Jump to content
Sony a6500 vs Canon R7
Featured Replies
Hello,
I have a Sony Nex 5N in a Nauticam housing.
I use it with the 16mm and fisheye converter with the 4,33 ‘’ dome port.
And 2 sea&sea Ys110a with fiber optic.
So, I shoot only wide angle and what I like the most are big animals : sharks, whales, dolphins, manta rays…
This setup is more than 10 years old. So, image quality is not very good and the housing begin to not work very well : for example, the trigger button sometimes doesn’t come back at his initial position.
But I really like the size of this setup.
So I m thinking about an upgrade.
For the moment, I have 2 ideas:
  1. Sony a6500 with an Ikelite housing with a sigma mc11 or meta bones + tokina 10-17 . What I like is the fact that the camera has an internal flash to my current flash will work in TTL with fiber optics. But this camera begins to be old and investing a lot of money in an underwater setup is maybe not the best idea…
  2. A canon R7, again in an Ikelite housing with an RF to EF adapter and Tokina 10-17. The camera is more recent , better custom white balance for video but I would need to buy TTL trigger and my current flashes will only support manual and not TTL.
What do you think about these ideas?
I mentionned Ikelite and not Nauticam for example because it is much cheaper and the port chart includes the Tokina 10-17
Other options?
I also have a question concerning the flashes.
Ikelite ECKO seems to be really light and small. Anyone already tried them? Which results to expect comparing with my sea & sea Y100a?
Note: I also use my housing a lot for snorkeling
Thank you for your help.
I am using a Canon R7 in a Nauticam housing so will answer only on this part according to my own experience. Personally for bigger animals such as sharks or Manta rays, I prefer the RF18-45EFS + WWL1B combo :
  • it doesn't need any adapter and fits a smaller N100 flat port
  • I find is more adapted to animals in the distance with a longer range although I can use it for wide coral reef images
  • It is often even sharper in the corners than the 10-17 tok fisheye+minidome (which I also own and seldom use it anymore)
Otherwise I don't understand your remark about a mandatory TTL trigger (I am using a manual trigger currently which works fine with the R7 and most of the strobes).
FWIW after having used alu housings of different brands (Subal then Nauticam) I wouldn't go back to Ikelite (which I have also used in the beginnings). I know investment can hurt financially speaking, however when it's time to change you should be aware that the cheaper might be the more expensive in the long run (less reliability, frustration leading to forward another change, etc.).
Providing you are mainly focusing on big aniimals, you should invest into more powerful and even lighting than entrry range strobes mainly thought for macro.
There are now a number of brands which have rolled out these 2 past years some quite powerful strobes under the 900€ price tag (think Supe, Fotocore, Kraken, AOI, Backscatter, etc.) : they should be more suited to your kind of subject and worthwhile the investment.
Manual mode is not so much an issue with a little experience and will not need a TTL trigger btw ;) )
Ikelite are fairly unique and were mostly setup to use ikelite strobes with wired connectors but have just started optical triggering recently. They tend to push TTL as they claim no one else knows how to do it. I think after using Nauticam you may find the ikelite housings a bit basic for want of a better word. You need to see what ports they offer and read the fine print for your chosen lens option there are some interesting limitations sometimes. They are also not that compact, basically a big cube with a lot of space inside. They don't offer a compact 4"dome port for fisheyes for example. The dome options for the mirrorless housings like this one are quite limited. the only dome options allowing zoom is the 6.5"dome with a zoom knob on the extension.
Unfortunately you picked camera models that only have ikelite or Nauticam housings available. I'd suggest a good start would be to choose your lens options and work back through the ports to available housings to finally arrive at a camera choice. If you wanted a WWL for example the 18-45 is supported for Nauticam and if you can use it on Nauticam you could also set it up on Marelux.
If you wanted a 10-17, it takes 20mm less extension than the Canon 8-15 so a Nauticam 10mm extension, however Marelux doesn't seem to have a 10mm extension so it looks like it may be a non starter on that system for R7. You could use a the excellent Canon 8-15 with it though on either system.
