Jump to content
Nauticam/Canon WA questions
Featured Replies
  • Author
46 minutes ago, Chris Ross said:
Try again:
https://waterpixels.net/forums/topic/1438-testing-nauticam-n120-port-extension-for-140mm-and-180mm-domes-with-wide-angle-lenses/?&do=findComment&comment=13817
The links on the forum are not active everywhere in the box, you have to hover over the title, caught me out a few times, hopefully this link works, it's just to show minimal difference with a change in extension on a fisheye.
Thanks, this link works.
Actually, I was already reading the whole thread a few days ago (before I started this thread).
  • Replies 51
  • Views 2.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • There have been various posts talking about the pros and cons of the various combinations of lenses and Nauticam wet optics as well as comparing performance of rectilinear lenses behind various domes.
  • BrightSea
    BrightSea
    waso, I am attaching a couple of images, no crop, no edit, so you can look pixel peep if you desire, of course there are different f/stop depth of field varies and images resized to enable upload here
  • Adventurer
    Adventurer
    Thankfully Landvogt1893 send me the RAW files and we can have a look at the two uncorrected RAW files to learn how much of the image is actually black and artificially generated. I have activated Ligh
Posted Images
..and that should have brought you to the conclusion not to use WWL on Canon Naughtycam Systems and put a 3rd party dome on your shopping list.
Please report back WASO once you have some shots with what you bought.
  • Author
Actually, the WWL was never on my shopping list.
Before I started this thread, I was almost sure to buy a WACP-C.🫢
After Christmas, I will first buy and modify the Commlite RF/EF adapter to determine how big the IQ difference is compared to the older Kenko and after that, I'll probably buy the 140mm FE Port.
Actually I also had a long period, where I thought, I might be missing out on something, not owning a WAPC-C or other Nauticam Water Contact Optic. They are just so heavily hyped and raved by various (officially not paid) talking heads on the internet.
The death sentence for WAPC-C was this very honest review by Interceptor121 :
Interceptor121 Photography & Video Workshops
No image preview
Nauticam WACP-C vs WWL-1
I am conscious that a post like this is destined to create some stir, however it reflects over one month of testing of the two Nauticam water contact optics with my A1 and summarizes my conclusion …
Wrap Up
As you can see by yourself there is really nothing between the two optics and clearly the difference between the wet and dry version is simply in the ergonomics and of course the price. For me there is no reason to consider the WACP-C unless you have serious issues with a wet mount.
Edited by Adventurer
  • Author
Thanks for the link!
It will provide me with good entertainment for this evening. 😁
  • 4 weeks later...
Is there a decision by now? I’ve also been searching for the right ultra-wide-angle solution for a long time.
At the moment I’m using a Canon R5 with the 15–35mm f/2.8 and an 8.5" acrylic dome. With the 70 mm extension, the acrylic dome always tends to float upwards, which really annoys me.
I’ve also tried the EF 8–15mm, both with and without the 1.4× Kenko teleconverter. However, I don’t always find the fisheye look to be the right fit.
I also tested the RF 24–50mm with the WWL-C. I actually found the image quality to be very good, and a friend of mine uses the same combination as well — mainly because of the lower weight and the versatility.
  • Author
No decision yet.
Right now I'm busy selling off the remaining Seacam equipment and a few Nauticam items, ordering the Commlite adapter and then testing it in comparison with the Kenko on my 8-15.
Personally, I'm not interested in a rectilinear wide-angle lens behind the dome as the optical quality has simply been too poor in my experience.
If you have sample shots and 100% crops from the corners with your RF 24-50/WWL-C, it would be nice to have a look.
On 12/29/2025 at 1:50 PM, Adventurer said:
I’ve been examining the Canon RF 24-50mm STM lens on full-frame bodies and noticed something important: this lens, often recommended by housing manufacturers, does not actually project image corners onto the sensor at 24mm and not even fully at 28mm in uncorrected RAW. In other words, the much-discussed corner sharpness that underwater photographers focus on isn’t even present at those wide ends, because the image simply doesn’t cover the full sensor corners natively.
It's very ironic that you start to discuss about corner sharpness performance of a lens that does not project corners at all to the sensor 🤣 😂 ... But I am 100% with WASO and would love to see some RAW files with that lens + WWL-C.
If you mean me – where did I say that the corners are super sharp?
Yes, I think you are the man who can provide RAW images required by waso. But no, about the sharp corner part that was requested requested by waso, not you.
So do you have an underwater RAW file at @24mm hand, you might want to share?
