Keep or ditch the MFO-1?
Featured Replies
I know there has already been a lot of discussion about the utility and value of the Nauticam MFO-1, but I’d still really appreciate some advice specific to my setup.
I’m shooting an OM-1 in an AOI UH-OM1II housing with the Olympus 60mm macro. I currently own an MFO-1 and just picked up a used CMC-2.
The main reason I’ve kept the MFO-1 so far is that it does let me get slightly closer to the subject and increases magnification to about 1:1.1, compared to 1:1 with just the 60mm alone. That said, in my experience, and other comments I have read, e.g. from Alex Mustard, the improvement in image quality and reduction in focus hunting seem pretty marginal.
Given this setup, would you keep the MFO-1 or ditch it? Does it still fill a useful niche alongside the CMC-2, or is it mostly redundant at this point?
I’d be interested to hear from anyone who has real-world experience with a similar configuration.
For me (Canon RF 100) the main utility is to have a reduced range of focus. It's important for me to shoot small subjects with some element in the background. If the focus go in the back it is difficult or impossible to get it back near.
The MFO change my life... I win a lot of time for some pictures --> better results, faster more time for other shoots
  • Author
I can understand that, but wouldn't the CMC-2 do that, also?
I'm using a R5 with the RF100 I have also the SMC-1 impossible to use for the picture I take with the MFO-1
The range is from near to 1 m or a little bit more. I don't really know.. That mean I can put it and make mear 95 % of the dive with it... some times I change (Flip x3) for the SMC-1 or since last trip the MFO-3.
Next month 10 days in Lembeh with this configuration... the first intensive test with the 3 lenses mounted together.
Last year in Lembeh I was absolutly happy with the MFO-1
The RF100 give me "out of the box" a mx magnification of 1-1.4 it is enough. for near 100% of my shoot.
In my hands, (I sold mine) there was NO visible or measurable improvement with any of the macro lenses (30, 45, 60, 90).
Bill
  • Author
Bill
Thanks. I've seen you say that before. It is very confusing. Some swear by the lens, some hate it. I am still not sure how I feel about it.
I don't know anyone running the OM-1 with macro lenses that seems to get better results with it. Full frame folks do in fact get "better" results.
Bill
Better I don't know but easier for sure
The MFO-1 should be thought of as a high quality low power diopter. In the case of the 60mm macro it only improves magnification to 1.1x while the CMC-2 achieves 1.7x but it will only focus between 33 and 122mm. Based on the focus distances there might be a little overlap with the CMC-2. It seems there are some benefits on image quality on full frame sensors and also prevents hunting with some macro lenses which readily switch to the background. However it seems that for m43 lenses there is no reported improvement.
It seems to me that whether to keep it or not comes down purely to whether you can find subjects in the magnification range covered by the diopters. There is less case for diopters with m43 lenses, first the working distance is small and diopters work by reducing working distance, second the field covered at 1:1 with these lenses is 17mm across, half that covered on a full frame sensor. The CMC-2 covers a field 10mm across at a working distance of 33mm which means it is difficult to aim and to light the subject.
Because diopters like the CMC-2 limit the focus range to a a limited working distance, they are in general more difficult to use compared to a bare macro lens, the MFO-1 limits the range but the maximum working distance is over 1m so you can use it just like a regular macro lens, you can find the subject from a distance and close in while looking through the viewfinder, not so easy to do if the subject isn't in focus until you close right in on it.
  • Author
Thank you for such a comprehensive answer. I thought this was a simple question, but it seems the answer may be far from that.
If I understood you correctly, the CMC-2, like all diopters, may not be a great choice for my m43 setup. The focus distance would be too close and thus difficult. I suppose I should have done more research first.
Now, I wonder if I should keep the MFO-1, and ditch the CMC-2. 🥴
That being said, if diopters do not work well with m43, what option would you suggest for super macro, only the 90mm lens?
No not exactly - the suggestion is to work out if you regularly find critters that require that amount of magnification. My experience with the 60mm macro is it's very rare for me to find something small enough that I feel like I need a diopter. From a week in Lembeh with over a hundred critters found only one or two were small enough that a diopter might have been useful. Your experience might be different, I think it depends on where you dive, how good you are at finding small stuff etc.
The CMC-2 will be challenging to use at max magnification for sure, I'm not suggesting don't use it, rather I don't see it as an either/or situation with the MFO-1 as they have different magnification ranges and I would choose based upon how much magnification I need. If you find you are getting down to 1:1 all the time currently and wishing for more and are OK with lighting subjects right on 1:1, then a CMC-2 is possibly the next logical step.
