Preview of the Retra Maxi Strobe
Featured Replies
  • Author
Off camera remote triggering is not a feature of the Maxi's. You would need a dedicated remote trigger product.
BTW, my full review of the Retra Maxi's will be published this coming weekend I believe.
  • Replies 131
  • Views 17.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Kiliii Yuyan
    Kiliii Yuyan
    Hi everyone, I just did a pretty extensive review of the Retra Maxis compared to several other top of the line strobes, using quantitative methods in a studio. I reckon it's a good counterpart to Dav
  • Dave_Hicks
    Dave_Hicks
    I updated the Power Level comparison, trying to find a better and cleaner way to visualize the range and alignment of power levels across the three strobes being compared. Feedback is welcome! (PREVI
  • Dave_Hicks
    Dave_Hicks
    Sharing are a few more wide-angle shots with the Maxi's. The water conditions around the PNW tend to be fairly particulate at the best of times, so I normally like to use reductions rings. The Maxi
Posted Images
OK, and looking forward to reading your full review!
55 minutes ago, CCRphoto said:
A question about the Retra Maxis - what are the options for offcamera/remote firing? (doesn't need to be TTL)
I believe all the current generation Retras have the same off-housing remote possibilities: you can run a long fibre optic cable (the most reliable and inexpensive); or you can set it up so that the Retra sensor can "see" a light trigger fired by the camera (more tricky); or use a light sensitive wireless sensor such as the Anglerfish plugged into a Retra which is very sensitive to a strobe being fired nearby and would trigger the Retra.
The Retra Maxi optical sensor is very sensitive. I am pretty sure a light tube in the port would trigger as long as it can see the master strobe.
The build quality, light quality, speed, power, light spread are just amazing. And as powerful as they are they can be turned way down for a huge range of power.
One thing, not a big deal to me since I do not shoot video, the TTL flash cancel (preflsh cancel learning mode) is shared with the video On/Off mode. So, you must use the Retra App to tell the strobe that you want TTL cancel or Video light. This really only becomes annoying for Sony shooters whose Sony camera is always on TTL mode and you want to shoot manual strobes (and video). And you decide you want to shoot a video mid dive.
I am very happy with my Retra Maxi strobes. They are not all that big, they are neutral in the water, I think they are the most powerful current strobe in the market. Amazing strobes.
Edited by Nemrod
Sounds like I should be able to make something work! Cheers!
Good to know - cheers!
  • 3 weeks later...
Posted too soon--my observation about the non-linearity of the photoshop luminance measurement, especially at the higher ranges, was addressed earlier in the thread.
As a testing protocol note, I also struggled with testing the higher end output of the strobes without compressing the results. What I settled on was to take photos (of a white wall, but of course a grey card with 18% reflectance would be better for this purpose) at ISO 100, F22 and to move the flash back around 1.4 meters from the wall to reduce the reflected light into a range where the measurement devices (luminance scale in lightroom!) weren't clipping. And for added accuracy, I basically took the same shots at wider appertures and tried to match lightroom-reported luminance levels to reverse engineer actual f-stop scale exposure differences between the different strobes.
Anyway.. very nerdy, I know, but just a suggstion for anyone else running into this very niche issue testing very bright strobes :D
Edited by DreiFish
Really no longer relvant to the discussion :)