It might also be interesting to find out how hard the black corners still come through with the camera submerged + WWL-C attached and at what zoom level ( @28mm @30mm ? ) there will be real corner projection onto the sensor by this lens combination. As I did buy the lens and also have a zoom gear for my housing, I am still pondering with the Idea of adding a wetlens in front to figure out if it is really worth it. I would be very thankful if you @Landvogt1893 could contribute it to this thread with image examples:
The lens needs to be corrected; otherwise, there is noticeable vignetting at 24 mm. That’s why I was surprised by your statement that you find it ironic, especially regarding corner sharpness.
Overall, this lens in this combination is a good compromise, but it’s not for pixel peepers.
Booth are taken with 24mm.
Send me a PN and i will give you the link to my onedrive with the raw´s
1/200 F10 ISO 320
1/200 F9 ISO400
Edited by Landvogt1893
I believe what is happening is the lens has a lot of uncorrected barrel distortion and relies on software correction. Barrel distortion stretches the corners out and the corrected image needs to be cropped after correction. So Canon designed it a bit wider than 24mm to accomodate the cropping and the end result is black corners in the uncorrected image.
There may be some benefit in in shooting uncorrected and zooming in till the vignetting stops as you really mostly don't need the corrections UW, it's no different to shooting a fisheye. If you don't do the software correction to remove the barrel distortion the overall image quality can improve. Whether it's worth the trouble I don't know, you would have to manually pick the widest zoom setting you can live with on the uncorrected lens and it would be fiddly.
I agree the lens is a compromise, it seems like there might be sample variation as well, some land reviews give it a poor rating and others say it is quite good including sites that do performance testing.
On 12/12/2025 at 1:36 PM, waso said:
Hello,
as a user of a Canon R5 and a newcomer here in the forum (though I've been with wetpixel for many years), I'm currently switching from Seacam to Nauticam and my main question is about wide-angle - what else 😁.
For many years I photographed with the Canon EF 8-15/4 (often in combination with a Kenko 1.4x TC) behind a superdome or the small fisheye macro port (CFWA).
Now I would like to photograph with even better corner performance and more compact dimensions in the future, and therefore I was considering the Nauticam WACP-C.
Unfortunately, I can't find any informative reviews and/or images online about the best(!) camera/lens combination for Canon FF mirrorless cameras.
The RF 24-50 is recommended, but I'd like to know if, for example, the Canon RF 15-30 STM might offer better image quality (it only has 85° at the long end), or if an older adapted EF lens (e.g., the 28-80) would be advisable (it has 54° at the long end compared to the RF 24-50's 81°, so it would be much more versatile).
Or would I ultimately achieve comparable image quality with my old 8-15/4 lens in combination with the Kenko 1.4x TC? I'd probably have to stop down significantly more to avoid corner softness, even behind a super dome.
I also read here in the forum about the combination of the EF 8-15/4 with a 2x TC on a Sony, but I don't know if that works with Canon.
I know that the WACP-1 has up to 1 stop better image quality than the WACP-C (probably only visible in the corners), but the WACP-1 is simply too heavy - and a little bit too expensive for me as well.
Currently, I only own a Nauticam 8.5" Acrylic Dome Port (SKU # 18802) that came with the 2nd hand housing, which I could use with my Canon 8-15/4. However, I don't know if the image quality would be acceptable.
And btw: is there a WA lens recommended to the 8.5" Acrylic Dome?
Or does anyone have completely different considerations regarding excellent WA IQ?
Btw: I own a RF 14-35/4 and still have the EF 8-15/4, of course.
I'll definitely buy a Super Dome later at least for split or wreck shots... well, and I read here in the forum that a 140mm Nauticam dome is hardly recommended for the 8-15/4.
I would be grateful for any helpful answers!
Best regards,
Wahrmut
Hello, I shoot R5, for wide angle I chose the Canon Rf 24-50 with a WWL-C, it seems to have a sweet spot that is not so wide, the ability to close focus is a lot of fun, if was a very affordable option and travels well compared to WACP lenses. The ultimate would be Nauticam FCP, out of my budget, for now I use my very affordable set up and do not pixel peep.
  • Author
1/200 F10 ISO 320
1/200 F9 ISO400
Is it possible to get 100% crops from the corners (as I posted with my images above)?
It would probably be interesting not only for me.
  • Author
Thanks for your statement.
Would you mind showing some images with crops from the corners?
Sure, will do this evening after home from office.
waso, I am attaching a couple of images, no crop, no edit, so you can look pixel peep if you desire, of course there are different f/stop depth of field varies and images resized to enable upload here, not sure if that affects how you can see the quality of the lens performance.