If you wanted an extremely flexible wide angle setup you could run an adapted Canon 8-15 on m43 and have the ability to zoom from full diagonal fisheye to a field equivalent to a 28mm rectilinear wideangle - full frame equivalent but with barrel distortion from the fisheye. The cheapest way to do that would be in Isotta with a special extension with zoom gear and a 4.5"dome port on their OM-1 housing. So it's a fisheye, part of WWL range setup and a 14-18 (FF equivalent ) lens all in one setup. I use this setup with Nauticam and it is excellent if a little heavy. The m43 sensor is good enough for what I do.
On the question of port charts for EF lenses the main housing manufacturers have their systems to allow use of EF lenses on the RF-EF adapter, Nauticam housings for example setup the housings to you can use the recommended ports and zoom gears for your EF lens from the EF port charts with the RF housing and it all works. Isotta has and RF-EF adapter ring, but they don't support the R7.
You could also look into the Marelux R7 housings They do support the Canon 8-15.
  • Author
Yes . You are right. Sorry. The Canon R7 needs, at least, a manual flash trigger.
Concerning Nauticam vs Ikelite : i am convinced that Nauticam is better but the price is prohibitive...
Maybe if I find one used but it would probably be for an older camera model like maybe an a7II/a7rii but bigger than an apsc housing...
About fisheye lenses , I had in mind :
  • Tokina 10-17 for APSC
  • Canon 8-15 for full frame -> So this lens makes sense for APSC as well?
On ikelite port chart, I see that with for Sony E mount, Tokina 10-17 can be used either with a 6" dome port or a 8"dome port (good for slept shots). 6" dome port is too big in order to handle easily ?
FOr Canon R7 : also 6" or 8" dome port but no zoom possible for the 8".
On Nauticam side, which dome port can be used for the tokina 10-17 for Sony e mount and for canon APSC?
I don't see any possibility in the port chart
Sticking with Nauticam :
For Canon APSC -> I don't see the rtokina 10-17 in the port chart
For Sony full frame : for using the canon 8-15 : N100 to N120 adapter + N120 Extension Ring 30 II + 18802 (8.5" Acrylic Dome Port) so it seems very big
@Chris Ross : I never looked at the m4/3 world but maybe it is a good option if it is cheaper, lighter and minimal image quality reduction compared to APSC or full frame. Which camera model would you recommend? with an adapter and the canon 8-15?
Thank you very much for your detailed answers :-)
Here's my take from a long time Canon dSLR and now mirrorless shooter......
The R7 is a fine camera no matter what housing you put it in. APS-C versus full frame is in my opinion not as critical as too many whine about. Any print, self printed book, online use or whatever can be done with APS-C or even 4:3.......
As to lenses for Canon the EF-RF adapter (I'd recommend getting the Canon brand) will function fine with several EF lenses and new RF or RF-S lenses designed for APS-C sensor Canon models including Canon R100, R50, R10 and R7.
The Canon 8-15mm is stellar and APS-C designed Tokina 10-17mm can be a good choices. Both lenses are discontinued but can be found on the used market. Since the Canon R7 is APS-C the Canon RF-S 10-18mm rectilinear lens is a bargain producing great sharpness and color. It's all I own for WA shooting now.
Just noticed the poster is more interested in wide shooting but here's info for any potential macro shooters.
For macro several lenses are fine including the discontinued but very sharp Canon EF-S 60mm. With the Canon R7 camera's 1.6X sensor crop factor it "sees" like a 96mm lens. On APS-C sensors I feel the Canon 100mm Macro whether the older EF or newer RF model are way too long and simply frustrate people.
On housings I'm tired of people denigrating Ikelite......
Are they perfect? No, but cost to benefit are still an attractive option......