The 90mm macro I think would be a lot easier to use at high magnification, it has about 65mm working distance at 2x compared to 22mm with the CMC-1 also at 2x, but it's an expensive lens, needs a new port etc. I'd want to be sure I would make use of it and could live with the extra working distance. At 1x it's only maybe 10-15mm more working distance than the 60mm, at 0.5x (35mm wide frame) you are at 170mm then 330mm at 0.25x. So for 60mm long subjects you are getting quite distant. I have the 90mm macro and use it a lot on land, but have not been tempted to take it UW.
This may be daft.. but when I had my Olympus I wondered about the viability of the well regarded Raynox DCR-250 for super macro. These only cost something like US$100. Obviously this is more limiting than having a removable underwater diopter, but for a bit of fun with super-small subjects I wondered if it would work underwater (I never got as far as trying it out). It is 18mm thick and needs a slight step-down ring but maybe works if one has a 20mm port extension already that can be added to the macro port.
Almost 20 years ago, I used a similar setup with a Sigma 150/2.8 and an expensive Raynox in the Philippines.
The image quality was 'okay' (compared to today's Nauticam SMC-1/2), but you could only photograph very small objects with the internal close-up lens, making it extremely limited in its versatility.
I definitely wouldn't recommend it.
  • Author
I think I understand your points better now, but I’d like to ask a couple of related questions.
As I understand it, the bare 60mm has a working distance of roughly 80 mm to infinity (without limiting the focus range) and a maximum magnification of 1:1. The MFO-1 shortens the minimum focus distance to about 58 mm, which increases magnification slightly to around 1:1.1 and also reduces the amount of water between the camera and subject, which is obviously a plus. It does limit the maximum focus distance to roughly 1.12 m, but realistically there’s rarely a good reason to shoot macro beyond 1 m anyway. On m43, the improvements in image quality and focus hunting seem likely to be marginal or even negligible.
Given that, do you feel the reduced minimum focus distance alone is enough to justify keeping and using the MFO-1, considering the added weight and bulk it adds to the setup? Do you personally use it in a similar configuration?
Alternatively, would it be just as good—or even preferable—to shoot with the bare 60mm and rely on a CMC-2 on a flip adapter for the (probably rare) situations where I need more magnification?
For tiny things (like ladybugs in Komodo) I find that the 60+CMC is quite appealing. I have the 90 as well but somehow for me at least the 60+CMC is "easier" than the 90 at full magnification. Probably because I am using the AOI 90 degree finder; with the Nauticam 45 finder it might be different.
Bill
  • Author
At this point, I've decided on the following for our Turks & Caicos next month.
  • Leave the MFO-1 at home.
  • Dive with the CMC-2 on a flip adapter.
  • If I don't miss the MFO-1, sell it when I get home.
  • Consider selling the CMC-2 and flip adapter, too, if I don't end up using it much (although I got a great deal on those.
Does that sound reasonable?
I'd be taking the MFO-1 along and try it on the trip as well. It doesn't take up much room, so why not. Try them both side by side and see what works best for you. Stick it in a pocket and swap it on the adapter as wanted.
If you still want to get rid of MFO-1, let me know. Shooting with a Sony 90nn FF and looking to pick one up.
  • Author
Our trip is at the end of February. If I decide to sell it (my guess is that I will), I can let you know then.
Based upon the reviews and the fact it only gets to 1.1x, I don't have an MFO-1 and don't plan to buy one. Seeing as how you already have the CMC-2, mounting it on a flip seems the best way to go. I agree I'd take the MFO-1 along, you might as well try it out, it's not like it takes up much space.
  • Author
The more I thought about it, the more it made sense to simplify. Bringing both the MFO‑1 and CMC‑2 on separate bayonets would just add unnecessary complexity, so I’d rather stick with a single flip adapter. Sure, the MFO‑1 would be easy enough to pack, but given the range of creature sizes in the Caribbean, I doubt I’d ever finish a dive thinking, “Damn, I wish I’d brought the MFO‑1.” On the other hand, I can imagine spotting something tiny and thinking, “Damn, I wish I’d had the CMC‑2.”
Edited by Adrian Gresores
Wanted to change formatting for one word
Do you have any sample images taken with the MFO-3? I’m using the same combination and would be very interested to see some example shots.
You mentioned using a 3× flip — which manufacturer is that from?
It's a self made flip
I'm searching some pictures wait a mnute
I made some shots during last trip... but to be honest I don't know wich with and witch without the MFO-3
I can try to find some but without waranty.
But if you have time, I'll have some after 10 days diving in Lembeh next month.
Important Information