Edited by BrightSea
Thankfully Landvogt1893 send me the RAW files and we can have a look at the two uncorrected RAW files to learn how much of the image is actually black and artificially generated. I have activated Lightrooms overlay to give you a better idea of the dimensions. If you want to shoot 4x5 you still have some black corners, but much less, which you could also fill with Photoshop's content aware fill:
There seems also be some lens flaring in the 2nd image provided. Here is one of the corners, Waso was so curious about:
I have also made this illustration of the corner to show you where the lens correction moves the corner to fill the frame:
So, what do we learn from this? In my view it’s quite surprising to spend more than $1,000 / €1,000 on the Nauticam WWL-C for dismal results like these - especially when strong in-camera corrections and additional processing make the output look somewhat “artificial”. Especially if you could also have gone for the much cheaper INON UWL-95S (roughly half the price) and achieved similar ( or maybe even better ) results, with a more compact setup - assuming you’re pairing it with the Canon RF 24–50mm STM. 🫣
At the same time, in some parts of the world the WWL-1B and the WWL-C cost the same - or the WWL-1B is even available for less. Considering that the WWL-1B (optimized for 28mm) also has a reputation for higher image quality than the WWL-C (optimized for 24mm), I don’t really understand why Nauticam doesn’t recommend zooming slightly to 28mm and choosing the WWL-1B instead of the WWL-C.
  • Author
Thanks for the pictures!
Do you know if they were all taken at the minimum focal length?
Can you use the 24mm lens without vignetting?
Could you perhaps show 100% crops from the relevant corners?
The lens correction is removing barrel distortion and you can demonstrate this on a fisheye image with the lens correction tools in your IP program. Here is an example image taken with a Panasonic 8mm fisheye:
If you use the lens correction tool it removes the barrel distortion at the cost of a reduced field of view:
You can see that the image has lost the edges and it hasn't even been fully de-fished yet, so it doesn't actually stretch the image into the corners, but crops them out. I expect the lens correction on the 24-50 does something similar and I expect what Canon has done is that the 24-50 is actually wider than the a standard 24mm lens, knowing full well it will lose the corners when the barrel distortion correction is done. Unless you are doing raw conversions in Canons software the correction will be done using Lightroom's standard lens correction tool. It would be an interesting exercise to compare an image cropped out of the raw file with one that is automatically corrected and also to determine if the 24-50 has the same maximum field as a regular 24mm lens.
It doesn’t matter Chris, in both exercises the corners massively loose image quality and resolution (sharpness).
The lens is 24mm FOV but i lacks corner sharpness as the straightening lens correction digital process degrades IQ massively.
You will simply never get high quality sharp corners with that lens and a Nauticam WWL-C as the corners are never recorded on the sensor @ 24mm. Period.
The interesting exercise is looking at RAW files that have been shot @28mm or 30mm to learn if combining the RF24-50 STM with WWL-1B or an Marelux Aquista 110 or Aquista 130 is going to be the better solution.
If I understand correctly, you would like me to use the original size image, crop a corner and upload the crop sample? I will do what I think you are asking for.
I don't see how the standard lens correction tools in photoshop can do what you are saying, maybe lightroom has a different tool to capture one which I use. Before you write it off I would suggest you use the lens correction tool and see what it actually does and you can see how it changes the image shape when it is used. Have a look at about 6:20 mark of this video:
You can see the top of the image bows in to correct the barrel distortion and you have to crop the image. If what you say is correct then when zoomed at 24mm and auto-corrected the field of view won't be as wide as a standard well corrected 24mm prime, because the correction tools need to crop to remove the barrel distortion.
You would indeed likely get better corners at 28mm when you zoom in and then use the WWL I believe, the digital picture notes that corners improve at 28mm. In theory if you crop an image out of the vignetted image and don't apply distortion corrections, then the image won't be degraded further by those distortion corrections. I'm assuming you don't see those non-illuminated parts of the raw image in the viewfinder. This being the case the camera is cropping the image from the sensor so you can properly frame your image to match what happens after the corrections have been done.
The above RAW files shows what the sensor captures. The corners are pitch black with no photons hitting them. If you have an R5 or R6 II or other full frame camera you paid a lot of money for the FULL FRAME SENSOR; and you also collect more real light when utilizing the full frame of the sensor.
Lens corrections makes you throw away a substantial amount of your expensive sensor. That’s just bad! In the case of the 24-50mm STM it is really really bad and I think it’s the lens in the RF system that throws away light, the by the largest amount. It‘s almost a circular fisheye 😆
You can solve this by zooming in and get sharper corner JPEGs and RAWs.
removed inappropriate convulsions
  • Author
Yes, exactly!
If you take a look at page 1 of this thread, I already posted some images in standard web size and 100% crops from the corners.
Important Information