Full disclosure; I was an Ikelite dealer for over 35 years and user and also owned Aquatica and Nauticam housings. You can search for comments and recent use in 2025 of the Nauticam Canon R50 housing and various WWL and other lenses with sample photos.
Ikelite's smaller DLM sized housings for Canon APS-C and even the full frame Canon R8 and Dry Lock port system can withstand any typical dive conditions. Their full sized housings as evidenced by many top notch shooters (see several web site stories at www.ikelite.com) have enabled photographers to capture great images from Norway's arctic to wherever. If you really need 100M depth rating then sure buy an aluminum housing at 3-4X the price....But you'll still be shooting the same lenses inside any housing.
Famous underwater photographer Chris Newbert long ago at a DEMA trade show told a friend considering an Ikelite housing; "They're all just boxes with o-rings keeping your camera dry". He shot many (all?) of his macro images for his famous underwater coffee table book: "Within a Rainbowed Sea" with Ikelite housed Canon F1 cameras.....At another show I had Michael Aw of Ocean Geographic fame tell me his early Bunaken books were shot using multiple Ikelite housed film cameras.
The argument on acrylic versus glass domes I contend in today's world of shoot, edit, publish and share is simply not as important as touted. I'm sure many will disagree and that's fine......
As I've written the new Ikelite TT5 Canon optical transmitter provides accurate TTL with their newest RC165 and Ecko Fiber strobes. If you have other brand strobes you can trip them in manual flash with a quick change in the camera's flash menu choice.
I find people not even trying TTL to be another disappointment in today's tiny underwater shooting world but that's me.......
Underwater time is limited and unless you're shooting slow macro creatures playing with flash settings is too "old school" for this 72 year old :)
For the original poster here's an article I wrote on DivePhotoGuide shooting the new Ikelite Ecko Fiber strobes in Roatan Honduras. They're all I plan to shoot on my 2026 trips to Palau in March then Philippines in June.
DivePhotoGuide
Shooting the Ikelite Ecko Fiber Strobes in Roatán
My intent is NOT to "stir the pot" but share a lifetime of underwater imaging insights with the original poster :)
Good luck with whatever set up you choose!!!!
David Haas
Edited by dhaas
One thing I will say about Ikelite (I don't own one) is they will sell you parts to service it yourself and it's not expensive.
Getting Nauticam to even reply about parts is impossible.
That said I shoot Nauticam.
Even though you’re on the West coast, reach out to Reef Photo in Ft Lauderdale if you get in a Nauticam bind. They are connected to Nauticam USA.
Ikelite is the least expensive. There are reasons. I’ve owned a couple and have been much more happy with the build quality of Nauticam. Get what you pay for.
Edited by ChipBPhoto
Yes you can use the Can 8-15 same as the 10-17. You set the zoom limiter to 10mm and can zoom from 10-15mm with APS-C, better image quality, less zoom range, more weight, and can be used on Marelux compared to the Tokina 10-17
Yes you need to read the fine print in the port charts:
this is because the small housings don't have a zoom control it must be on the lens extension and all they offer is the 6"dome in this format
Regarding the m43 option , I have the OM-1, you have a lot of options for housings and Isotta is a good option if you want to adapt a Canon 8-15. Here is the parts list in this post:
SO you could price out this option. I did it with Nauticam, but it ends up expensive as you need an N85-N120 adapter which are really pricey and Nauticam no longer makes the specific adapter and their ports and extension rings are pricey. I got some of the items second hand. You will need the metabones adapter - the latest model EF-M43 is needed due to geometry of the OM-1, but I have an older version I filed down to fit. The image quality is great though. This gallery is all taken with OM-1 and Canon 8-15:
https://www.aus-natural.com/Underwater/Walindi%20Resort%20PNG/index.html
I did have a few issues with noise on a couple of deep dives on overcast days, but doing it again I think easily compensated by upping the ISO and shooting a little wider open. Shooting at f8 is generally enough so you can use less powerful strobes. If you can source the FML-3 mini flash to trigger strobes it is a cheap and reliable option for manual triggering.
