tested was the WWL-1 and I used the Sony 28mm F/2 lens for that review because 28-60mm was not yet released. Nauticam still offers an N100 32 flat port for that lens but it is not shown on the port charts for use with WWL-1/1B.
Last what is hardly ever talked about when involved in a wet wide lens discussion regardless of brand is Depth Of Field. While many of these lenses advertise a 130 degree diagonal AOV it has become clear to me and many others who have used these lenses extensively that DOF is far less than what you get with a lens of the same 130 degree AOV behind a dome port. This became blatantly obvious to me when I tested the Laowa 10mm F/2.8 a 130 degree rectilinear lens against images taken with wet lenses of the same130 AOV.
Edited by Phil Rudin
Hi Phil, one thing to note is that in reality the WWL is not equivalent to a 10mm rectilinear. They both have a 130° Diagonal field of view, but the horizontal field with WWL/WACP is about that of a 14mm rectilinear lens which has a 104° horizontal field while the 10 mm Laowa has a 121° horizontal field. This is due to the barrel distortion stretching the corners.
So the correct lens to compare it to is a 14mm rectilinear behind a dome. The 14mm has more magnification and so less DOF. Would you say that the WWL still has less DOF than a 14mm rectilinear behind a dome?
The short answer is yes, also keep in mind that I found WWL-1B to be noticeable wider when used with the Marelux N100 to 5 inch, 17mm adapter. I have used Laowa 10 & 12mm, and at least four different versions of both 14mm and 14mm zooms that have all had better DOF. This is an issue I was discussing with a well known U/W photographer at DEMA who has compared fisheye water contact optics V. lenses like Canon 8-15mm in 140 to 230mm domes and he remarked that the differences are even greater with fisheyes.
I have used 28-60/70 zooms and the 28mm F/2 and DOF at 28mm is about the same across all of the wet optics I have tried that are advertised to be 130 degrees. With WACP-2 you can use lenses up to 14mm and DOF then improves.
Thanks for the clarification Phil, I recall people saying the FCP had noticeably small depth of field.
FCP is not a lens I have used so no first hand knowledge. I have however heard similar feedback from some that have used FCP.
Perhaps a new thread should be started to hear others opinions.
Interesting! Could you clarify which of the two has more DOF ?
Or better rank all three optical options, with best DOF from 1. 2. 3. top down?
Important Information
