MFO-1 and focus limiter
Featured Replies
I almost put this into one of the existing MFO threads but then I thought it might deserve its own space.   I am curious and interested in the MFO-1, but oddly, Nauticam has no instructions or manual for this thing on their website.  Pretty much the only information they provide is sales-type stuff.  I realize there are still few of these in the wild, but I am trying to understand its utility.  If using the MFO-1, do we set focus limiters to the "infinity" setting and not suffer the hunting and focus speed issues that setting can cause, or use the reduced focus range setting?  It seems like it would need to use the unlimited setting given the published focusing range, but ???
Perhaps I am just being dense, but maybe Edward Lai or someone else with knowledge could post some additional details about using the thing.
  • Replies 69
  • Views 13.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Dave_Hicks
    Dave_Hicks
    I shot my new MFO-1 last night with a Nikon Z8, 105mm F-mount, and Nauticam housing, dual flip with the MFO-1 and Subsee +5.   Quick observations are that the Subsee is likely going on the s
  • I Just did around 30 dives in Lembeh and had the MFO for most of it, I think it's very easy good ot leave on for general macro shooting. You kind of don't notice it's on until you nee dit and it just
  • Here's a few thoughts I wrote on the MFO after doing around 30 dives or so in Lembeh with it last month    https://insidescuba.online/p/why-the-nauticam-mfo-1-is-a-must-have-for-underwater-m
Posted Images
I just got my MFO today. Not wet yet, but on the bench I only see about 20cm max focusing distance on a Nikon 105 lens. Is this expected?
Hi I try for the first time today my MFO-1 with a Canon RF100  max distance beetween 1 and 2 m... but the first impression ...
Waouh 🥰   Now I go watching the first shoot.
This is a wet lens.  Please try it in the field, or at least a bath tub or water tank that is big enough.
Same subject showing close up and at distance     Canon R7 with 60mm .Very impressed  i have tried it with the 100mm in a big swell but very happy with the out come. Subject size 20mm
Edited by Griffer
missed size
Thanks for confirming. I will dive it in a few days!
What I noticed is that it is much more easier to take such pictures... before it was complicate to put the focus then it allways go at the bacground. I love that
Edited by CaolIla
Small update of using the MFO-1
Maximun distance is less as what I believe... I estimate now on 1 meter with the RF100.
I probably made 95 % of the pictures with it the last 4 days.
Quick observations are that the Subsee is likely going on the shelf. The MFO both reduces and extends focus range to over a meter and reduces it beyond what the 105 can do by itself. The Subsee +5 has been my go-to macro accessory as it also reduces the shooting distance while not magnifying too much. However, it has a very limited range of maybe 30cm. I often have it flipped down and then mistakenly try to shoot something larger beyond its range, causing a delay to flip it up. The MFO can get in tight but also provides useful range.
The first critter I spotted last night was a pretty large Pacific Ruby Red Octopus, about 12 inches long, This is about as big as they every get. I was able to take full body shots from about 1 meter away no problems.
Here are two sample photos:
f16, 1/200s, iso250
f16, 1/200s, iso100
6 hours ago, RVBldr said:
@Dave_Hicks Any idea how much closer you're able to get with the MFO-1?
Not any closer than my +5 Subsea did already, maybe 10cm? Just looked at the Nauticam product page than they report 12cm with my exact 105mm lens setup. But then you can point off to another subject up to 114cm away. This tracks with my experience on this first experience. Without any diopter you can't get much closer than 25-30cm or so with this lens.
I may try some dives with the MFO directly on the port. The MFO-1 in only about 10g less than the Subsee +5, but is a bit shorter. However, the Nauticam dual flip adapter is over 300g. Inexplicably, the MFO can NOT screw directly on the Nauticam flat port as the threads are not deep enough. However, it does come with a minimal spacer / adapter that lets you screw it on the port.
Edited by Dave_Hicks
  • Author
3 hours ago, Dave_Hicks said:
 Inexplicably, the MFO can NOT screw directly on the Nauticam flat port as the threads are not deep enough. Fortunately, I have a tiny little aluminum adapter (from my Kraken krl-09) than weighs nothing and can make the connection.
That is disappointing.   I am thinking I want of these for use on a 105, before trips to Philippines and Sulawesi next year.  I guess I need to get the screw on spacer or something else?
Actually, I just remembered / realized that the MFO-1 comes with such an adapter in the box. So, no worries if you buy the MFO without a flip adapter. I should have realized that earlier. I edited my earlier post to clear up the confusion.
What about benefits, if any, on crop APS-C size sensors? For instance, Nikon DX and my favourite 60mm macro lens. Does anyone have a field experience using the MFO-1 and the Nikon/Canon crop sensor cameras?
Possibly a little early as it's newly released.
The port chart shows the details of magnification and focus distance:
https://drive.google.com/file/d/1FmfFKRmxF8aFsCdF97nBk1QIIAVbjlsI/view
I am using mine on the Canon R7 using the 60mm and RF100m works very good on both lens
Wish I had followed my instincts and bought the MFO instead of the SMC-3.  I realize they are different tools, but the MFO sounds like it would be more advantages to my personal needs at this time.
Thanks for the feedback @Dave_Hicks
  • 3 weeks later...
I did another few dives with my new Nauticam MFO lens on my Nikon Z8 with the AF-S 105mm macro lens. Based on my earlier experience, I decided to mount the MFO directly on the port and dispense with the Dual Flip adapter and it's 300g weight. To my delight my camera rig was just about perfectly neutral in the water with this setup. (Nauticam Z8 housing, HF-1 and MF-2 snoot strobe, 6 stix jumbo floats on the arms, and my custom-made port float) I let it go in mid-water and it just hung there. :)
If I am shooting macro with the MFO I don't see any compelling reason to take it off the port. It can handle all distances from maybe 10cm to 100cm. If anyone can think of a reason to keep the MFO on a flip adapter I'd like to hear about it. I can't think of one right now!
Here are a few photos:
Cockerell’s Dorid (Laila cockerelli)
Range: 10-15cm
Nikon Z8 w/Nikkor 105mm lens, Nauticam MFO diopter, f16@1/200s iso160 Backscatter MF-2 strobe & snoot + BS HF-1 strobe with beam restrictor
Red Rock Crab (Cancer productus) with egg mass
Range: 60-75cm
Nikon Z8 w/Nikkor 105mm lens, Nauticam MFO diopter, f11@1/200s iso160 Backscatter MF-2 strobe & snoot + BS HF-1 strobe with beam restrictor
The only one I see is to put a macro lens
I have a double flip with the MFO1 and the SMC1 but I agree 95% minimum is with the MFO1 on place
Hi, I also use the MFO01.
Does anyone have pictures "with lens/without lens" so I can see the differences?
I was using it in a Mediterranean black water session and it wasn't the best situation to put the lens on and take it off.
I also have a double flip. I very occasionally use a SubSea +10 diopter, similar to the SMC1. If I want to use that I'll still pair it with the MFO on the flip. Otherwise, I've replaced the Flip / Subsea +5 combo with the MFO directly on the port.
Would be great to hear about experiences with a MFT camera. For instance with the Olympus 60mm macro (quite a hunter) and the Nauticam 45mm macro.
I Just did around 30 dives in Lembeh and had the MFO for most of it, I think it's very easy good ot leave on for general macro shooting. You kind of don't notice it's on until you nee dit and it just allows you to get a tiny bit closer than normal. With regard to focusing quicker, I didn't notice that but I am pretty used to shooting macro and generally start off with the camera in pretty much the right place to make focusing instant. The image quality from it and it doesn't have any colour casts like some other macro lens such as the EMWL