Be aware though in Nauticam the housing ends up quite heavy and needs a fair bit of flotation, the small housing size is less buoyant and the 8-15 is a heavy lump of glass.
Regardless of housing choice, if you decide to go Sony, don't choose the 6500. Get at least the 6400, which still has built-in flash and has vastly improved AF over the 6500.
I like my Sony A-6400 in Nauticam. I use either the WWL plus a Sigma 19 or the kit lens behind the WWL. I also use the Sony 16mm pancake by itself, with the wide angle or the fisheye adapters inside the 4.33 dome. The WWL easily produces better image quality than the 16mm pancake but at the expense of only a 130 degrees FOV. The problem for me with the A-6XXX series of cameras is the 1/160 sync speed and the preflash that cannot be cancelled for manual only. Using the UWT trigger I can trick the camera into 1/200 sync speed and it works fine. It also has the booster battery or I can run onboard charging thus making it possible to shoot several days without opening the housing if need be.
I really liked my 6500 but that battery definitely didn't last long. I'm currently on the hunt for a 6400 although since a large focus will be video I debate if giving up IBIS is worth the improved AF and battery life.
I shoot an A6100 in an Nauticam A6400 housing. The cameras are dimensionally identical. For WA I shoot the Tokina 10-17, with the Zen DP100 mini dome. For Macro, I shoot the Zeiss Touit 50mm macro with a +7 flip diopter. For Strobes, I started with Dual 110a's, and now have D3 Mk2's.
I absolutely love the setup. It's small with the mini dome, and has zero focus issues with the Tokina lens. The Zeiss lens is very fast as well (as long as it's been software updated).
Battery life can be touchy, but I added the Nauticam USB-c bulkhead, and have a USB-C to mini usb adapter cable, and charge between dives from a power bank.
@kalani Can't go wrong with the Canon R7, but consider the R50, too. It’s compact, relatively inexpensive, and Nauticam’s housing is much cheaper than full frame.
As for the A6500, I agree with other posters here that the A6400 is a better camera. If you’re shooting stills primarily, you won’t miss the IBIS. If you shoot video you might want better stabilization than what Sony offers. The R7 has better video specs: e.g., 4k 60p versus 4k 24/30p in the A6400.
Any A6xxx camera before the A6600 also has that tiny W series battery, much improved with the A6600 and A6700.
  • Author
Hello,
Thank you again for all your replies and advices.
Yes I shoot also videos . I always put a GoPro on the top of the sousing but I can take better videos than a Gopro, it is a pro to consider.
I will try to sum up in order to sort my thoughts so far:
  • Canon R7 vs Sony A6xxx (I'm not talking about the a6700 that I don't know) :
    • Canon is better (for my use) on almost every aspect of: better autofocus (with EF lens), better white balance for video, better video options (oversampled 4k 60p), better battery life, better flash sync speed... BUT there is a major cons : No TTL with my current strobes... Concerning this point, I don't really understand why it would not work because the camera "talks" with the TTL converter and then the TTL converter send the good amount of light trough the fiber optic. That means that Ikelite strobes don't "interpret" the amount of light the same way as other brands... That is really annoying...
  • Canon R7 vs other Canon R camera : regarding the price of a used R7, I think that I prefer to go with a R7 without compromise on 4K frame rate, Ibis or Megapixels... Canon R50 could have been acceptable regarding the weight but the fixed flat port for Nauticam is a show stopper for me
Concerning housing brands : Nauticam is really too expensive for me (housing, ports, domes...)
So, I'm still considering Ikelite but the lack of TTL with no Ikelite strobes is really annoying...
With Ikelite, it would also be possible to buy 2 dome ports (without having to sell my house for the second dome lol) : the classic 6'' and a bigger 8" for split shots and paired it with a canon 10-18 RF lens...
Another note : I had confirmation that with the updated Ikelite housing for canon R7 , zoom gear and port, it is possible to put the camera with the tokina 10-17 lens without to remove the dome port.
The R7 can also be a great second camera (paired with Canon R full frame) for safari travels for example.
Edited by kalani
Marelux mentioned building a Canon R50 housing but lately has gone quiet.....I suspect it may be due to the Canon R50 having Canon's 21 pin cyber flash hot shoe only.....
My advice for Marelux would be simply make the Canon R50's pop up flash usable. That moves all flash trigger headaches from the equation. Yes, recycle time depending if one wants to shoot flash photos at 5FPS or faster might slow down your shooting but for manual dialed down triggering depending on your flash unit choice could be fine.
Personally my low priced Ikelite housing for the Canon R100 and compact 6" dome can accommodate the only 3 lenses I'll shoot with these days.
I can shoot the Canon RF-S 18-45mm IS STM "kit" lens, RF-S 10-18mm IS STM wide angle lens and if I wanted to the Tokina 10-17mm and Canon EF-RF adapter all mounted to the camera with no zoom clamps, rings, etc.
I did this approach for many years with the lightweight Canon SL-1 DLM housing and 6" dome port. I'd use some variation of Canon 18-55mm IS kit lens and a Tokina 10-17mm, Sigma 15mm and even an older Canon 15mm f2.8 lens never taking the port off for even extended 10-14 day trips.
The less parts you disassemble and re-assemble means less chances of leaks, errors, of floods.....
The simple mechanical vacuum system I also have is a plus but I dived for decades without one on Ikelite and Aquatica housings.......That said I do like it on my current housing and it imparts confidence my system is sealed.
Good luck
David Haas
10 hours ago, kalani said:
  • . BUT there is a major cons : No TTL with my current strobes... Concerning this point, I don't really understand why it would not work because the camera "talks" with the TTL converter and then the TTL converter send the good amount of light trough the fiber optic. That means that Ikelite strobes don't "interpret" the amount of light the same way as other brands... That is really annoying...
What strobes do you currently own? The ikelite strobes have their won proprietary TTL system that only works with the ikelite TTL triggers which are now a little cylinder that connects to a housing bulkhead. They used to line inside the housings. I know at leats one person who has had ongoing issues with these triggers.
But there is more than one way to solve the problem The new external UW technics triggers could be used on ikelite and assuming you have compatible strobes you should be able to use them . If not compatible you have a wide choice of other strobes you can use.
I still think you should consider jumping to m43 generally a great system to use, with a lot more choices for housings and lenses, depending upon which body you choose. You could even use your 10-17 with the metabones speed booster.
  • Author
I have two Sea&sea YS 110a strobes
I will have a closer look to m43 sytem
  • Author
Another cheap option : what do you think about sea frogs salted line for Sony A7III ?
https://www.saltedlineeurope.com/products/seafrogs-saltedline-underwater-camera-housing-for-sony-a7iii-a7riii-6inch-v7-dome-port?variant=50842460356955
It is written that 6" or 8" dome ports (acrylic or glass) would work with the canon 8-15 fisheye (without zoom gear).
For flash triggering , the flash trigger cost only 50 euros but it will not allow TTL...
A lot of people use them , they are cheap for a reason. Among other things the ports are setup for multiple lenses, but can only have the right positioning for one of them. They will let you get your camera underwater and seal properly and certainly you can take quite good shots with them. The vacuum system is not recommended as it can only be used to test, it's not water tight so you don't keep the case under vacuum while diving, which defeats part of the purpose of pre-loading the o-rings. There is a third party solution though.
You could check with UW technics when the time comes if they support YS-110a. They are getting quite old now though.
I'm guessing using the YS-D2 setting on UW technics will work pretty well for the 110a's.
But I noticed limitations with my 110a's when I stepped up to mirrorless from compact and really noticed the additional power from the D3's when I upgraded.
  • 2 weeks later...
What is that third solution to keeping a Salted Line housing under vacuum while diving ?
Important Information
